Question about Hotpoint FFM70 Bottom Freezer Refrigerator
Hotpoint FFM70 not cool!!
Hello all, I have a Hotpoint FFM70 not cooling fridge or freezer.
The defrost and high temp alert lamps are on.
The compressor is on and fluid noise apparent,and the valve(in white box)beside compressor clicks in.The internal fan comes on at switch on and runs for a few seconds.I have measured resistance of 4? temp sensors.Are 2 of the sensors built into the cabinet in the fridge section?I see the 2 in freezer(red and green)Has anybody got a block diagram for p.c.b. or where can I get pcb. Any help appreciated.
Peter Hardy
Aberdeenshire.
5 Suggested Answers
  • 17 Answers
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Posted on Dec 10, 2007
  • 833 Answers
SOURCE: Hotpoint Ice diamond fridge freezer both green & red lights on.?
bulmer...it takes about two days to fully defrost these units unless you take the freezer section cover off and use a heat source. If you do...be sure to protect yourself against water and electricity mixing....not healthy. See below for another note.
clean the condenser coils below the unit.
check for the amount of gas in the unit. It must be off for half an hour. Remove the back fiber panel. The big thing is the compressor. Clean off the largest pipe coming out of it. Plug the unit in...watch out for the fan! The pipe should frost up and then clear off or stay wet after about 5 minutes. It should not be frosty. If it is, you need refrigerant.
Note: If you do remove the inside freezer panel and defrost, you can see how much refrigerant you have in your unit. Start the unit. Wait 5 minutes and observe the coils. They should be evenly frosted end to end. If approximately so, you're good. If not, you're low on gas.
Posted on Dec 18, 2007
SOURCE: relay clicking, not cooling either side
asdsad asd
Posted on Mar 22, 2008
SOURCE: hotpoint ultima fridge freezer
It's just simple.Keep the refrigerator open for few days with power on.After when the electricity bill comes,eveerything will be cooled.
Posted on May 28, 2008
mgprice
  • 744 Answers
SOURCE: fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Posted on Jun 23, 2009
Hotpoint quadrio fridge isnt cooling but freezer is can i start its defrost cycle manually?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 10, 2011 | Hotpoint Refrigerators
Freezer temp is fine at -22 but fridge is to warm at +18
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 15, 2011 | Hotpoint Refrigerators
Meant to be frost free but there is a build up in the freezer
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 28, 2010 | Hotpoint FFM70 Bottom Freezer Refrigerator
The freezer was showing high temperature, then defrosted overnight...why
Defrost timer/control stuck....
heatman101
Oct 19, 2010 | Hotpoint FFA60 Bottom Freezer Refrigerator
FRESH FOOD SECTION OF SIDE BY SIDE FRIDGE NOT COOLING ENOUGH. TEMP SET @ 9. FREEZER SECTION WORKING FINE
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 20, 2010 | Hotpoint HSS25GFP Side by Side...
I have a hotpoint RLA80 the back wall on the top half of the fridge keeps freezing although the temp is on 1
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 09, 2010 | Hotpoint RLA80 Refrigerator
Freezer has defrosted on its own. Red freezer high temp light will not go off.
Door has accidentally been left open. Have missed a proper defrost and ice has built up internally. Switch off and do a 12 hour defrost. then switch on again. (Thats where i would start.).Because fan is stuck in the ice, it cant blow cold air to the sensor. Sensor detects this and shows red error light.
Nov 13, 2009 | Hotpoint FFM70 Bottom Freezer Refrigerator
Fridge part of fridge freezer not cooling
heatman101
Aug 16, 2008 | Hotpoint FFM90 Bottom Freezer Refrigerator
Fridge Smell
i have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Aug 02, 2007 | Hotpoint FFM70 Bottom Freezer Refrigerator
Hotpoint FFM70 Bottom Freezer Refrigerator Logo
66 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
