Question about Samsung LNT3242H Television
Samsung LN-T3242HX At turn on display lights up blue for 1 second then goes black. There is a noise like something has broken under the screen. I can hear it moving inside. I have taken apart the TV and it is not under the screen or the back. Any suggestions or schematics or diagrams on how to go under the boards would be greatly appreciated. Do I need to remove the screen to get in the center of the TV? Thank you!
  • 2,336 Answers
Hello Compgeek09,
It appears that one of the CCFL lights might have broken behind the screen and that is why the TV would turn on for 1 second and goes off after.
The noise you are hearing could peaces of shattered or broken light and you would have to remove the screen and to be able to fix it, if you are up for the challenge.
Let me know if you required further assistance.
Posted on Jun 11, 2017
2 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Samsung LN-T3242HX LCD TV
Hi Compgeek09
Please check CCFL is hooked in connector properly, all connectors of back light inverter board are plugged correctly, check also other connectors of removed boards while CCFL replaced.
It doesn't seem issue of back light inverter board nor its related to ground wire of power plug to wall because tv was working before replacement of CCFL.
Posted on Oct 19, 2008
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
My samsung 932gw is turning on and is only displaying for 3 seconds then goes off the power light is still blue, during displaying it makes some noises at the back. what could it be and is that repairable?
michal489, You should use Samsung warranty first!!! If that not an option, you will need to know and understand the top 1 or 2 causes of Black screen monitor failure so you will be able to do a possible DIY repair or contract out the work to someone who can!! Symptom sure sounds like power supply shutdown or failure. If you read some of my older and longer responses to BLACK screen owners in my fixya profile and visit some of the web links found there you will be in a much better position to make a decision on how best to deal with your lcd monitor.
I hope this steers you in direction you want to go. 12fixlouie
Dec 30, 2009 | Samsung SyncMaster 932GW LCD Monitor
Samsung LNT-4665F won't power up properly
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
You can get parts for your TV here:
http://www.shopjimmy.com/catalogsearch/result/?q=LN-T4665F+
Dec 09, 2009 | Samsung LN-T4665F 46 in. LCD Television
Samsung LN-t5265f picture turns off after a few seconds hear buzz
You have a bad Power supply. Have a trained Samsung tech replace the Power Supply.
Jul 02, 2009 | Televison & Video
Monitor screen goes out (black) 2 seconds after turning on
Your site is extremely misleading and fraudulent. I was under the impression that I would at least get a hint at what might be a problem instead of you folks making me wait to get a money for something answer that you could have displayed on your main page. Places like yours have no place on the internet and I'm going to find out what I can do to report you.
Thank's for nothing
Jan 16, 2009 | Mag Innovision LT976S 19" Flat Panel LCD...
TV won't turn off
Problem solved. I opened the configuration menu, went to Setup, More, Light Effect, changed setting from "Always" to "In Watching TV".
Dec 09, 2008 | Samsung LN-T4071F 40 in. LCD HDTV
Hi Compgeek09
Oct 19, 2008 | Samsung LNT3242H Television
LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
Jun 03, 2007 | Samsung LN-T4665F 46 in. LCD Television
Televison & Video Logo
90 people viewed this question
Jerry Greenberg
Jerry Greenberg
