Installing new harddrive - Computers & Internet
  • Newbie Johns Jan 08, 2009
    Installed new SATA but computer does not recognize it. Read I might need to update the BIOS but in Drive Configuration...I only see the orginal drive...no ofther SATA on port 1,2 or 3? Can someone help?
    Scholar:
  • 69 Answers
So you want to Install a new Hard Drive?
Im assuming your New Hard drive is a SATA connector. Reply if it isn't.
Open up your computer case and look for the current hard drive. place the new hard drive in a free spot and screw it in. then plug in the SATA power cable and then the SATA interface cable and the other end on the motherboard by locating a free socket usually orange (Gigabyte Motherboard).
If you do not have a SATA power connector, you can get a Molex to SATA converter or you should buy a new power supply that has SATA power connectors.
Posted on Oct 08, 2008
Bios no longer detects the harddrive
Is it set to run disc or hard drive 1st?
if reinstalling windows it needs to boot up from cd drive 1st and this will automatic copy to new garden drive, after that change bios to boot up from hard drive.
Jan 14, 2014 | Toshiba Satellite M55-S331 Notebook
Replaced harddrive
Which version (including service pack) of Windows are you installing?
Dec 10, 2013 | Computers & Internet
Hi Andrea I have just connected a hard drive to my Laptop and it isn't recogized.. can you help. I'm running on Windows XP Thanks Ian
Not Andrea, just wanted to offer;
1) Installed a new larger Harddrive for the laptop?
There is a special procedure for this. Depends on what laptop we're discussing here.
A new harddrive will have no operating system on it. BIOS needs to recognize the harddrive.
{When you press the Power On button of your laptop, the first chipset to receive power is the BIOS chipset. BIOS looks to see what devices are installed, does a Ram Memory count, turns the Processor on, and hands the laptop over to the Operating System. WinXP is one example of an O/S }
Some laptops have a procedure where basic info is stored until the new harddrive is installed. Then the basic info is transferred to the new harddrive.
In any case I suggest going into the BIOS Setup, and on the main page see if the Harddrive is recognized.
It will be listed.
If it isn't listed you have to manually set the harddrive's parameters. (Type them in)
The Cylinders, Heads, and Sectors.
When BIOS recognizes the harddrive, then you can install Windows XP off of the Restoration Disk, (Repair. Also know as Non-Destructive Installation), or a fresh, new genuine copy.
2) If this is a reference to an external harddrive, there may be an electronic problem with the unit.
The main problem that happens with an external harddrive, is the small circuit board inside goes bad.
This small circuit board is an Interface Board.
It connects to the Harddrive inside the case of the external harddrive, and allows a USB cable to be used.
If this is found to be the problem simply remove the harddrive inside, and install it into an economical external enclosure.
Awaiting further information so I know what we are dealing with.
A) Is this a reference to a new harddrive being installed into the laptop?
If so, laptop manufacturer name, and Model Number.
(Bottom of laptop in a white Service Tag, or sticker)
B) Is this a reference to an extermal harddrive?
Manufacturer name, and Model Number
Regards,
joecoolvette
Oct 25, 2011 | Computers & Internet
My computer cannot recognise the hard drive
Are there any other harddrives installed on the computer...or is this a new harddrive...
If it's a second harddrive...then you have to set the jumpers accordingly...if it's a new harddrive...it should of came with a Cd and or floppy (depending on how old your computer is). You need to install that cd first, so it can tell your bios/cmos that there is a new HDD and the software will tell it to recognize it. Let me know
Dec 02, 2010 | Maxtor Hard Drive
Hard drive crash, not usable at all; downloaded xp drivers and computer drivers but cannot get them installed. Hard drive not recognized.
When you install a new harddrive, it has no Operating System on it.
Windows XP and Windows Vista, are examples of an Operating System.
Each laptop manufacturer, has their own system of changing a laptop harddrive. Some allow you to press a key or two, to put the laptop in a state where it will save the basic Operating System files, and when you install the new harddrive, it will transfer them over to it.
Some laptop manufacturers do have this option.
You either have to take the harddrive out, install it into an external enclosure for a harddrive, (Uses a USB cable) Then attach the external enclosure via the USB cable, to another computer, and use a 'mirror' imaging program to save the Operating System to that computer.
Then the new harddrive is installed in that external enclosure, and the Operating System is 'mirrored' over to it.
Just information for you, as you cannot do this now with a crashed harddrive.
Your option now, is to buy a genuine copy of the Operating System you had on the laptop, and install it.
Not what you wanted to hear, huh?
You need to buy whatever version of Windows XP it had, (WinXP Home or WinXP Pro), or Windows Vista.
If it was Windows Vista, I suggest getting at least the Windows Vista Home Premium version.
I personally prefer Xp over Vista.
Tigerdirect.com, and Newegg.com, have these.
Look for Software>Operating Systems.
OR, you can simply put Ubuntu Linux on it for free.
Apr 16, 2009 | Toshiba Satellite P25-S5263 Notebook
Won't boot up
Buy a new harddrive and install a new OS on it
make sure your old harddrive is disconnected
after the new hard drive is working properly then reconnect your old harddrive and
u will have all your files back unless the old hard drives crashed completely
Oct 18, 2008 | Gateway GT4022 PC Desktop
Replace hard drive on Gateway laptop
get a New 2.5'' laptop hardrive, and follow the steps: - Turn off the Laptop - Take off the Power Supply - Remove the Battery - Remove the Screw from the Harddrive cover plate - Once cover removed,romove the other (2) screws that hold the harddrive - Slide the Harddrive toward the Screw Hole - Lift the Connection End. - Slide the New Harddrive towards the connection end, Put back the Screws & cover plate - install a new copy of Operating System.
hope this is helpful 'suraj'
Oct 10, 2008 | Computers & Internet
Toshiba satellite a205-s5831 Received kernel data error. Hard drive has clicking noises. Programs ran slow. Chkdsk running now for over 15 hours and only on 11%..preplacing bad clusters.
When a harddrive starts clicking it's on it's way out.
Buy a new harddrive and at the same time get a USB to laptop harddrive adapter. You can reinstall XP with the recovery disks that came with your machine ans then slave your old drive to your laptop and recover your personal files.
If you really want to get technicalbuy an Apricorn housing: http://www.newegg.com/Product/Product.aspx?Item=N82E16817155602
And two new harddrives, fit one new harddrive to the Apricorn housing and try to install the EZgig cloning software to your dying Windows. You can clone your existing Windows install to the new harddrive in the Apricorn housing and then move that drive to your laptop, the second new harddrive can then be fitted to the Apricorn housing and used as an external harddrive.
EZgig comes with the Apricorn housing and you could even go so far as to create a clone of your Windows install to the new external harddrive. The Apricorn housings are excellent, they are small enough to carry in your laptop case and all they need for power is a USB port.
Sep 01, 2008 | Toshiba Computers & Internet
Bad Harddrive
please check your cables and try with new one.check the bios setting
Apr 04, 2008 | HP Compaq Business Notebook NX9010
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
