Question about Water Heaters
Boiler overheating baxi solo 2 40pf overheating been using this boiler over the summer for hot water tried it the other day for heating upstairs radiators got red hot downstairs luke warm pump makeing screeching noise now overheates within minutes on hot water and heating pump is still turning boiler and exit pipes red hot pump red hot tried bleeding rads and pump i have just fitted new radiator in bathroom and there was a lot of black sludge in old 1 this did new rad did get hot other day just swapt them over im thinking pump or system flushing out or both any ideas? oh the overheat light goes out after boiler cools down and then i can start again but then it overheats
  • 3 more comments
  • anth1 Oct 18, 2008
    sorry this is a gas fired boiler with storage tank i cleaned the pump out and fould the float valve on the heder tank sticking meaning insusiant flow of water in the system so replaced valve put in a system flush now working fine thanks
  • Anonymous Mar 16, 2014
    woke up this morning with no heating or hot water boiler showed code a04
  • Anonymous Mar 22, 2014
    Installed today, but when the boiler fills up and heats, after a minute or so the red warning light comes on, then it disperses hot water out the vent
  • Anonymous Mar 28, 2014
    Pump wouldn't start, changed pump motor and starts fine but running very hot.
    Problem Solver:
  • 7 Answers
The problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Posted on Oct 18, 2008
Have a Baxi solo boiler 340PF, have hot water but no heating, pilot light will not stay on. how do I fix it so I get heating please?
it might be the thermal coupler....it is a piece of wire that goes from the pilot to the thermostat. very inexpensive. .I am a 50 yr old woman, and I changed mine on my furnace twice..Home Depot or equivalent should be able to help. Google "thermal coupler"
Jan 22, 2013 | Water Heaters
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Baxi 80 overheating on hot water circuit
thermostat on the gas valve needs to be replaced,, which you will probly have to change the hole gas vale ,, check on the parts and labor and if it is over 6 years old wheigh the diffrence between it and a new unit good luck
Jun 10, 2009 | Water Heaters
Baxi solo 2 30pf will not fire up.. please help!
first off ensure water is getting to boiler, next, No pilot = pressure switch. On my baxi solo 40 pf pressure switch is replaced 8-10 times a year cures your problems,,,,,,,, momentarily , and have had all your other parts,but with no effect to speak of,.......sorry............ solution = [ change boiler ].sounds like gas pressure or lack of water to system or **** boiler like mine .........good luck.
May 15, 2009 | Water Heaters
Re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Mar 23, 2009 | Water Heaters
Overheating
you could have a flow problem due to sludge or scale in the boiler, it could be a pump problem as it may not be circulating enough water around the system. or it could be a faulty thermostat if it is not cutting out soon enough.
1st try turning the boiler stat down to its minimum, if it still over heats then it is probably the stat.
if you have a switch on your pump to increase the speed make sure it is on setting 3. if the pump is old then it may be time for a replacement.
Mar 01, 2009 | Water Heaters
Combi Boiler pressure gauge reading 0, and radiator half on!
The first thing you need to do is to put some more water into your heating system. This is usually done by allowing water from your (pressurised) domestic cold water supply to flow into the system: On older boilers, this is done with a connection (often made with a removable hose) on the pipework just outside the boiler. Newer boilers may have a built-in connection with some sort of removable link (sometimes looks like a plastic key).
Once you've got the boiler up to working pressure (typically about 1 bar - 15 psi), you should be able to bleed your upstairs radiator properly.
This may be all it takes, though the pressure excursions you're getting when you run the hot tap suggest there may be another problem. See what happens to the pressure as the boiler heats up and cools down. There really ought to be very little pressure difference between the two conditions. If you see significant changes, this usually means that the "pressure vessel" (or in hydraulic terms, system accumulaor) has lost its air charge.
The pressure vessel is a metal container inside the boiler, usually painted in red enamel. Somewhere near the top, you will find a schrader valve (like the one on a car tyre), and you can use this along with a tyre pump to replenish the air in the top of the vessel. This will reduce your pressure transients for a while, but you need to keep an eye on it. If the problem returns, you probably need to replace the pressure vessel (or clag another one into the plumbing alongside the boiler).
A.
Feb 03, 2009 | ACCO Brands Water Heaters
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Boiler shuts down repeatidly
i think you will find that instead of modulating as demand requires the boiler is overheating and then re operating after the safety thermostat has operated.
i wilud put some de scaler into the main heat exchanger circuit or add it to the radiators and let it circulate for a while.
also make sure the pump is operating properly to ensure proper water flow.
Nov 17, 2008 | Water Heaters
Water Heaters Logo
1,644 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
