Question about Electrolux Vacuums
Hello. We have an electrolux super J canister vaccum. Its fan is broken. How can I remove the fan from the motor axel ?Where can I get a new fan ? Looking forward to your reply, Robert
Japanese AV ****, Asian Femdom, Slave Domination & Bdsm http://www.avbondage.com
Posted on Apr 01, 2009
  • 3 Answers
Hi Robert, good luck with getting a new fan! I cant even get a new hose for mine! Its like a secret society this parts thing.... my poor vac cleaner is duct taped up like a **** fettish gone wrong and everytime I vaccum I am worried the tape will blow off and take my eye out! Maybe your best option and fastest solution is to buy a gerbal or ferret, make a little cage, attach to the fan and put them in it so they run around and gets the fan spinning ! Cause electrolux is **** hopeless at helping.....ALSO Feed ferret/gerbal now and then though.... food for thought.... Hope this helps,,,LOL Rachael
Posted on Oct 08, 2008
When vaccum is in use it shuts off after vaccuming for a minute .
Look to see if the main air filter is clean (some can be washed and others have to be replaced) it will if blocked up trip a thermal cutoff to protect the motor in the unit.
Dec 22, 2012 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Canister starts, but vacuum does not start
Take the hose unpluged see vaccum is working or not.
IF NOT.
  1. BAG FULL
  2. HOSE CLOGGED
  3. BELT BROKEN/LOOSEN
Dec 28, 2009 | Electrolux Guardian Bagged Canister Vacuum
Sparks in the el. motor of Electrolux Canister.
check the wiring it might have gone bad
Jul 07, 2009 | Vacuums
Switch is not working I want to change it but I cannot access it.
THE LONG PLASTIC STRIPS DOWN THE SIDES HAS A TRACK IN IT. YOU MUST OPEN THE DOOR AND PULL (SLIDING) THE STRIPS OFF THE TRACK LONG WAYS AND THE TOP HALF WILL SEPERATE FROM THE BOTTOM HALF. BEWARE THE WIRING INSIDE IS JUST LONG ENOUGH AND CAN DISCONNECT EASY. IM PRETTY SURE YOU HAVE TO DO THIS TO GET TO THE BOARD INSIDE.
Mar 04, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Vacum won't ****
Do you have good suction right out of the canister without the hose attached? If so, AND your hose isn't plugged, you must have a pretty good sized hole somewhere in the hose. If you don't have suction at the canister, pull the filter cover off the top-back of the machine and remove the filter. This is where all of the air that the machine pulls in is exhausted. If something is plugged here, it will greatly reduce your suction. If you still haven't found the problem, you could have a problem with the fan assembly on the motor. But usually this is accompanied by some noise from the motor, but not always. Good Luck!!
Jan 03, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Vacuums Logo
142 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
