Question about Motorola Mobility ROKR E6 Smartphone
Autorun.exe file created automatically
Hi... in my e6 files called autorun.exe& autorum.inf files r crated automatically nd it can't be deleted. It also can't be seen when plugged into computer
is it a virus??? help me...... my speaker sound is also lost. is it due to autorun files???
These are viruses and may cannot cause any damage to ur phone..ur E6 have been infected when connected to an infected computer. u can remove this by a virus scan using a good kaspersky or McAfee. pls beware to use an updated anti-virus.
Posted on Oct 08, 2008
My program file regsvr.exe delete.How restore this
Dear Amartya,
Here is a solution for your problem.
What the regsvr.exe virus does?
• This worm creates folders and a registry entry to enable its automatic execution at every system startup.
• This worm also creates a scheduled task to enable its automatic execution at a specified date and/or time.
• It also creates Autorun.inf file for its auto execution.
Solution to fix the problem:
1. If the task manager and registry editor is disabled then we need to enable them first. Read this post.
2. Delete the Autorun.inf file created by the virus. Read this post to know how to do that.
3. Now type msconfig in the Run dialog and click on startup tab.
4. Look for regsvr and uncheck any options, click OK.
5. Now traverse to control panel -> scheduled tasks, and delete the At1 task that might be listed there.
6. Type regedit in the Run dialog to open the registry editor.
7. Click on Edit -> Find and search for regsvr.exe
8. Just delete all the occurrences of regsvr.exe virus (do not confuse it with regsvr32.exe which is not a virus).
9. Navigate to entry HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon and modify the entry Shell = "Explorer.exe regsvr.exe" to delete the regsvr.exe from it.
I think it helps.Let me know
Best regards
Chandrashekahr Bhat
Dec 25, 2010 | Microsoft Windows XP Professional
Tip
How to remove Autorun.inf Virus ?
Manual way:
1.) Open Notepad and do not write anything in it. Go to File > Save as autorun.inf
2.) Copy the blank autorun.inf file that you have created in the above step and paste it in your "Pen Drives"
3.) Remove your pendrive.
4.) Re-insert your PC. Now your pendrive is safe to use.
Automatic way:
1.) Download Panda USB Vaccine which allows users to vaccinate their PCs in order to disable autorun completely so that no program from any USB/CD/DVD drive can auto-execute.
2.) Download Flash_Disinfector.exe and save it to your desktop.
  • Double-click Flash_Disinfector.exe to run it and follow any prompts that may appear.
  • The utility may ask you to insert your flash drive and/or other removable drives including your mobile phone.
  • Please do so and allow the utility to clean up those drives as well.
  • Wait until it has finished scanning and then exit the program.
  • Reboot your computer when done.
Flash Disinfector will remove any autorun.inf files; create a hidden folder named autorun.inf in each partition and every USB drive plugged in when you ran it. Don't delete this folder. It will help protect your drives from future infection
on Oct 29, 2010 | Computers & Internet
I am using a Transcend 8GB USB Pend Driver. when i scanned it, it showed me that, find "rahulvirusprotection.vbe". Hence i delete it immediately. After deleting the virus, i tried to access the...
It is virus which uses autorun feature of the removable devices such as USB Pen Drive. These type of viruses usually have two files. (a) autorun.inf and (b) the executable (.exe) or script file. Some Antivirus programs delete the exe file but the autorun files remains. In your case, the exe file (rahul's virus protection.vbe) has been removed but the autorun entry is there, which is run everytime you try to access your pen drive. First, plug-in the drive and DONT OPEN IT. Open 'My Computer' , right click the pen drive and choose explore. (This would by-pass the autorun feature).
Download Flash Disinfector and save it to your desktop. Double-click Flash Disinfector.exe to run it and follow any prompts that may appear. The utility may ask you to insert your flash drive. Please do so and allow the utility to clean up those drives as well. Wait until it has finished scanning and then exit the program.
(Flash_Disinfector will remove any autorun.inf files, create a hidden folder named autorun.inf in each partition and every USB drive plugged in when you ran it. Don't delete this folder. It will help protect your drives from future infection)
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 24, 2010 | Office Equipment & Supplies
Antivirus for ''doomsday'' virus
I had this virus, and the following procedure seemed to work in getting rid of it for me. Hopefully it works for you as well.
open command prompt my going Start > Run and typing cmd.
You should be in a directory called something like “C:\Documents and Settings\User”. if you are not, change to it by typing ‘cd’ and the directory above (replacing ‘user’ with your username), and then pressing enter.
type ‘attrib’ and press enter. There should be a file called svchost.exe, and will have the attributes SHR (which stands for System-file, hidden, and read-only).
type ‘attrib -s -h -r svchost.exe’. This removes the SHR properties and allows you to delete the file.
type ‘del svchost.exe’. This should delete the virus from your computer.
