Question about Panasonic Televison & Video
Vertical Deflection problem on Panasonic TC29V10A
I am in Australia and have a Panasonic TC29V10A. Recently it has developed a problem where the only thing appearing on the screen is a very bright thin line horizontally across the screen. The sound seems to be fine. How can I go about fixing this problem?
  • registrat73 Oct 08, 2008
    Thanks for the advice, but, how do I identify these components?
  • 24 Answers
Replace the vertical Ic and it probably failed because of the two Electrolytic Capacitors so check and replace if necessary. Not for a beginner but if you are good with a soldering iron and ****** it is possible.
Posted on Oct 08, 2008
  • supertech272 Oct 08, 2008
    Do you know anything about the insides of a television. the vertical Ic will almost always be attatched to a small heatsink and will have at least 4 to 9 pins on (usually the lettering on it will be tda or la then some numbers on it and usually it will be standing upright(vertically)it will usually be on the same board as the flyback transformer (this is a transformer that supplys the 25 000 volts approx to the picture tube. Just follow the lead back from the tube and you will see it.As for the Capacitors they look like cylinders with a marking on one side. Be aware though you must replace them with the same parts as are in it or else it will blow again or even may destroy something else also the Electrolytic capacitors (cylinders )are polarised so they must be put in the right way or they will blow up immediately. Happy to help if you like take a photo of the board preferably closeup and I will identify the components for you.
No horizontal and vertical deflection available:- audio OK
Check its horizontal output stage circuit. Replace damaged component/s. Vertical output stage gets its working voltage from the horizontal output transformer. If you want to get vertical deflection, this transformer, otherwise known as {LOT] should work to produce the supply voltage to vertical output stage.
Oct 12, 2012 | Panasonic CT-2789VYD 27 inch TV
I got the problem for my Panasonic 21 TV (CRT type) where's Vertical line across picture tube when the brighness adjust high. The vertical I.C already changing. Any solution > Thank you
Have you recently replaced its Line Output Transformer [LOT]?. If so have you replaced it with same type and number? Verical bars are due to LOT to Deflection Yoke mismatching. It is known as "Yoke Rigging" technically. Replacing the vertical Ic won't help in this problem . If you have replaced the LOT, the replaced one is not orginal. Ok
Oct 31, 2010 | Panasonic Televison & Video
Usually that is caused by a part failure. The vertical deflection ckt is most likely the roblem. Sometimes it's just a cap usually a 100mf right next to the vertical ic chip. Or it can be the ic itself. Unfortunately you can't adjust it out.
Feb 23, 2010 | Toshiba 32D46 32" TV
Panasonic CT-27SL15 has scan lines on top 4 inches of screen, what is problem and how to fix?
Nov 2011 - Comment
Have similar problem on a Panasonic Tau model CT-27SL15.
It's a 27" CRT TV manufactured around 2005.
Other posts / solutions on this problem say possibly a capacitor going bad in the vertical circuitry / near the vertical IC / vertical blanking circuitry. Telephone call to a TV repair person mentioned something similar - "possibly a bad capacitor in the vertical circuitry".
Found a service manual online w/schematics and board layouts.
Panasonic Service Manual
See pg 25 (of 42) - Deflection Schematic Diagram (Main PCB)
Shows: V Output IC - IC401
Finding the actual bad component(s) may not be so easy.
Anyway ... just wanted to add this comment.
Feb 11, 2010 | Panasonic CT-27SL15 27" TV
Vertical deflection went out and now HV is going into shutdown
Get service manual / schematics from HERE and find why vertical uotput IC is blown in your TV.
Service Manual will also give you info how to perform vertical adjustments.
Hope this info will help you to resolve problem.
Aug 22, 2008 | Mitsubishi CK-31304 TV
TV - only single, linear image with sound
vertical line on the screen is due to problem in horizontal deflection coil circuit
plz check
  • connector loose which is going to deflection coil mounted on crt.
  • loose contact or print break from flyback to def.coil.
  • capacitor defective going to deflection circuit.
  • if you are not tech person call tech. to fix it
  • it is not a major problem & can be fixed at your home.
  • hope this will help.
  • good luck.
Oct 17, 2007 | Televison & Video
Green horizontal deflection
Change both STK convergence IC's for reliability. They amplify/control both horiz and vertical. re-align after replacement.Locate them on the largest heat sink in your set!
Sep 26, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Samsung syncmaster 204b
Yes. There is no vertical deflection. The circuit that controls vertical deflection is bad. This is an easy fix for a TV tech. Take it to the TV repair shop.
Dec 14, 2006 | Samsung SyncMaster 204B 20.1" LCD Monitor
i also suspect its just bad solder connections, the vert. o/p ic is maked ic451 look for all the ic's on heatsinks. it should have 10 to 15 pin all in a straight line & be attached to a small heatsink. if i remember right i think if you are looking at the tv from the back it is on the left side near the front (by the buttons/swtitches). resolder all the pins on the ic & resolder the parts just around the ic as they too also develop bad solder connections. just remember to check for shorted pins after soldering. good luck.
Nov 30, 2006 | Panasonic CT25G7 25" TV
Screen Color Looks Like a Rainbow
Good day.
The problem includes malfunctioning of you units deflection yoke, color circuit and failures in the chroma system.
Have it check by a repairman.
Aug 04, 2006 | Toshiba 36A40 36" TV
Televison & Video Logo
143 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
