HELLO I want TV Polaroid power supply part,the part number is 860-AZO-MLT666AMH.My Tv blown up some months back and I found out the fuse T5AH/250 its gone. Please can you be of help. Thanks, Akins
  • 173 Answers
Sorry dont have a parts book handy.. but blown fuses usally means a big part with a heatsink behind it has shorted.
call a wholesale electronics parts house close to you and they might have it or can cross it to a stronger generic.
Posted on Oct 08, 2008
Polaroid TLX-1911C LCD TV with no picture (black screen) and sound. Which board do I replace? Power supply or Main board?
I would first check the power supply. Check the main fuse, if is blown and there was no power surge from an external source, the supply board has some serious problem. If the fuse is fine measure the output voltage of the power supply board. Check for any swollen electrolytic capacitors, they are the number one cause of every LCD failure I have come across. I just fixed a Polaroid FLM1514 which has a 2956C Ver 2.0 power board driven by a Fairchild CM0765. Turns out the VCC capacitor was bad and not even swollen, sowpped it for a 47uF 50V and presto.
Mar 15, 2014 | Polaroid TLX-01911C LCD TV
Polaroid model 3211tlxb sept. 2007.ec18 on the power board gets very hot and tv shuts down. i have replaced ec18 and q16 no help
Hi mrdink010,
I've checked my service manual collection but I don't have the copy on this model. I've also search it online and to my links of the service manual but I can't find one to view the schematic diagram of your unit.
The power supply gone to excessive heat due to over current flowing on its circuitry. This is caused by faulty parts like the transistor, IC's, diode, resistor, capacitors, transformer on its line that in most cases have a partial leak. This is hard to diagnose and needs the skills of an expert to determine which part gone bad. Usually this is not caused by one parts only but most of the time multiple parts gone to malfunction.
I would advice you to replaced the entire power supply board rather than troubleshoot this kind of symptoms because it will cost almost the same. Click this LINK( for the replacement. Double check the actual part no. of your board that is printed on the white sticker on the board itself before ordering online.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 29, 2011 | Polaroid Televison & Video
I need the inverter board for TLX-01911C polaroid, where can find it?
860-AB0-190DTLTCH shop
this is the same as the power supply board.
please leave feed back
Feb 18, 2011 | Polaroid TLX-01911C LCD TV
Polaroid tv goes immediately off after turning on
Ur tv power supply board is defective.That the board where the a/c power cord go into it.Replaced the power supply board,ur tv will have stable power and work again.Tries websites like, to buy a refurbish power supply board for the replacement.
May 27, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Where is the fuse in a 3701 LCD Polaroid TV/Monitor
In the Polaroid FLH-3701, the fuse is located on the power supply board, next to the AC power connector. It is a small black cylinder. It is labelled F1. Value is 5 amp, 250 volts.
A fuse does not blow for no reason. Most commonly a fuse will fail because of a short someplace on the board. I have this same TV. The fuse blew. The reason was transistor Q6 had shorted. There are two identical paired transistors on the output side. Q6 and Q7. They are both Infineon 11N60C3 MOSFET transistors. Check those for a short. There may be a burnt smell.
More commonly, this TV will fail because of bad capacitors on the power supply board.
May 08, 2010 | Polaroid FLM-3701 Television
Polaroid 4011-TLXB Power supply blew up IC3 I need the generic IC nr. It is an 8-pin dip. It is switch mode driver IC. Please help. Larry @ central tv
Replace power supply board from PTS. No parts available for PCB.
Generic part nr for IC3 is A6252M can't find one easily.
Feb 08, 2010 | Polaroid 4011-TLXB LCD TV
TV will not turn on. Went dead shortly after turning on can't get it to turn on again. Seems like it is not getting AC. Yes its plugged in and there is juice to the socket.
If the red ring in front of tv is not lit when it is plugged in it is probably the power pcb. I just ordered one from part # 860-AZO-IPOS150H FOR $45 plus shipping. installed today and everything is fine.
Apr 14, 2009 | Memorex MLT3221 32 in. LCD TV
Replacement of fuses on Philips 37PF7320A 37 in. HDTV-Ready LCD
Is the fuse in the plug okay?
If the fuses are not blowing when you are turning the tv on, this suggests that the PSU primary side is okay.
Since you have opened the TV up, I would suggest probing around with a multimeter however I do not want to let you harm yourself or the TV.
Look for any:
on the power supply
Aug 13, 2008 | Prima CV1311 TV
Polaroid FLM 2011
have a tech repair your tv the problem is in the power supply and related circuit.good luck.
Apr 12, 2007 | Polaroid FLM-2011 Television
Televison & Video Logo
247 people viewed this question
Top Televison & Video Experts
