Question about Husqvarna Chain Saw 20" Bar
Chainsaw kills when I press the throttle
When I give my chainsaw (Husquvarna) gas it will run good for a couple seconds then kill? I tried cleaning my air filter and nothing changed. Any ideas on what to try next?
  • 2 more comments
  • tabipapa Oct 08, 2008
    Mine seems to do the same thing as well but when I get it to run a little while longer, as soon as I try to cut a log, it dies on me. It starts again easy enough but it would be nice if it stayed on. Anyone has a solution??
  • jckedup Oct 20, 2008
    Mine did this last year, took it to the shop, dirty spark arrestor screen. I've been cutting once this season and the next day it started again.... Hard to start and once it starts it will run for 10 seconds and go to cut and it dies and won't start again. Very frustrating!!!
  • nudebomb Nov 19, 2008
    own a 357xp, starts up no prob, then when you go to cut down a tree it seems like it wants to die out. Then when i do cut down the tree and move on to another, she doesnt want to idle for more then 10 secs.
  • mac4251 Dec 05, 2008
    i have a 455 rancher iddles great. when i pull the trigger it is fine till i get her completly open the she will die any ideas?
  • 16 Answers
Broken fuel pipe is a common problem
Posted on Nov 11, 2008
My 372 xp did that and when I talked to the repair shop they even showed me. There is a fiberglass gasket that is used to mount the carburetor to the engine. I have no idea on how this happens, but I saw it with my own eyes. The gasket had actually folded over. They replaced it with a rubber one and have had no problem since. The saw was hard to start, would run as long as I didn't try to cut anything and when I did it would open up and then die. I could be giving wrong information, but that sounds exactly like the problem I was having.
Posted on Oct 28, 2008
    New Friend:
I had the same problem with my Rancher 455. With a full tank of gas, it would run for about 10 minutes and die. I found the fuel line (inside the tank) was broken. I forgot to store the saw without fuel and the gas eroded the fuel line. I replaced the fuel line and filter. Works great!
Posted on Nov 10, 2015
I removed the throttle rod from the carb and now I can not installed the rod properly my chainsaw is a Husqarna 55 rancher .
Posted on Dec 04, 2008
As a follow-up to my post of my Husky 455 rancher dying when I go to cut, the local repair shop told me it was a dirty fuel filter and a carb adjust, it runs great now
Posted on Oct 30, 2008
It could be tank vent. it could also be fuel tank filter.to get at filter you must empty all gas and fish out fuel line with peice of wire with hook on end.if you look in tank you can see line and filter.
Posted on Oct 22, 2008
Sounds like the gas tank vent is clogged. Try opening the gas cap and running the saw (this is best done with a 1/2 full tank), if the saw runs ok with the cap loose the tank vent is clogged. Took me a long time to figure that one out.
Posted on Oct 20, 2008
Where does the kill switch wires go
Coil too the kill switch , kill switch too the ground good clean metal.. Kill switch is just making the ground conection.. Goodluck..
Aug 11, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
40 CC WILD THING POULAN
maybe the thermal sensor in the engine is overheated..it is inthere to keep the engine from frying.
Oct 23, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Husquvarna 350 chainsaw won't stay running
There could be a couple of things wrong. Check fuel filter and fuel lines for integrity. Then check air filter. Replace sparkplug with proper resistor style plug. If the saw will still not run, check compression, should be between 120 - 145 lbs.
Still nothing, check to make sure ignition has good ground where it mounts on case.
May 10, 2014 | Husqvarna Garden
Does the wire from the kill switch need to be connected in order for the chainsaw to run?
The on/off switch must be connected and switched to ON to run. The kill switch if it is the type of switch that you must press and hold then not it only grounds the coil to stop the spark plug from getting power.
So my answer is no.
Apr 23, 2014 | Stihl Garden
Chainsaw runs fine than goes full throttle all by its self and cannot shut it off with switch.
Kill switch is broken or disconnected. Throttle linkage is broken or disconnected or idle is set way too high.
Oct 26, 2013 | Craftsman 2.5 Turbo Chainsaw Throttle...
Chainsaw dies out when gas is pressed to full throtle
Carb needs teardown and cleaning. May be a stuck float or clogged jet.
Spraycleaner just wont cut it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Husqvarna 51 Starts and runs, but shuts off after a few seconds. I have a Poulan Pro 310 that started doing the same thing at the same time. I bought new spark plugs for each, as it had been a lot of...
Try removing the air cleaner and get the thing running and throttle it wide open and place your hand over where you removed the air cleaner. Basically choking off the air to the carb. But do it quickly sometimes you have to do it a couple of times. This clears out anything that is stuck in the idle jet. Just throttle wide open and quickly place your hand over the carb and quickly remove it. You may kill the engine a couple of times before you get the hang of it but you want to try to keep the unit running if at all possible. It works for me about 90% of the time. The other alternative is to remove the carb and give it a good cleaning. There very simple to take off and take apart if you have any mechanical knowledge (and it sounds like you do) Good luck.
Oct 10, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
455 Husqvarna chainsaw will not run
Remove exhaust , check piston make shore you have a chance,
check ex screen isn't blocked.
check choke isn't stuck on,and half throttle is working. get back to me from there.cheers
Dec 22, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan 295 farm boss chainsaw
Try to adjust the air and gas intake pin. It is a screw type dial usually found sticking out the carburetor. You are tuning your carburetor, so you will have to test different adjustments until you get your desired running idle and power. I suggest you start with adjusting the air intake screws to decrease air supply going to the cumbustion chamber, It will probably make the chainsaw run when you give it a throttle.
Keep me updated
Mark
Husqvarna Chain Saw 20" Bar Logo
1,176 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
