Toshiba D-R410KU DVD recorder, How do I set it up with a regular TV and no cable box? I want to record regular TV shows and I receive only local station via Rabbit ears .
  • tamoshanter Dec 26, 2008
    i just got the toshiba D-R410KU DVD video recorder for xmas. however, the installation guide starts out with saying that the recorder needes to be connected witht cable/satellite box. we have cox cable in VA and it goes directly from the wall to my VHS recorder via coax cable. so i don't have a cable box. i also have a panasonic 5 disc DVD player hooked up to my Samsung HDTV through a coax (just for picture, the panasonic DVD player is 5 years old, so doesn't have HDMI connection in the back)
    would i just connect the coax directly to the TV, then RCA cable it back to the Toshiba then back again?
    very frustrating when you're a technically impaired geek...
    tamoshanter
No offense intended, but...get a life and a new TV and a cable box with DVR...pre-record your shows and later record on Toshiba DVD recorder using HDMI cable, available at Fry's for $10. Also, you might still be able to do what you want if you are willing to read every word of every page of the user manual...been there done that...it wouldn't work for me either until I did same...I know, only read the user manual as a last resort, so...
Posted on Dec 25, 2008
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
What is the setup code for the DVD Video Recorder D-R410KU to control the player with the cable box remote?
I have found the code for the Toshiba D-R410 DVD recorder ! The code that works with my Radio Shack family 5 in 1 remote is:
1008
I hope this helps !
Feb 06, 2010 | Toshiba DR410 DVD Recorder
Can the Panasonic DMR-EH55 be made to receive digital channels? e.g. via a digital capable TV or a set top box? If not, I suspect it will be obsolete when analogue channels cease this year (in Australia)
If you receive your channels through your local cable company, nothing will change. The DMR-EH55 will continue to work normally.
If you receive your channels with your rooftop antenna you'll need a Digital to Analog TV Converter Box. The unit itself will not receive digital signals directly.
Jan 16, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
A/V Signal Outout through Onkyo TX-SR705
Are you trying to record cable programming with your DVD recorder? If so, you might want to try using component cable as HDMI does have a copy protection circuit that might be preventing your recorder from receiving the image. Just try to connect the cable box component (RED/GREEN/BLUE) cable to your DVD recorder. If that doesn't work, then try to change everything over to component cables. HDMI is a great cable to use but it the only required to display 1080p images and the only current source that uses 1080p is a bluray player. Everything else, such as your cable box and DVD recorder is 1080i and component cables are perfect for it.
Mar 14, 2009 | Toshiba RD-XS32 DVD Recorder
Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
Mar 02, 2009 | Toshiba DR410 DVD Recorder
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
Dvdrecorder and convertor box
If the clarification request is correct. The only thing i can suggest is. Plug aerial into converter box. plug converter box into TV using either scart or coaxial cable. then connect converter box to dvd recorder using scart or coaxial cable depending on what you used to plug converter box into TV with. Then plug dvd recorder into TV. I don't know if you have to set-up the converter box to start receiving i'm not sure. But try this anyway.
You'd probably have been better off getting a free-view box and your dvd recorder. Because as long as you've got a free-view box you'll always get digital. Hope this helps
Jul 29, 2008 | Televison & Video
Televison & Video Logo
1,125 people viewed this question
Top Televison & Video Experts
