Question about 1995-1997 Chevy Tahoe Ignition Starter Alarm Switch
1997 chevy tahoe performance
I just changed my spark plugs, my wires and even the rotor and my truck is running way better!! but how can i get more gas mileage and better performance from my truck
Try putting some of that fuel injector cleaner in your gas tank next time you fill up...and if you really want better mileage i have a 97 tahoe also and i put an airade cold air intake on it and its like night and day difference with mileage as long as you dont pound the petal...if you do decide to go fast it gives you like 10hp gain too and it'll take off a lot faster and sound sportier.
Posted on Nov 13, 2008
How do I tune up my 5.7 vortec v8 Chevy Tahoe engine
Depending on the year, the only option you have is to change the spark plugs and then consider changing cap and rotor and plug wires. Modern computer controlled cars have very few adjustments.
Feb 16, 2015 | Cars & Trucks
Mis when idling runs crapy plz help
Well you can pay to have it put on a scope OR start replacing parts.I would start with a tune-up Thats//// spark plugs/spark plug wires/distributor cap/ and rotor if applicable.Make sure the plugs have the right gap. They can tell you at the part store
Jun 09, 2011 | 1997 Chevrolet Tahoe
What part get replaced on a complete tune up on a 2000 chevy tahoe?
I would replace
1. spark plugs. Do not go cheap on the plugs use the proper AC Delco spark plug
2. cap and rotor
3. spark plug wires
4.fuel filter
and then i would have a fuel injection cleaning done . there is not a timing adjustment or air fuel adjustment this is all done by the PCM ( Powertrain Control Module )
Mar 04, 2011 | 2002 Chevrolet Tahoe
I have 1996 chevy tahoe 350 vortec i have spark , fuel, and new throtle position sensor still only crank over no start though
unplug your mass air flow sensor i havd the same problem with my 97 tahoe unplug it and it should run
Jan 06, 2011 | 1996 Chevrolet Tahoe
97 chevy 1500 4x4 4.3 wont start when wet have changed cap rotor plug wires plugs. veh has spark and fuel!
I have the same problem with my 1998 chevy 1/2 ton, if the weather is damp we have to plug it in, give it an hour and away it goes, have had it to a shop several times and still no solution. we have also changed cap, plugs plug wires
Aug 26, 2010 | 1995-1997 Chevy 1500 Truck Ignition...
2001 checy Tahoe wont stay running for more then 10 seconds?
hi i have a 1997 chevy tahoe that starts but won't stay running i have changed fuel pump, fuel filter,relay ,spark plugs, and just changed rotor and dis. cap ready need some help to figure this out please.
Jan 31, 2009 | 2001 Chevrolet Tahoe
1997 chevy tahoe misfiring 5 and7.
Check your FUEL INJECTOR HOUSING. The old style factory housing most likely has an internal crack. OLD style has the INJECTORS AT THE HOUSING with tubes running fuel to the engine. NEW housing has wires running to the INJECTORS AT THE ENGINE. If you have the OLD style then it is probably (99%) cracked. This will cause fuel to be sprayed into neighboring cylinders causing a firing problem. This crack IS NOT visible because it is internal. After exhausting all the regular solutions to your misfire with no success, you will probably try to replace the individual injector (like I did....cost approx. $300) and you will still have the misfire. To replace the entire housing with injectors will cost around $400. Good Luck.....on other forums, I've seen people replace anything and everything (including engines) and still had problems with the misfire.
If you're in Louisville KY and need a mechanic (not a parts replacer) for this, try Tony Johnson @ 3215 Fern Valley Rd. 502-387-0847
Dec 26, 2008 | 1995-1997 Chevy Tahoe Ignition Starter...
1995-1997 Chevy Tahoe Ignition Starter Alarm Switch Logo
218 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
