Laptop I found didn't charge battery, and only would work with a battery. so I found a burnt mosfet 4407 chip and swapped it out. Now board will power up off AC, and not battery. No LED showing battery charging. Before charging LED was in error color. Did I solider it wrong? Do I need another chip changed too?
This unit had a RED CHARGE error. Replaced PQ38 solved the problem.
If you get an error on the charge circuit after replacing the PQ38 you should also replace PQ38 because it too may be blown. Make sure Pin 1 where the dots. Also check the MOSFET on the other side of the COIL too.
I've got power problem and burnt PQ38 4407 MOSFET chip. Mine is trying to start from battery but shutts off 5 sec later (with burnt chip)
Looks like PQ37 4411 has to be replaced. Looks like it's also N channel MOSFET
I'm trying to find a source for it.
Let me know if you can find one
4407 is P-channel, 4411 looks like is a N-channel
Just found specs for one by Vishay full name Si4411DY
http://www.datasheetcatalog.com/datashee...
Yo tambien tenia el mismo problema 4407 - BE5K4B MOSFET chip quemado y no encontraba una refacion. asi que agarre otra de mis laptops dañadas y busque un MOSFET parecido y encontre este: 4411 -BE5B2X Mosfet chip y lo cambie y funciono perfecto, volvio a encender la laptop. la tengo trabajando en este momento. yo creo q existen compatibilidades, si tienen uno parecido pueden probar y ver si queda, saludos. Elulilzc, mich. mex
If you have any problem with ur lcd and laptop then u can ask me by my email [email protected] and write laptop on ur subject ... (i recv too many junkies thts y)
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
did you get your computer fixed. My gateway mx6030 with same problem and had power jack broken. Got new adapter and jack fixed then battery would not charge and had red light. once bat died will not work at all. I could use some pointers on how to fix the item you trying -- pq38 4407 mosfet chip
I got my chip off another motherboard, dead boards are cheap on ebay.
Where can i buy the 4411 and 4407 8 pin chip mentioned in kegtappers fixya???
