No scan option in my printer
I have no scan option in my printer, the model is photosmart 3310 and i connect it throug usb
    Master:
  • 505 Answers
Open the HP application that is installed in your computer. You need to click on the scan option and it will work
Posted on Oct 08, 2008
UNABLE TO SCAN - "NO SCAN OPTIONS - REFER TO
Please click the below link for detailed step by step troubleshooting assistance.
Click here to get the solution
Regards
Riztech
Jan 09, 2011 | HP Photosmart 3310 Printer
I have a HP Photosmart 3310. I see a place for USB key in front. I need to print document from it. It says no information found on the usb key. Can you print from USB key? Thanks
The Port on the PS 3310 is called PictBridge. it is mostly used to connect Camera devices thru USB. It will not Read documents, you will have to try using an USB Adapter ( but not sure if that will work )
Jun 23, 2010 | HP Photosmart 3310 All-In-One InkJet...
How do I setup scan?
Kindly install the scanner software for printer..You just re install the driver software cd it will automatically install the missing components.
Which is contains the hp director software. Which shows the scanning option For normal scanning you can choose the option of Scanners and Cameras wizard in control panel. But it is better if you have software disk of printer because it contains more option.
Have a nice day and do not forget to rate please...!
Feb 17, 2010 | HP Photosmart 3310 Printer
"no scan options error" appeared
Try ths:
This happens mainly when you try to scan from the printer ;
Always try to scan from HP solution center but still here is the resolution:
Open Hp Solution center
Click on Settings
Click on scn settings
click on Scan to Setup
Select all the option available to updrade the Front panel menu list and click on ADD
Click on Update;
Restart the computer and the printer and try to scan.
It should resolve the issue.
Regards Soumajit
Jul 16, 2009 | HP Photosmart 3310 Printer
I can't scan!
Uninstall the driver and re- install again...good luck
Jul 07, 2009 | HP Photosmart 3310 Printer
Carriage Belt is worn and slipping 3310 HP. Where do I purchase?
The 3310 parts are not distributed anymore.
This is one of biggest sellers, and does not have any part listed for 3310:HP Photosmart Printer Parts.
The only option is grabbing spares from Ebay, like this one below:
eBay.com.sg: HP Photosmart Printer 3310 REPAIR PARTS
Mar 01, 2009 | HP Photosmart 3310 Printer
HP 3310 will NOT scan
This issue occurs when the digital imaging monitor is not running or the software is not installed properly.
This issue has nothing to do with the cartridges.
If the printer in connected in wireless, once check the communication between the computer and the printer and then disable the firewall and antivirus and try to scan again from the all-in-one. Also try to scan even from the HP solution center.
If the printer is connected via USB then try to scan from the HP solution center and then check the result, if the issue persists check whether the digital imaging monitor is running or not, then try to scan from scanners and camera wizard.
Sep 17, 2008 | HP Photosmart 3310 Printer
Scanning from wireless laptop
First of all, just use a USB cable, there not that expensive and it will be alot easier.
If you must use wireless. The laptop is trying to connect directly to the scanner or is there a print server somewhere, is there internet being used, is it connecting to another access point or wireless router?
Thes questions need clerifying.
Again. Wirless is supposed to be easy but we all know it isnt always true.
I would either Hardwire into the network or printer or connect direct to the scanner VIA USB.
May 31, 2008 | HP Photosmart 3310 Printer
Memory Card Error
If you can do so, go through the menu options and look for the ' restore to factory defaults option and do it.
Does it have memory ports to plug in or expand memory? if so, try turning off any optionsd to use expanded memory. Also, check the website, there maybe a simple soution available there.
Check for Firmware updates as well.
Oct 26, 2007 | HP Photosmart 3310 Printer
122 people viewed this question
jasbo
jasbo
