Question about Lexmark X75 All-In-One InkJet Printer
Printer spooler not working
If i try to print anything it comes up and gives me this printer spooler is not working
  • Lexmark Master
  • 4,338 Answers
Start/settings/control panel/Administrative Tools/services
Scrool down to Print Spooler, set it to automatic, Then press "start " to start the print spooler service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 19, 2008
Have Z2420 printer appears it's talking with PC says it's printing gives printing status as 20% complete but nothing prints s
It could be due to the print spooler service on your computer. Please follow the steps below on how to clear the print queue and enable the print spooler service.
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Jan 15, 2012 | Lexmark Z2420 Printer
Printer refuses to print. Shows message 5100. Nothing in printer manual shows how to remedy fault. Unable to find anything on website to fix it.
Hi
I believe the print spooler had stoped and needs to restart again. Please try this solution
Go to START MENU
Choose Command prompt, right click and run as administrator ( Fow window vista and windows 7)
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
If it does not help you, please let me know to give more advise. Regards
Mar 03, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
I have an HP 1020 printer. I cannot undertake any operation as the words " printer spooler not running " continues to appear on the screen. I tried to delete the printer and reinstall , without...
Print spooler not running is not the printer error, it happens when the print spooler service starts working in windows, For making it enable you dont have to reinstall the drivers for the printer, as print spooler service is for every printer, even if you put another printer the result will be the same
To Enable Print Spooler Open Control Panel
Go to administrative Tools>Services (For Windows XP Users)
Control Panel\System and Security\Administrative Tools( for windows 7 users)
Open Services Find Print Spooler in the list
Right click the service and make it stop, if its already stop set it to Start and then again give prints
Double click on the service and set "Startup type to AUTOMATIC". You should now be able to get prints from your printer
Now restart your desktop/laptop and check if the service is still working by giving any test print.
Hope it will solve your issue
If you require more assistance, regarding this topic feel free to reply
Regards, BA
Jan 14, 2011 | HP LaserJet 1020 Printer
I cancelled a print job from the Vista Printers link on my desktop. It jammed and I can't get it to delete and can't print anything down queue. How can I clear the print queue?
hi,
you need to delete the jobs and print the stuffs...
you need to give the following commands in the command promt which can be accessed from the start menu or by clicking "windows key+r"
net stop "print spooler"
to stop the print spooler
after you have stoped the print spooler
You should see files there ending in .SPL and .SHD created around the time you tried to print – delete these files.
now try to print the stuffs..
if it clears the mess please give a vote....
Mar 11, 2010 | HP OfficeJet 7310 All-In-One InkJet...
My daugther is trying to print but the documents are coming out side ways and the printer is printing the same thing over and over. I tried to cancel the printing , cut off the printer, unplug it and is...
hi,
you need to give the following commands at the run
you can get it from the start menu..
in it give the following code
one by one each line
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
it actually cancels the print jobs and deletes the contents in the buffer..
you should give the files to print again....
if it helps you please give a vote....
Mar 02, 2010 | Brother MFC-7340 All-In-One Laser Printer
Everytime I try to cancel the pending document it doesn't do anything just stays the same, so that does not allow me to print anything else because for some reason that pending doc. won't erase... please...
first do a right clickon the printer icon
select run as administrator if there or else try cancelling the document
if still does not work
go to run and type "services.msc" and it will take you to the services page
in the services page look for a service "print spooler "
and then try deleting the documents .......................... hope this should work for you let us know wat happens and we will help you accordingly ......take care ............god bless you ...........thank you (HAMID)
Oct 29, 2009 | HP Officejet 5610 All-In-One InkJet...
The print spooler service is not running.
Reinstall the printer drivers will shore it up quickly the spooler has to do with the printer so do that and you should be fine.
Apr 23, 2009 | HP OfficeJet 4215 All-In-One InkJet...
I can not print anything from the Internet with my HP psc 750
Try this.
Goto-->Start-->Type cmd & Hit Enter
Now on the cmd prompt type net stop spooler & hit enter
After the message "The Print Spooler service was stopped successfully"
Type net start spooler & hit enter
after this process try to print again..sure it will work.
Again same issue then i would suggest you to power off your printer for a min & power it on back.
I am sure it should work.
Mar 13, 2009 | HP PSC 750 All-In-One InkJet Printer
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
Print spooler service not running on Windows XP
Spooler depends on the RPC service being running. But you really need to get into event viewer and check for anything related to either RPC or Print Spooler. If you're trying to print to a network printer you could have firewall issues either within Windows or your router. Think about what changed on your system around the time this problem began.
Dec 30, 2008 | HP Pavilion dv6000z Notebook
Lexmark X75 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
