This model Canon MX700 cannot scan slides. A flat bed scanner that can scan slides and negatives has a light scource that shines through the slide and negative fand is detected by the scanner sensor. I suggest you purchase a slide scanner, it will be cheaper that getting a new flat bed scanner with slide capability.
Brand new cartridge or refilled one? If refilled cartridge, just wait for 30 minutes after refilling and use good quality of ink. It's caused by bad ink flow. While ink spray (bubbling) form head, ink at ink tank not flow to head.
I just replaced my MP810 printer head. Procedure: open printer - remove ink cartridges - Pick up arm located on right side of cartridge holder- remove printer head by picking up by the cartridge slots. Place new printer head in holder - replace printer cartridges - press arm down and your done....However, the error message stays on and reset procedure doesn't remove it. Canon tech support said their solution (because of distance from canon support) is to replace MP810 with comparable printer, which came to $299 with 15% discount and free shipping. My solution, I’m checking out other printers.
Follow these steps: start off removing the ink tank holder (held in place by the grey lever) and cleaning it with an alcohol solution and paper towel. When the ink tanks are not in use they slide to the right side and rest on a pad that collects excess ink. Mine was loaded up and gel like so I cleaned it as well. With the ink tank removed place your MP600 upside down on the table with a towel underneath to protect the lid, then gave it a few good hits on either side of the lower paper tray.
The printer not recognize the print head at the moment.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Clean the contacts using cotton and some alcohol.Then put all back and try again.If this not help you need to replace the print head.It's part number is QY6-0070
Did you look under the white foam protective cover on the underside of the lid, the one that looks like its sole purpose is to press documents flat against the glass? That's where the film guides are stored, believe it or not. See page 65 (of the file, page 63 as numbered on the pages themselves) of the manual here:
The setting should go something like this-
Colour reflective
Black and white reflective
Colour Negative.
Colour Transparency.
Black and white negative.
Some scanners automatically sense and switch to what is loaded - others need setting up.
So check thoroughly all the settings in conjunction with the manual[A full manual in PDF format is usually on the software disk.
Then come back
