Question about Belkin Computers & Internet
How do I secure the wireless router with a pass word
  • mrbrown0603
    mrbrown0603 May 11, 2010
    Can you give me the model and manufacturer of your router?
  • 781 Answers
In esence what you do is:
1. go into configuration page (check your router manual or documentation)
2. go into wireless
3. change the defaul SSID (that is the network name or Access point name or your router name)
4. make a note of the SSID you have defined (you needed when setting up your client computer)
5. if you want you can stop broadcasting the SSID (recommeded.. that's why you noted that on previous step
4. set up your encription method (wep, wpa, wpa2).. wp2 is recommeded or wpa if wpa2 is not avaliable or wep if that's the only option as it is better than nothing.
5. configure and note you passphrase/key (you need this to configure your client computer)
this is a good article that will give you some fundaments
and this is a walk through securing a router with an example for a popular linksys router:
and this is a wlak through securing a router with an example for a polar d-link router:
other routers may be different but in esence is the same.
let us know how it went!! good luck!!
Posted on Oct 08, 2008
How to secure my pass word
Take a look on these point for password security :
Change your Default Password , Set up a security key for your wireless router, Try to priorities WPA than WEP for more protection, Disable your remote administration setting and Enable your router Firewall and MAC Filter. Try Security set-up and Router Support for more help.
May 29, 2014 | Belkin Basic Wireless Router
Wpa2 pass phrase
You'll have to connect to the router through a wire, log into ints web-based configuration page ( by default) and see the wireless security from there in the "Wireless Security" section.
good luck,
Dec 28, 2011 | Linksys WRT150N Wireless Router
How do I secure wireless router ... currently open .. I'm attempting to restrict piggy-backing for security reason.
Which router do you have.You have to first open the administration page of the router. Better to do it with a laptop or computer attached to the router physically with a cable as the wireless configuration might corrupt data as the router will disconnect when you change the security setting. Default ip for router's are , you can see your manual for the correct address and even the username and password would be provided in the documentation. Once inside the administration select Wireless and then Wireless Security may change according to manufacturer. Here you have many choices like WEP or WPA, i think for home networks WPA is a better choice as WEP is easier to break. Select TKIP under that, then you should enter a pass phrase. This is going to be like your password.It has to be minimum 11 characters long.Save settings and check if the pass phrase is asked for when connecting to your router. If it does you have secured your wireless connection.
Jan 17, 2011 | Computers & Internet
What if i want to secure it. do i need the cd?
Im not sure what you are saying is your problem.
To secure your wireless network you first need to log into your routers configuration settings to do that in your address bar of your browser type enable either WEP or WPA security and tell it what security key or pass phrase to use.
Then on your computer when you try to connect to your wireless routers signal it will ask you to put in the security key or pass phrase you selected and thats that. You are secure.
Sep 30, 2010 | D-Link DIR-615 Wireless Router
What is wpa pass phrase while setting wireless printer
WPA with a Pre-Shared Key (PSK), also known as personal. PSK is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
WPA pass phrase is a password for the wireless network to make it secured. You can obtain the WPA pass phrase when you access your router. Check the manual of your router for the address, username and password of your router. Go to wireless settings, you will see ther the SSID or Network Name, Network Key or the Pass Phrase and Authentication (WPA/WPA2/WEP). You can personalize the SSID,Network Key and Authentication. Remeber that for you to connect wirelessly the Authentication and Network Key on the router should match the Network Key and Authentication of the Printer or Computer.
Thanks for using Fixya,
Aug 06, 2010 | Computers & Internet
My daughter set the router up and then moved out with the setup disc and she doesn't remember the pass code. My signal is not secure and my neighbors all use it. How can I make it secure? It always wants...
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Aug 04, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Pass pharse
Log on to the router, go to wireless security.
I would choose WPA ( you choose the password)
WEP is much weaker, try not to use WEP ( It gives you a pass phrase/key)
Jul 22, 2010 | Linksys WRT160N Wireless Router
Need a security pass for wireless router
HI Friend
please follow the steps
1. Click the start menu on the desktop after connecting your desktop or laptop to your router.
2. Click RUN and type cmd and hit enter
3. In the black box type ipconfig/all and hiot enter
4. Note down the default gateway and exit from the black box
5. Open internet explorer and type the default gateway number and hit enter
6. If you have changed the default password and username then enter that or else leave blank the username and in password type admin and hit enter
7. Now in the setup page click wireless and under wireless click wireless security
8. Now select whichever security option you need and enter the passphrase and save settings
9. Turn off the router for 30 seconds.
Now your network is secured.
Dec 27, 2009 | Linksys Wireless-G Broadband Router
How do I put security on my Belkin 54g router
You set your security by enabling WEP.
When you get in the interface to configure WEP, set a pass phrase. Write down the 3 numeric keys it generates. Then connect to the wireless using your laptop, etc. When it asks for your passkey, do not enter the pass-phrase; enter one of the three keys that were generated by the router. That's the biggest mistake people make when trying to get wireless to work.
Oct 06, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Motorola WR850G wireless router - what is a security key or pass phrase that I am being asked to provide? Verizon has no clue. Thank you. Russ
Check this manual and look at the installation part. It will tell you how to reach to your Wireless Security page. That is where you would find your key or pass phrase.
May 12, 2009 | Arris Wireless G Broadband Router (wr850g)
Computers & Internet Logo
161 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
