Question about Brother MFC-640CW All-In-One InkJet Printer
Best way to refill Brother LC41 ink cartridge
I have found several sets of instructions for refilling the Brother LC41 ink cartridge on the web. They all use a syringe. Most of them tell you to make a new hole (in various different places) and one indicates that you should remove the needle from the syringe and fill it through the existing hole where the ink comes out (continually making sure to pump out any air that is in the cartridge).
Of the ones that tell you to make a new hole, there are different several places in which it indicates to make it:
o On the side of the cartridge 1/4 inch down from the top black cap.
o On the top of the cartridge's black cap, right where the "o" in the brother logo is (I think this one was on this site).
o On the very tip top of the cartridge "tab" (the part of the cartridge you would naturally hold to pull it out of the socket) where there is already a slight indentation.
Some say to use electrical tape or glue to cover the hole after you are finished, or else the ink will spill out. Some say NOT to cover the hole or else the ink may spill out :-)
Note that some of the procedures are for the LC-900 cartridge, which seems to be the same as the LC41.
So what is it? Which is the "correct" procedure?
Thanks
3 Suggested Answers
SOURCE: how to refill the cartridge of brother MFC240c
Hey its very simple, you'll need a syringe and an exacto knife. You just need to pop the case in half use the exacto knife to cut the seem very carfully and to pry the cartridge apart carfully. On the back of the cartridge you'll see a little indintation were it was filled in the factory just fill the cartridge with a syringe push in the indintation fill cartridge remember to leave a little air in there and seal the hole up so it's air tight again this can be done by using a little hot glue to seal the hole. I hope I was helpful. As well you can by a continous ink system for the brother 240c which is pretty need too
Posted on Sep 10, 2007
Mix-it-up
  • 832 Answers
SOURCE: instructions on refilling cartridge for brother LC41CL cartridge
Do mix the ink with some glycerol to prevent clogging!
2ml glycerol (85%-glycerin alc. from drugstore) with 10ml of ink for C/Y/M and shake well (mix) before use. Mix 1,5 ml glycerol with 20ml BK ink.
Simply drill a hole into the brandname (O of brother) on top of the cart. Refill with 12ml for C/Y/M and about 21ml for bk.
You can leave the hole open.
Next time when cart is empty simply open scanner and refill without taking the cart out! ;-)
DO MIX THE INK WITH GLYCEROL!!!
Posted on Apr 03, 2008
  • 10865 Answers
SOURCE: HOW TO REFILL WITH THE HELP OF SYRINGE INK CARTRIDGES OF BROTHER
locate the small hole or holes on the cartridge and slide the needle in. Be sure to put the right color in each. good luck
Posted on Jan 25, 2009
How to refill Brother LC101 ink cartridges
many manufacturer's have made the cartridges so they can not be refilled , but only replaced with OEM cartridges . they chipped them .
Apr 14, 2016 | Brother LC101BK Ink Cartridge
How do I refill Brother HC65 cartrige?
Hi
All printer are the same ways to refill the inks up go to this website it will show you how it done there is a few Videos there for you to see how it done
http://www.youtube.com/watch?v=pnCPB9Clk5c
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Brother MFC 6490CW InkJet Printer
Refill a 564 black cartridge instructions?
Refills are not possible for this cartridge type yet. There is a chip on the cartridge that needs to be reset or replaced for the cartridge to function. Any chips for sale on the internet are technically violating patent law. Any refill kit that tells you to take the chip off your cartridge and place it on their refill is swindling you. Once the chip says the cartridge is empty it WILL NOT print, no matter how much ink is actually left. I would wait until a reputable refiller like Cartridge World or Office Depot offers refills for this cartridge before you try to fill it at home.
Nov 12, 2009 | HP PHOTOSMART PLUS B209A All-In-One...
I NEED TO KNOW HOW TO REFILL INK FOR A CANON MX310 #41 COLOR.i DON,T KNOW IF YOU PRY THE TOP OFF OR IF THERE ARE SOME REFILL HOLES SOMEWHERE.SHIRL85@EMBARQMAIL.COM
Your printer uses the following cartridges:
canon-pg-30
Black Pigmented
canon-cl-31
Color
canon-pg-40
Black Pigmented
canon-pg-50
Black Pigmented canon-cl-41
Color
canon-cl-51
Color
ou find the refill instructions for your cartridges in the book at the link below:
Download Inkjet Refill Instructions
You can also buy refill kit here: inkjet refill products.
You also need to reset the cartridge after refill, see: Reset Ink levels for canon mx310 - FixYa
Mar 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Instructions on refilling cartridge for brother LC41CL cartridge
Apr 03, 2008 | Brother MFC-5440CN All-In-One InkJet...
"NO CARTRIDGE" MESSAGE ON BROTHER-425CN
try this:
take all carts out. Unplug machine from power outlet. wait 5 min. leave scanner top open. rplug to power. wait til machine demands carts. reinsert and secure the carts. close cover. answer questions on display. set date and time again in case its not displayed.
If you still receive message use another cart of a diffrent brand. There are many generic carts with bad construction and bad ink out on market.
Best way: refill original brother carts. drill a 2mm hole on top into the brand name (O of brother). refill C/Y/M with a mix of 2ml 85%-glycerol (glycerin alc.) from drugstore and 10ml of DYE ink (shake well before refilling). For BK use 15ml DYE ink mixed with 1.5 ml gylcerol
shke very well before refill.
Mar 21, 2008 | Brother MFC-425CN Multi-Function Center...
Brother mfc210c
two ways to refill lc41:
drill a 2 mm hole into the brandname (e.g. O of brother ) on top of the cart. You can leave the hole open and leave the carts in the printer in future for further refilling ;-)
The cart can be refilled by inserting a syringe without a needle into the ink Outlet(!) at the bottom, too. Carefully press a 12ml for C/Y/M and ca. 15ml - 18ml for BK into the carts.
Anyway:
Do use DYE-ink only!
Important: You must mix the dye-ink with some 85%-glycerin alc. to keep the print head nozzels alive = 10ml ink with 2ml glycerin alc (drugstore).
For BK: 15ml ink + 1,5ml glycerin alc!
Feb 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
Brother MFC-640CW All-In-One InkJet Printer Logo
234 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