NOTE: svchost.exe is a critical system file if it is located in C:\WINDOWS\System32. If it is located elsewhere (as this one is), it is generally a virus.
Then, insert infected pen drives (memory sticks, iPods etc.) which carry the virus. Change the directory to the pen drive by typing ‘E:’(or whatever letter it is) ENTER. Then type ‘attrib’ as above.
there should be the files ‘protector.exe’ and ‘autorun.inf’ which also have the properties SHR. type ‘attrib -s -h -r’ ENTER, and then delete the files by typing ‘del autorun.inf’ ENTER then ‘del protector.inf’ ENTER. This should remove the virus. Autorun.inf might reappear, but this shouldn’t be a problem.
Do not open the pen drive after you insert it, and cancel any autorun windows that come up.
May 13, 2010 | Computers & Internet
When I open computer a message displayed cannot find regsvr.exe
Hi there.
You have a virus on the PC!!
2. Delete the Autorun.inf file created by the virus. First go to cmd (start menu, run or search, type “attrib X:Autorun.inf –s –r –h” without quotes where X is your drive name which is having the problem. Now the file is visible and ready to delete. After deleting the file, close the explorer and open it again
9. Navigate to entry HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionWinlogon and modify the entry Shell = “Explorer.exe regsvr.exe” to delete the regsvr.exe from it.
shell_regsvr.jpg10. Now to actually delete the virus from the system go to system32 folder and delete the regsvr.exe virus file from there (you will need to uncheck the option of “Hide Protected System Files and Folders” in Folder Options to view the virus file).
Reboot the system for changes to take place.
If this is too much for you to understand please post back for an alternative.
Good luck
May 27, 2009 | Microsoft Windows XP Professional
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
Autorun.inf doesn't open file in internet browser
Hello ksharp628,
I use a program called autorun.exe One limitation of the standard AutoRun facility is the fact that it will only run executable programs; it will not by itself open document files such as web pages or text files. AutoRun.exe is designed to circumvent this restriction: it will open any number of document files or start executable programs. Moreover, it is smart enough to use a sensible fall-back strategy if no documents can be opened, perhaps because the target system does not have the required support for those document types.
example of my autorun.inf
[autorun]
open=autorun.exe msn.html
action=Run MSN.com
icon=msn.ico
in root of thumb drive I have Autorun.exe Autorun.inf MSN.html and my ICON msn.ico wich i did a search for on my computer
I hade t make and msn.html
my edited msn.html file open in txt format
<meta HTTP-EQUIV="REFRESH" content="0; url=http://www.msn.com">
You can replace with what ever website you want and rename it to that.
This autrun.inf setup will popup the autrun box and ask you pick an option. this is as close to running the webpage when inserting the usb drive. The program comes with a .pdf on many options wich can be used with autorun.exe.
the link to the autrun.exe program is found below.
http://www.tarma.com/products/autorun/
Hope this helps you, take care.
May 05, 2009 | Dell Dimension 4600 PC Desktop
Unable to delete the autorun.inf
hi azhar here form Karachi it is very easy. do, the below steps
reboot ur PC in safe mode with command prompt
when u bring a dos screen just move to ur drive mostly virus stayed in d: drive got d: drive and type
d:dir/ah and press enter
if u see there any auto run.inf file there also should be another file like .exe file or .bat or any kind of unknown , file so for delete the auto run file type attrib -s -h -r autorun.inf and press enter
then type del autorun.inf and hit enter here u go u have done.
do the samr process in all drives because mostly autorun.inf file make copy in all drives
remember autorun inf is just a file which help the virus to run autometicly
Feb 12, 2009 | Microsoft Windows XP Professional With...
",.exe" (comma.exe) causing a problem
Its your OS affected by virus..
Mar 04, 2008 | Computers & Internet
How to edit registry
1) to edit registry go to start / select run and type regedit. from there you are able to edit registry values. BEWARE because editing registry values may make your windows stop working. you should know what you are doing and you are responsible of the cosnequenses 2) a bat file is a batch file. Batch files are files that allow MS-DOS and Microsoft Windows users to create a lists of commands and/or programs to run once the batch file has been executed. 3) create a file called autorun.inf and type inside [autorun] open=file.exe save your file and write it in the cd you want to autorun the file.exe part must be replaced with the executable you want to load when your CD autoruns
Oct 08, 2007 | Microsoft Windows XP Professional With...
Motorola Mobility ROKR E6 Smartphone Logo
148 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
