Question about Garland H283 Gas Kitchen Range
Pilot lights keep going out and smell of gas
I live in Houston and wanted to know if there is anyone that can service and clean this stove. Moved into this just bought home and the stove was here.
    Novelist:
  • 125 Answers
I would bet if you look in the phone book, under commercial restaurant equipment repair, you will find what you are looking for. Try to get a CFESA certified company, as they will be experienced with the range, have most of the parts, and a relationship with the manufacture.
Here is one:http://www.restaurantservicecenter.com/
Hope that helps, thank you, and Happy New Year.
Posted on Jan 01, 2009
Gas smell when using and not using
follow this steps and fix it. God bless you
f the pilot light on your stove goes out, natural gas may build up in your stove. If your pilot light has gone out, open the kitchen windows and doors for 15 minutes to let the gas dissipate safely then relight the pilot light. Do not relight the pilot light immediately -- striking a match could cause an explosion.
Gas Leak
  • If you can smell the sulfur-like or rotten egg smell of gas, there may be a gas leak inside or outside your home. You might also hear a hissing sound coming from the stove or another appliance or from a pipeline. Outside gas leaks may kill or stunt nearby vegetation. Signs of carbon monoxide poisoning include nausea, dizziness, fatigue and other flu-like symptoms.
f you still smell gas after relighting the pilot light, don't hesitate. Leave your home, along with the rest of your family and pets, then call your utility company or 911 from a safe location. Leave the doors and windows open behind you, especially if the odor is strong or you can hear the hissing of a gas leak. Do not turn appliances or lights on or off or use a phone in your home. Do not strike a match or use a lighter, either. Prevention
Read more: http://www.ehow.com/info_12193884_smell-gas-house-still-lingering-after-shut-off-stove.html#ixzz2aT2VTMtc
Jul 28, 2013 | Maytag MGR5752BDS Stainless Steel Gas...
I have an old RV with a dometic refrigerator which runs on gas, 120 or 12v. I have verified gas at the stove. When slecting gas the refirg clicks trying to ignight but the piolt holes are rusty. Behind...
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF This service manual should help you get it going.
If the pilot light will not light, you need to get that operational before you can get the gas portion working. So you might want to take the pilot light assembly off (make sure the gas is off) and clean it with a brass wire brush. Once you get the pilot light to lite, then it should warm the thermcoupler that will open the gas valve.
Sep 01, 2011 | Dometic RM2852 Refrigerator
Gas is going to cooking stove in camper. Stove lights. But can't get pilot to light for hot water heater. Don't smell gas coming to pilot area. Furnace is not turning on, but worked fine when...
Chances are good that the thermocouple is bad. It is a small probe that the pilot light keep hot. Take it out and get one at HDepot or at a RV store.
May 27, 2011 | Heating & Cooling
Won't get hot, smells like gas
Most of these new fangled gas stove feature a silicone carbide ignitor to light the oven. Older stoves used a standing pilot light. As silicone carbide ignitor age a little they tend to get weak and fail to open the gas safety vave sufficiently enough for ignition. Take a look
Jul 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
We smell gas and our landlord said might be pilot light?? been using the stove all week we just moved in
Hi, Does this oven have electronic ignition?
If the pilot light is out, the burners will not light when you turn it on.
If this does have a pilot light, pop the top up and ight the pilot with a lighter or match. The pilot should be between the 2 burners.
please let me know if I can assist you further.
Vic
Jul 12, 2009 | Magic Chef 31000 Gas Kitchen Range
Pilot light keeps going out on one side of my Tappan stove (TPF303BWA). The 2 left burners are fine but the right side burners will not stay lit. I can light them with a match and they stay on for...
HI, Try using a needle to clean out the pilot orfice. Most models have an adjustment for the pilot light. It would be located near the manifold under the top panel.
I hope this helps you. Please let me knwo if I can assist you further.
Vic
Jun 05, 2009 | Tappan TGF303BW Gas Range
Gas stove works, but oven does not
A gas oven will have some built in safety devices. Assuming that you have an electric pilot light sparking device, anything in the pilot light circuit could cause your problem
The oven does not "want" to turn the gas on unless there is an operating pilot system.
Since you never smell gas, but gas is available, then something in the pilot light circuit sounds like the culprit.
It could be as simple as carbon build up on the igniter or an internal fusing mechanism.
If you can get into the oven to the igniter, you could try cleaning the unit with a plastic scrunge.
I'm going to guess that this is not going to respond well to 'home grown' measures and that it will require replacement of parts.
Perhaps it is time to bite the bullet and call in repair......
good luck
Apr 20, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
Gas smell when start oven
Hello, Kimquy25 -
Fixya.com is not a website for scheduling a Sears technician to inspect your gas stove.
Since you live in Houston, Texas, see the information here:
https://www.searshomeservices.com/locations/appliance-repair/tx-houston/4201-main-st
Personal opinion: If you can avoid it, do not use your gas stove / oven until a repair person checks it. Also, if you think there is a gas leak, IMMEDIATELY LEAVE YOUR HOME, go to a safe location and call the CenterPoint Energy natural gas Leak Emergency Hotline: 888-876-5786. - See more at: http://www.centerpointenergy.com/en-us/residential/customer-service/reporting?sa=LA#sthash.fGZo7JXh.dpuf
Best wishes.
Dec 19, 2017 | Stoves 720EF Electric Double Oven
Gaffers & Sattler stove
The pilot is under the bottom oven deck, usually you can lift the front edge, and slide it out, smelling gas without a pilot would be bad, that means either A : your safety is bad, and allowing gas to flow anyway, which requires replacement, and you may as well replace the thermocouple, and clean the pilot. or B : it is old enough it does not have a protected pilot, and you have to manually light it, usually indicated by an open hole in the front middle of the oven deck plate when you open the door, with a tube going to the burner. or C : your oven burner is bad or misaligned with the burner, and is shooting gas away from the pilot area, it would light via an open pilot eventually, but you don't want that. Please let us know, or have a qualified servicer look at it. Happy New Year, and thank you.
Nov 19, 2008 | Garland H283 Gas Kitchen Range
Garland H283 Gas Kitchen Range Logo
157 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
