Question about Alpine Car Audio & Video
My alpine TDM-7534E head unit has intermittent power, wont turn on at power button although backlight is on
  • 277 Answers
SOURCE: Wiring on tape deck Alpine tdm-7543
hi there is a manual in the model page click on it page 2 there is a description how to connect the unit good luck
Posted on Mar 21, 2006
tech48
  • 624 Answers
SOURCE: I have an Alpine CDA-9815
It sounds like the sub woofer amplifier is pulling down the voltage level in the truck when it starts to get really loud. It may be the voltage regulator which is probably part of the alternator, or the alternator is not capable of supplying the needed current for the amplifier. If the voltage level drops below a certain level, the radio will see it as if the battery is disconnected. It requires a voltage level of around at least 10 volts to stay turned on. When an amplifier is playing loud, it draws a lot of current. If the current supply does not increase, it lowers the voltage level to compensate and get the current it needs to play at the level the head unit is pushing it to. As the voltage level goes down, the current increases when the voltage is dropping due to increased demand. You could check this with a voltage meter and monitor the level right at the battery and have somebody turn the volume up on the head unit slowly as you monitor the voltage level. The normal operating voltage of a car while the engine is running is about 14.4 volts. It should not drop much at all, no matter how loud the amplifier is playing. if it does drop, you have a problem with the trucks regulator or alternator.
I hope this helps, if you need more assistance let me know.
Dave
Posted on Jul 08, 2008
JustJeeps
  • 74 Answers
SOURCE: alpine CDA 7843E head unit
if this unit has a motorized face the ribbon cable is bad and will need to be replaced
Posted on Nov 28, 2008
SOURCE: removing TDM-7545 unit from dash
i cant seem to remove the unit from the dash ? thanks zac
Posted on Jan 17, 2009
hack124x768
  • 33 Answers
SOURCE: connect alpine 7874 to alpine powered sub
You need to run the RCA cables from the head unit to the sub for the audio signal, and possibly a turn on wire (the blue one on the back of the head unit), unless the sub has an automatic power feature.
The sub also needs power and ground wires attached, but those do not connect to the head unit. Power should be run directly from the battery with an inline fuse, and ground should go to the nearest good ground point (Trunk latch, seat bolt, etc).
Posted on Mar 28, 2009
Why is it that when i turn on the stereo the backlight is too dim i cannot see what radio station that i tuned in.
You probably have burned out bulb(s) behind the display. Unless you are good at desoldering and soldering, it is recommended you have them replaced by a professional.
Aug 18, 2011 | Alpine TDM-7561 Cassette Player
Trying to set the radio stations on Alpine stereo
The radio either does not have the yellow power wire connected(constant 12v) or the wire is connected to a switched source and when the key is turned off the radio has no backup power. You will need to pull the radio out and verify the yellow wire is not connected to switched voltage and connected to constant power. It is also possible that they have the red and yellow wires mixed up. Remember yellow constant power and red is switched power(with ignition key). And also disconnect your negative battery cable when working on the electrical system of your vehicle...you may short something out and damage your vehicle's electrical system or head unit.
Sep 19, 2009 | Alpine TDM-7543
Connect alpine 7874 to alpine powered sub
Mar 20, 2009 | Alpine CDM-7874 CD Player
Removing my alpine 7510T
The trim ring around the radio must be removed, then slide alpine head unit removal heys in each side.
Dec 26, 2008 | Alpine TDM-7561 Cassette Player
Removing TDM-7545 unit from dash
Nov 26, 2008 | Alpine TDM-7545
Alpine CDA 7843E head unit
Nov 25, 2008 | Alpine CDE-9852 CD Player
Inconsistant Switching of Alpine MRA-F350 Amp
try and unplug the audiovox unit and check if problems still exist. and what swithes on what unit are you talking about? this kind of sounds like a wiring problem.
Nov 21, 2008 | Alpine MRA-F350 Car Audio Amplifier
How to adjust the clock?
According to the manual you hold the clock button in for a least 3 seconds. The time indication will blink for about 5 seconds.
Press the CT button while time indication is blinking to set seconds to "0".
Press H button to adjust hours and the M button to adjust minutes.
The time indication will stop blinking, 5 seconds after adjusting the minutes.
Oct 22, 2007 | Alpine TDM-7545
No backlight on a cdm-7834
The only possible installation problem could be the illumination wire on the head unit. If this is hooked to a 12 lead it would dim the backlight. Try disconnecting the orange wire if it has one(I'm not sure if the 7834 had a dimmer lead). If that doesn't fix it the head unit will have to be serviced.
Sep 03, 2007 | Alpine CDM-7834
Mar 20, 2006 | Alpine TDM-7543
Car Audio & Video Logo
117 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
