Question about AudioBahn AEQ6 5-Band Car Equalizer
Pyramid eq 906vl no remote lead
I am hooking up my new pyramid eq and it only has a red batt. wire and a ground wire. NO REMOTE turn off wire! Can i wire thid fused red wire to the head units remote power lead?
    New Friend:
  • 28 Answers
That unit use just two power wire you have to connect it to an accessory power source that turn of by your car radio
Posted on Dec 04, 2008
How do i install a pyramid pb880 4 channel mosfet amplifier?
run rca cables and a remote wire from your radio to the amp,run a power wire from your battery and attatch a ground to the car ,then hook up the wires and cables to there respective places.
Jan 15, 2011 | Pyramid Car Audio & Video
I need to no how the wires get hooked up
bottom right( red wire 12 v dc on/off ignition switch)
2. top right( blue wire with inline fuse to amplifires)
3. bottom left( black wire ground)
4. top left( blue wire stereo2_bing.gif remote wire)
May 09, 2010 | Pioneer EQ-6500 9-Band Car Equalizer
I have a 300 watt amp, but i just bought 12 gauge wire why wont it allow sound to come from my 12'' sub
There is no reason even if the wire was to small it would still allow ssound.make sure you have good connections.
Nov 08, 2009 | Pyramid 906 300 Watts (peak) 10 Band...
Wiring ID- Pyramid SE808ECHO 200watt amplifier/grapic equalizer
THE UNIT YOU ARE USE HAVE SPEAKER IN AND OUT WIRES LOOK AT THE INSTRUCTION AT THE BACK OF THE EQ AND DECIDE HOW YOU WANNA USE THE EQ
Aug 01, 2009 | Car Audio & Video
Equalizer doesn't turn on
hookup the remote wire of your EQ to that of the HU or just simply connect it to the positive line but it would make your EQ powered ON all the time. That remote wire of your EQ is to get a trigger signal from the HU so that it will turn the EQ "on".
Apr 20, 2009 | Power Acoustik PWM-19 4-Band Car Equalizer
Color code for speaker out on a JVC KS R140 car casette player
White - left front
Grey - right front
Green - left rear
Purple - right rear
Yellow - memory power
Blue - remote power (power ant, amp or eq power)
Mar 20, 2009 | JVC KS-F150 Cassette Player
How do I wire an car stereo to an equalizer
from what you have explain you have a no experience to do so get your system installed by an audio installer safety come first and u have no clue for your safety seek a qualified person to do it
Mar 13, 2009 | Car Audio & Video
Kenwood kac-5201 amp
12 VOLT FROM THE BATTERY SOURCE GOES TO 12VOLT BATT CONNECTION.12 VOLT GROUND RETURN MUST BE FIXED TO THE FRAME OF THE VEHICLE.SOME VEHICLES HAVE FACTORY GROUNDS UP HIGH ON THE SIDES OF MOST VEHICLES, U CAN USE THIS GROUND LOCATION. IF CONNECT REMOTE WIRE FROM THE RADIOS REMOTE TURN ON LEAD WHICH IS A BLUE/WHITE WIRE OR A STANDARD BLUE IF ITS JUST ONE BLUE WIRE. CONNECT THIS LEAD TO THE REMOTE TURN ON CONNECTION ON THE AMP , SOME KENWOODS HAVE TWO ,INPUT AND OUTPUT LEADS.U ALSO NEED A TEST LIGHT, OR U CAN USE A SPEAKER TO TEST FOR POWER AT UR CONNECTION.IF U USE A TEST LIGHT , CLAMP THE END U WOULD GROUND TO THE VEHICLE, TO THE AMPS GROUND, THEN TOUCH THE PROBE END OF THE TEST LIGHT TO UR WIRED CONNECTION TO VERIFY U HAVE POWER AND GROUND TO YOUR CONNECTION.IF TEST LIGHT DOESN'T WORK ,CHECK UR FUSE AND REMOTE TURN OR LEADS.
Sep 02, 2008 | Kenwood KAC-5201 Car Audio Amplifier
INFO:EQ
Sens is ussually a term for the more common "remote
" wire. You will need to look at diagram to be sure but Im about 99% positive that in your case the sens wire is the input wire for a switched ingnition, especially since you say it is located next to theGND and BATT wires. You will need to connect the SENS wire to 12v hot, similar to the BATT wire but this wire will need to be switchable, meaning it can be turned off and on, say when you turn your key on and off, or when you turn your radio on and off. For example, the remote wire output from the back of an aftermarket cd player, ussually blue with a white stripe or just blue, or the ignition wire of your aftermarket radio, ussually red, or the ignition wire of your factory radio, or any 12v switched fuse in your fuse box. They will all work. In a worse case senario, if you have trouble locating a true ignition wire, there is a short cut. If the EQ has an actual power button that you can turn on and off, you can make this short cut by wiring the SENS wire to the 12v hot BATT wire. Then you can manually turn the eq on and off with the power button. Just remember if you wire it up this way, and forget to turn it off when the vehicle is not running, after about 24 hours or so, the battery may be drained somewhat, and you'll have trouble starting your vehicle. This is definately your last option.
The BATT wire needs to go to the hot in the BATT or the memory ( yellow) from the aftermarket CD player. The GND needs to be connected to anything metal in the car that is connected to GROUND, for example the frame work of the dash board that is metal, or the ground wire from your aftermarket radio ( black).
The rca input will be the RCA;s coming from your cd player.
the rca output will go to your amplifier.
Placement is completely up to you.
If it came with brakets, placing it flat against the underside of the dash board should work. But it could litterally be anywhere, and any where where it will suit your needs. Glove box works well too, so does in side the arm rest console, if you can get you wire to reach good luck.
Jan 29, 2008 | AudioBahn AEQ6 5-Band Car Equalizer
AudioBahn AEQ6 5-Band Car Equalizer Logo
205 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
