Question about Mitsubishi WS-55819 55" Rear Projection Television
HD Problem When watching HD programming sometimes notice a ripple in the screen the rolls through out the picture. Sometimes the picture is so clear that you can't notice it. Tested a newer HDTV on the same Directv HD reciever. No ripple at all. I only am noticing the ripple when watching HD. It is hooked up through the component video connection. Even when watching the HD channnels off my digital antenna, I notice the ripple effect on my screen. It is like there is some interference coming through. It is a minor distraction, but want to know if something needs to be fixed at some point.
  • 2 more comments
  • gobears1 Jan 04, 2009
    Thanks for the input. Talked to a repair man and he will be coming out soon to take a look.
  • gobears1 Feb 10, 2009
    Thanks for the great input. I hgot it fixed. It was the Caps
    I just had the caps replaced a couple of weeks ago. Works great now.
  • gscrivner7 May 11, 2010
    try connecting a dvd player to the same componant input and see if the ripple is still there. I suspect it will be. The 'formatter' module is suspect, or a bad regulator on the 'signal pcb'. Yes, this will eventually require repair.
    Problem Solver:
  • 14 Answers
Sounds like you need to replace the Caps in the Dm board there are 4-7 of them if you send me pics I will talk you through it!
Posted on Feb 10, 2009
Only 1 channel that I always watch, suddenly showed a blue screen & says Channel 4 "LMN HD" needs authorization code
Check with your cable/satellite provider. There may be an error with your programming package assignment, or sometimes the companies move channels from one tier to another in order to make more money. They should have given you a notice on channel lineup changes, though.
Nov 07, 2015 | Sceptre Televison & Video
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
Colour is not normal, sometimes the picture is too dark, football pitches bright green, peoples faces very orange.
that would be a failing tcon board on the back of the screen.you would need to replace this part but they are available on ebay the part number is on the tcon board. match the numbers a version number to get the matching board for the screen. tcon board is the board were the main wire cluster goes to the screen board this is the tcon board.
Jul 03, 2017 | Samsung LE37R72B 37 in. HD-Ready LCD...
While we're trying to watch TV, our Panasonic PT-AX200U HD projector will sometimes start alternating from a green screen to a blue screen and then to snow, and finally back to a normal picture. It's
You are experiencing Power Fluxuation. The Power Supply seems to be going out or on the way out... How old is the TV? Is it still under warranty?
Apr 08, 2013 | Audio Players & Recorders
Whilst watching SKy HD programs either HD or
You may be experiencing problems due to signal lost.These are sometimes caused by trees etc and sometimes the dish may need to be moved.
Dec 08, 2009 | Samsung LE37R72B 37 in. HD-Ready LCD...
32in Westinghouse lcd / picture scrambled
my westinghouse has the exact same problem....i have noticed it will catch sometimes when the screen changes from one picture to another that is totally different and one right after another......
Jun 30, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
HDTV Mitsubishi WS-55819 55 Inch Diamond Shield
You will need to contact a Mitsubishi Authorized repair facility. The entire electronics package must be removed and sent back in to Mitsubishi. The problem is the Formatter circuit board which is no longer available as a replacement part. The repair cost is very expensive and must be quoted by the facility you contact not me. Expect 4-6 weeks turnaround.
Nov 28, 2008 | Mitsubishi WS-55819 55" Rear Projection...
TV screen jumps and rolls, sometimes won't stay on
Try Re-soldering the vertical yoke connection and the vertical output IC. Thats a common problem in that model.
Feb 26, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Pink pixels across plasma screen.
I have the something going on w/mine!!! Are your fans turning on?Mine are not.I think that's my problem...Get back w/me..thanks,jon.
Dec 23, 2006 | Pioneer PureVision PDP-503CMX 50 in....
Mitsubishi WS-55819 55" Rear Projection Television Logo
107 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
