Question about Maytag 7.0 Cu. Ft. Electric Dryer
Simpson Sirocco 350 Dryer not heating
My electric front load dryer looks like is working ok, but actually is not drying the clothes, but when you check the area next to the door is really hot!!!! what could be the reason
Thanks
  • lyndonald Dec 09, 2008
    Mine is overheating to the point where it turns itself off after a few mins. I pressed the Reset button & it worked for a few mins, then went off again. I checked the vents but I think it must need a new thermostat. Can we buy one & replace it ourselves or do we need a professional to repair it? Either way, any idea of how much? Many thanks - Lyn
  • HAL2100 Mar 21, 2009
    My Simpson Sirocco 350 has exactly the same problem
There is an oval cover on the back of the dryer. Remove this cover and you will probably find a broken fan belt. A replacement costs about $20 Aus.
NOTE: If you have been using the dryer for a while in this condition there will certainly be moisture inside the dryer. Replace the belt and leave the dryer for a few days to dry itself out (motor and electricals) before firing it up.
Posted on Feb 25, 2009
    Problem Solver:
  • 3 Answers
My Simpson sirocco had the same symptoms. the problem was not a broken fan belt, but the fan belt had jumped off the pulleys.
Another symptom I discovered afterwards, is that there is no air coming out the vent on the back!
Solution: Take the black, oblong plastic cover off the back of the dryer using two screws, one at one end and the second in the middle. The cover is hooked under a clip at the other end. It slides out easily. You should then see two pulleys and a fan belt. If the belt is broken, replace it. If it's just jumped off like in my case, put it back on. Easy!
Posted on Mar 21, 2009
  • 750 Answers
Check your vents are clear and the outside vent may have a cover on it to stop small animals from getting in it.
Take this off, if its even half clogged up it will stop the dryer from heating or it will heat unevenly.
And check the vent line is not kinked or twisted or squashed.
other wise it may be a bad heat element in an electric dryer.
Or a bad burner in a gas dryer.
Let me know what you find out!
huuum
Please remember to leave a rating
Posted on Oct 08, 2008
Thanks - had same problem. Opened back and indeed found a broken fan belt. The belt rubber bonds perfectly with super glue - one drop and within 20 seconds the machine was running again!
Posted on Sep 20, 2009
2 Suggested Answers
SOURCE: Simpson Sirocco 350 Dryer not heating
I repaired my broken fan belt with a drop of super glue - there is virtually no load on the belt and it now works perfectly again. A 30 sec quick fix.
Simpson clothes dryer sirocco 455 5kg the power shorts out when we turn it on ?
check the heating element.remove back panel to access it
May 31, 2015 | Dryers
Simpson sirocco clothes drier tumbles ok, but heater not working
Bad heating coils, or bad ignitor if gas.
Jun 21, 2010 | Dryers
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
I have 2 simpson sirocco 350 dryers and neither will dry clothes as soon as a bit of heat happens they turn off is there something that I did'nt take out of them when Ifirst got them? Hoping you can help....
difficult one , but drier will typically switch off if the over temp. sensor activates. Suggest you move the drier away from the wall or any area that could block air flow into the air ducts and retest. Very unlikely both would do the same thing. Common denominator is its position..
Sep 14, 2009 | Siemens Dryers
When the dryer is on high or medium heat, it trips the power breaker of the house. it does not do this on air only/no heat", which makes me think of a short in heating unit.
the dryer is run by a universal motor, and these motors (while being very robust) can draw more current if the torque put on the drive train is overloaded. try running dryer with less clothes.
May 12, 2009 | Dryers
Mar 21, 2009 | Dryers
Dryer will not heat until after about 2-3 loads
I am online looking for an answer similar---our dryer doesn't heat....air comes out lukewarm and will not dry after 2-3 cycles.
Jan 02, 2009 | Whirlpool LER5636P Electric Dryer
No heat
ok so you have some heat.your dryer unless an ge one has one element so if you have heat its working.then what you have is an exust problem.once you heat up the clothes and cause the moisture to evaporate then it must be able to leave the dryer or it reclings to the clothes,hence lond dry times.to test this dry a load with the venting undone and the dryer pulled out.dont worry it wont start a fire/never!its about 180 degress to 130 of moist air. if ok then confirms that venting is blocked.some times dryers get blocked internaly also but do the other first.God bless,tom
Jan 01, 2009 | Whirlpool LER4634J Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Maytag 7.0 Cu. Ft. Electric Dryer Logo
2,811 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
