Phillips 42PF9631D 42
Greetings,
I purchased the Phillips Plasma TV in December 2006 and everything worked great until this morning, I attempted to turn on the unit, nothing happened, no bang,Psshh or splat !! However, I got a couple of flashes from some little red light located at the bottom right hand corner of the set..? Confused, I unplugged the unit, for a "cooling" off period, but to no avail..I researched a little on the webb and found this was a similar problem with ALL philips tv's { I was sad.} I like my Tv and cannot afford a new one!! I contacted Phillips, and could have sworn I heard laughter in the back ground, they in return refered me to a local repair shop, again I swear there was laughter..I was told to wish in one hand and poop in the other to see which one filled quicker..That was about how quick the repair could be made..So, I'm appealing to your kindness and asking for any asistance you might have to offer, outside of the ramdom laughing I have been getting.
kind regards,
Joseph E Perry
  • 41 Answers
Do you hear a clicking sound when you try and turn it on? If so how many clicks? Also do you have and sound from the unit static or anything?
Posted on Oct 08, 2008
I heard Two clicking sounds, like it was trying to turn on but failed to do so. It almost sounds like the unit was going to turn on, you know the normal static sound, then it dropped off.
I have phillips 42pf9631d/37 that wont turn on and blinks red seven times
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.com
Oct 25, 2011 | Philips 42PF9631D 42 in. Plasma Television
42 inch plasma tv
Power supply needs repair.Est in range of $150 is fair. Find a qualified shop
May 12, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips 42PF9631D 42 in. Plasma Television TV wont turn on..I get the initial green power light, but it quickly goes to a flashing red light (flashes a series of 4 times). Philips tech support is a joke....
Philip have alot power problems with their tv.Check power board for puff up parts like Capacitors,or rust in cracks or soldering.Changes parts or the whole power board.
Jan 08, 2010 | Philips 42PF9631D 42 in. Plasma Television
I purchased a phillips magnavox tv in 2006
Just google the model # and you should come up with it.
Nov 17, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips 42 inch LCD 42PF9730A Redlight flashing
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Jun 16, 2009 | Philips 42PF9631D 42 in. Plasma Television
Removing closed captioning
Worked it out. The Direct TV remote has a yellow button and that did it. I don't know whether I had inadvertently programmed it that way but problem gone.
Thanks.
Jan 18, 2009 | Philips 42PF9631D 42 in. Plasma Television
42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Jan 06, 2009 | Philips 42FD9932 42 in. Plasma Television
Phillips model 42PF9631D/37 Plasma TV PIP Setup
Hello, please try this link: http://www.p4c.philips.com/na4/4/42pf9631d_37b/42pf9631d_37b_dfu_aen.pdf Best regards, Arpi
Jun 17, 2007 | Philips 42PF9631D 42 in. Plasma Television
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Electro Med Services...
