I have an old HP computer and it wont boot up from the cd rom what can i do? do i need a floppy disk? where can i get it?
1) Has it ever booted from CD-ROM? If it has, go to step #2. If not, go to step #3
2) If nothing has changed (BIOS, hardware additions, etc), it's a bad CD drive
3) Check your BIOS "boot order" section. It varies from motherboard to motherboard, but all BIOS's have some type of boot sequence that you can configure. It's possible that yours may be FDD, HDD, CDROM (in that order), which means that as long as you have a working Windows computer, it never needs to boot to CD. Try changing the order and that should fix you up :)
Hope this helps :)
Scott
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
hope this helps
Computer is booting from a non-bootable source
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette
or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a
memory stick is in a card reader and the computer is attempting to boot from it.
If you have any card reader or flash reader make sure that no memory
stick is inside the computer. Additionally disconnect all USB drives, cameras,
ipods, iphones, etc. from the computer.
If you are attempting to boot
from a floppy diskette and are receiving this error message it is
likely that the diskette does not have all the necessary files
or is corrupt.
If you are attempting to install
Windows XP or Windows 2000 and are receiving this error message as the
computer is booting verify that your computer BIOS
has the proper boot settings. For example, if you are attempting to run
the install from the CD-ROM make sure the CD-ROM is the first boot
device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note:
If you are not receiving the above message and your BIOS boot options
are set properly it's also possible that your CD-ROM drive may not be
booting from the CD-ROM properly. Verify the jumpers are set properly on
the CD-ROM drive.
Computer hard disk drive is not properly setup in BIOS
Verify that your computer hard disk drive is properly setup in the
CMOS setup. Improper settings can cause this
error.
Corrupt NTLDR
or NTDETECT.COM file
its an old computer from a friend what can i do to make the cd rom boot up a cd in start up
