Question about Kenmore 23822 Top Load Washer
Not switching from rinse to drain cycle
I have a Kenmore series 80 toploading washer. Every once in a while I have to open and close the lid before it will switch from wash cycle to rinse
  • Anonymous Mar 13, 2014
    kenmore topload belt driven washer wont drain
  • 5,911 Answers
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at Select "Search by Part Number" and enter the following part numbers: The lid switch is part #3949238 and the lid strike is part #350733. If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can can more potential problems.
Posted on Oct 08, 2008
My Kenmore 26442502 top load washer will not kick into the spin cycle after it agitates. Just kinda humms. As I open the lid while it should be spinnning, everything stops, like it should. Once I close the...
Hello Dbriner,
It would appear that the lid switch is defective and is in need of replacement. I included a video showing basically how to replace it (It is a series 80 machine but that is minor).The steps are the same.
Your part can be found here for $29.65 +Shipping
Good Luck!
Rich Lilja Kenmore Washing Machine Lid Switch Assembly WP8318084
May 20, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washing machine will fill up with water, then nothing happens
Kenmore Ultra Fabric Care Heavy Duty 80 Series washing machine (Model # 110.92389200; Serial # CF 1122814) went through the wash cycle completely, but rinse not the rinse cycle. Motor was going but washer not spinning. Also smelled something like burnt rubber. Could the belt have gone out? Is this something that I can fix myself?
Mar 18, 2010 | Washing Machines
Sears Kenmore 80 series will not rinse or drain
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at,,, Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing. That way I can provide you with better assistance. I hope this information is helpful to you.
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite 24952 topload washer stops after rinse before drain
sounds like lid switch ..if switch is along right side of of opening try holding it down with pencil or other slinder object if spins ok replace switch if switch is not visible it may be under left rear hinge area ck hinge screws and tighten or try pushing hinge lever toward back slightly
Nov 26, 2008 | Kenmore Washing Machines
Kenmore Series 70 Top loader won't spin
it is a problem with the lid switch. check for continuity. if the lid is close , it should have continuity, if you open the lid, it should be open also.
tnx 4 using fixya,
Oct 31, 2008 | Kenmore 23822 Top Load Washer
Kenmore washer will not spin
Jun 12, 2008 | Kenmore 23822 Top Load Washer
Kenmore 23822 Top Load Washer Logo
78 people viewed this question
Sal De
 Brian Main
Brian Main
