Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
The touch lift drip tray is broken its the plastic shaft that holds it together so its unusable.. I think someone lifted the machine by the lift tray or the shipper put the box upside down and it broke.... wonder if replacement parts is available... thanks for any help
    Sergeant:
  • Saeco Expert
  • 223 Answers
The entire machine need to be taken apart to repair the auto drip tray. I would reccommend a Authorized Service Center to replace the tray. It is again not a simple fix.
Saeco's First Authorized Service Center of New York
Cerini Coffee Service
718-584-6120
www.CeriniCoffee.com
Posted on Nov 25, 2008
New Royal Professional Machine has the workd Dregraw.miss can not use the machine what must I do to get started need help.
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
Jan 10, 2011 | Saeco Royal Digital Plus Coffee...
How to remove drip tray
Hi
Lift up on the front of the drip tray and pull out the front. There are 2 locking pins on the bottom of the drip tray that lock into the machine, that is why you lift up on the front of the drip tray before you pull out.
Apr 20, 2010 | Saeco Royal Cappuccino Espresso Machine
Dear sir , we have one error on printer E02-01 , whats problem printer Model DP-8020E
the paper lift assembly will be broken or some paper will be struck check both the piont ,also check the voltage
Mar 02, 2010 | Panasonic DP-8020E Black and White Copier
I have a Brother Intellifax 4100 Fax machine. I may have pulled the paper cathrudge out to abruptly because a 3/4 spring was dislodged from somewhere - I have not identified where it belongs. As a...
best guess is it belongs under the paper lift plate in your paper tray, remove the paper tray and all the paper, there should be a metal paper lift plate in the paper tray, these are typically spring loaded to lift the paper into place. lift the plate and check the underside for the location of the spring, there is usually a retainer of some sort to hold the spring in place. once the spring is in place the tray should feed correctly.
Hope this is of some help.
Ed
May 09, 2009 | Brother IntelliFAX 4100 Laser Fax
Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
Apr 18, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Replacing door hine on hotpoint washing machine
Its a ***** of a design. Mine is a Hotpoint Aquarius 1200 WD62. If you cant get the backing plate then get someone to tilt the machine right back and you can put your hand under to get it out. Then take the top off the machine(3 screws at the back). Then slide your soap tray right out,(put it to one side) you will then see 4 screws (Which hold in the other tray that holds the soap tray) take these out, you will then need to remove this white plastic tray to get your hand down the machine to reach the place were the backing plate goes. Once u have taken the screws out slide the soap tray holder to the left or right (can't remember) it will then come loose. You will then need to slide it back to lift it out the way (No need to take the pipes off the back of it) you may need to push the whole drum back at the same time you are pushing back the soap holder (Be gentle but it will come out). The holder should then lift up out the way, you can now get your hand down to hold the back plate on whilst you get a helper to affix the door. Make sure backing plate is on the right way, the screws will only go in one way (Check which way b4 u put it down into place). Then go backwards on all steps to put machine back together. This sounds like a load of **** but it worked for me and took about 15 minutes. Good luck!!
Oct 18, 2008 | Hotpoint Washing Machines
Aficio 1035 ps
Finisher 1 tray lift motor error.
It should be looked at by a technician to see if the sensor or motor needs to be replaced.
If you want to use the machine for now and bypass the error. Turn the power off on the copier. locate the finisher cable in the back of the machine. Pinch and release the cable and turn the power back on.
Jul 11, 2008 | Ricoh Aficio 1035 Copier
Final spin drum knocks and is unbalanced, never used to do this.
Hello, if your clothing are sorted imbalanced you will have that problem. Ensure they are evenly distributed.
If that doesnt solve the problem, there is a bolt that is broken on the agitator shaft. Lift out the top cap from the agitator, take out the plastic seal beneath, remove the bolt, lift agitator out.
There are two horizontal bolts holding the inner-drum to the shaft. replace both.Be sure to tighten all the way.
May 31, 2008 | Hoover Nextra HNT 2135 Top Load Washer
Extremely Load spin cycle
the bearing on the tub is shot. depending on the make and model you might want a pro to look at it. depending on the age you might just want to replace it
Oct 18, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Leveling a washer tub
you dont level the tub, level the feet on the bottom of the machine
Sep 27, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
135 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
