Question about Panasonic KX-TA308 Phone
OGM (Outgoing Message) setting for KX-TA616
Hai guys I want to know whether its possible to programme the OGM for KX-TA616 through PC instead of the voice through PT (Propreitary Telephone).
  • sicarsoft Nov 13, 2008
    I do not know how to setting OMG on panasonic KX-TA616
  • 4 Answers
Yes u can
Posted on Feb 26, 2009
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    I NEED A MANUAL OF PANASONIC KX-TA616
    Click here to view the Operating Instructions for your KX-TA616: http://www.norcom-it.com/ATC%20KX-TA308%20KX-TA616.pdf
    Feb 07, 2011 | Cell Phones
    How do i change outgoing answer phone message
    Solution for Fax1360, if this does not work please let me know as this process should be the same.
    Recording an outgoing message (OGM) on an external TAD 7
    Timing is important in recording this message. The message sets up the ways to handle both manual and automatic fax reception.
    a Record 5 seconds of silence at the beginning of your message. (This allows your machine time to listen for the fax CNG tones of automatic transmissions before they stop.)
    b Limit your speaking to 20 seconds.
    c End your 20-second message by giving your Fax Receive Code for people sending manual faxes. For example: 'After the beep, leave a message or send a fax by pressing *5 1 and Start.'
    Recommendation: recommend beginning your OGM with an initial 5-second silence because the machine cannot hear fax tones over a resonant or loud voice. You may try omitting this pause, but if your machine has trouble receiving, then you must rerecord the OGM to include it.
    Christy
    Sep 26, 2010 | Brother Inkjet Fax Machine Fax1460 Plain...
    Can i get a ring w/o the voice id on my answering machine?
    You can have no message, standard outgoing message, or your own recorded message, as you choose. You need to use the function to change the OGM (out going message). Instructions are in the manual.
    If you need detailed instuctions I will pleased to supply them.
    Feb 25, 2010 | Panasonic KX-TG1033S Cordless Phone
    When testing the outgoing message the volume seems
    http://www2.bt.com/static/i/media/pdf/response_75_userguide.pdf
    If you click on the above , go to p.11,12 on setting the volume .
    I agree with everything you say the only thing I can add is you may not be setting the volume correctly see note on p12.
    Hope i`ve helped.
    Dec 10, 2009 | British Telecom Response 75 Digital...
    Bought second hand i how do I change the answer phone message to mine?
    Hello. I have located the owner manual for your phone and I will provide the link at the end of this response. If all you wish to do is change the outgoing message to your own, do the following:
    The OGM is your announcement to the caller and may be up to 2 minute in length. If
    you choose not to record your own OGM, the caller will hear a prerecorded OGM. Use
    your OGM to advise the caller to begin talking after a beep is heard. For example:
    “Hello, we are unable to take your call right now, please leave a message after the beep,
    and we’ll return your call as soon as possible. Thank you for calling.”
    Recording your OGM
    1. Press .
    2. The total number of (new) recorded ICM’s will now be announced.
    3. Press 8 to stop playback.
    4. Press 4 5.
    5. Record your OGM.
    6. Press 8 to stop recording.
    7. Your OGM will be repeated after a few seconds. Repeat the same procedure if
    you wish to change the OGM. Any old OGM will automatically be erased when
    a new one is recorded.
    Here is the link I promised: http://www.doro.com/global/businessunit/dorocare/support/imagesdownloads
    please rate my answer. thanks. Regards, Joe
    Dec 07, 2009 | Doro 830R Cordless Phone
    Instructions for model 1188
    Hi Diana - To record your outgoing message, hold down your ogm button ( outgoing message) for two seconds and it will ask you to record a message. To play back your message, just push the same button and it will play your message. If you don't like it just do it again. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks and have a good day.
    Jeff
    Jun 11, 2008 | BellSouth Digital Answering System 2006C...
    No user manual
    To record a new OGM,
    Press "menu" on the base unit, then "up" once to record OGM 1 or twice to record OGM 2.
    Press "OK" The existing OGM will begin to play. Whilst this is playing press and hold "MEMO"
    Record your message, speaking close to the base unit. Press "stop" (square) when finished.
    If you decided you don't like your message then, repeat the process above but when it tells you to record your own message press "stop" (Square) and the default will be reset.
    May 20, 2008 | Cable_and_wireless CWD4901 Cordless...
    How to install the emergency numbers
    Programme Code 309, code no. (1-5), emergency no., store,end or next.
    Feb 23, 2008 | Panasonic KX-TA308 Phone
    Panasonic KX-TA308 Phone Logo
    766 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
