Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
Hp zv5346us audio problem
My sound is alway on mute mode. If I try to pop the volume sound is present but it automatically decreases. If installed all drivers and even changed the internal sound card. Any suggestions on how I could fix this problem?
    Scholar:
  • 83 Answers
Try to look for the sound icon in your task bar. select properties then try to check options then select all settings that are supposedly running in your system uncheck those settings that are set to mute then adjust the volume lever to higher level.ex. Right Click sound icon,-open volume control, When volume controls appear click on the properties,-then select all settings that you might be using then close the volume control panel. then try to run again. if possible it needs restart to take effect the new settings.
Posted on Oct 22, 2008
Cant hear anything.
right click on speaker icon, select play back devices, a box will appear and show the devices that are present, if there is more than one, click on the one that has no green check mark on it. Click set as default and try again. Also make sure nothing is muted.
Mar 19, 2016 | Sony VAIO Computers & Internet
Everything lights up and is working,but i have no sound
Do you accidentally have it muted? The Mute button, located on PASSPORT's top panel and SmartCord. Have you turned up the volume on it? Volume Control (VOL) To increase or decrease the audio volume, press and hold the (+) or (-) volume control buttons located on the top case. A sample alert tone will be generated, along with a corresponding bar-graph on the display. Once you have reached your desired volume level, simply release the button. This level will be stored in memory. In Preferences Auto Volume is the default. This feature will increase the audio alert level automatically when the ambient noise in the vehicle is high. Good luck.
Mar 06, 2011 | Passport 9500i Radar/Laser Detector
Volume on my hp dv7-2043ci is not working. volume
check whether the drivers are installed properly and try by re installing the driver after removing the existing sound rivers
This can be done by using the device manager
In the device manager you can find whether driver is installed if it is installed and not working means right click it and give uninstall ,automatically it will search for drivers and ask the required driver or it install if backup is present already
Mar 03, 2010 | HP Pavilion dv6000z Notebook
Hp dv71245dx cannot remove from muted state.
hi
Go to Control panel > Sounds and Audio Devices > Volume. Check that Device Volume is at least halfway across the slider and that Mute is unchecked. Go to Advanced and make sure that nothing is mute. Go to Speaker Volume and set the sliders at least halfway across the slider. Go to Advanced, and in Speakers setup choose Laptop Stereo Speakers (if that's what you have). Go to Performance and choose Restore Defaults. Click Apply > OK
plz do inform if this has sorted out the problem
all the best
regards
Jul 15, 2009 | HP Pavilion dv7-1245dx Notebook
Audio input/output problem
Dear user,,
Pl go to control panel and select sound/audio device and click and see you see install sound device.
pl double click on speaker symbol at taskbar.
see volume controler and selecting hedphone device and see it is mute or not
Regards,
Ravindra Shah
May 23, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
No sound from my HP w1907 monitor
This is a failure in the audio section of the control circuit. Your cable could be at fault or the circuit itself. Try switching cables or try you monitor on a different sound source. if this does not work then it is the monitors sound circuits. This requires a trip to a service center for servicing. Hope this helps.
Apr 07, 2009 | HP w1907 LCD Monitor
My laptop is always on mute mode
Try the following
START \ SETTINGS \ CONTROL PANEL \ SOUNDS AND AUDIO DEVICES
Then make sure the Mute box is unchecked. If that doesn't work,
click
AUDIO \ SOUND PLAYBACK VOLUME
and make sure that all the mute boxes are unchecked.
Sep 09, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Hyundai lcd tv
Mine does this too. Sorry if i tell you the wrong button, because i can't test it right now because I'm having the problem where my remote doesn't work. But i would either push the MTS button or the P. Mode don't remember which it was, but it would change the audio from stereo to mono and i think you want mono to fix it.
Aug 15, 2007 | Hyundai ImageQuest HQL320WR 32 in....
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
129 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
