Konica minolta bizhub 501
When in the copy screen it won't let me copy from the platen glass. Also the adf even in simplex will run as if duplex was activated but still only copies simplex. But when I scan to desktop or email it scans from the platen just fine.The firmware is only 2 weeks old andthe copier is 3 weeks old. Any ideas?
  • 1,326 Answers
The problem is that the default setting ing the copier has been set to all ways do two sided. Ckeck your user settings just go through all the screen and look for orginal doc. setting, it should be set for simplex or one sided. If it is not there you may have to call your service rep. and have them change the setting in service mode. Some of the older and newer copiers have a setting in service mode. It is most like in your user settings. Someone was Panic Botton Pushing & will not fess up....Good Luck
Posted on Oct 09, 2008
How to set up duplex printing
Select on the display simplex/duplex ,select 2 sided to 2 sided.
Jul 17, 2014 | Konica Minolta Bizhub 283 Copier / Printer...
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
Our office's Konica Minolta Bizhub C360 is always
This model has a tendency to fold corners. Have the tech. check the input guide to the fuser unit and also to check the door on the right hand side above the bypass tray. Its a fairly common issue. Also have them search konica-minolta's website for other techs having this problem. Good Luck !
Aug 11, 2011 | Konica Minolta Office Equipment & Supplies
Instructions for copying double sided
at the main menu of the panel, select "SIMPLEX DUPLEX" option,which is at the right side of the lcd screen, now in "SIMPLEX DUPLEX" option select "DOUBLE SIDED" original to "double sided" copy option and then press the start button...............
Mar 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
I get a black line through the copy on the Konica Minolta Bizhub 160. How do I fix it?
if you print a report and there is no line its the adf **** glass so clean it with a rag and glass cleaner
Feb 24, 2010 | Konica Minolta bizhub 161f All-In-One...
I have a bizhub 750 that I cant keep the scanner from comming out of adjustment. It shifts down and away from the leading edge
Did you try it from the platen glass? make sure it's the just the ADF and not the optics. Try it from different trays.
Oct 01, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica bizhub C351 copier with BLACK area in center of the copy
u have to run the setup for machine if u like i can send u the step guide how to setup the machine
Aug 05, 2009 | Konica Minolta bizhub C351 All-In-One...
The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Apr 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica bizhub 250
on the left hand side of the platen glass there is a **** glass just clean that with alcohol or wet rag.
HH
Feb 14, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub C650 (Minolta printer, copier)
setup for adf if is new machine u have the setup **** for adf
the setup **** (A4 page) with black border
Oct 13, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
597 people viewed this question
jasbo
jasbo
