Question about Garmin GPS
Go to Tools, settings, language, make sure your voice is in American English.
When mine stops voice commands, I have found this is usually the problem.
I have noticed this usually happens when my satallite radio (Sirrus) does an upgrade, as both are in operation at the same time.
Hope this helps
Posted on Feb 24, 2009
VOICE turn by turn has quit working. How do I restore voice.
Check that the mute box is not ticked.
1. Press Tools, Settings, Language and then press Voice. Select a new voice.
2. If that doesn't solve the problem it may be that the voice file has become corrupted. Connect the satnav to your computer. Download and install webupdater from When it's installed it will look for updates to your satnav software. After this it will give you the option to download voices. Select the ones you want and click next. The voice files will be downloaded to your satnav.
When you've disconnected the satnav from your computer select the voice you want as described in paragraph 1 above.
Aug 13, 2010 | Garmin nuvi 750 GPS Receiver
We just purchased a Garmin 1390. On our first trip, everything was fine and all at one the verbal instructions quit working.
First check that the volume has not been muted or the volume fully down. Touch the volume icon and see that the mute box is not ticked or the volume fully down. Touching the mute box will untick it.
The most likely problem is that either the voice has become unselected or the voice file is corrupted.
Press Tools, then Settings, then Language. The voice being used should be displayed. Touch Voice and select another which may solve the problem.
If this does not solve the problem the voice file is probably corrupted. To solve this it needs to be downloaded again. Connect your satnav to your computer and download webupdater from When it's installed you'll get an option to update your software. After this you'll have an option to download voices. Tick the ones you want and click next. When the voices have been downloaded and you have disconnected the satnav from the computer you'll need to go back and select the voice you want from Tools, Settings, Language as described above.
Aug 09, 2010 | Garmin GPS
Can't get English on my Garmin nuvi 205. Happened when we tried to figure out why the sound quit working.
you should be able to go into settings menu to change the language for both voice and text. Click the wrench icon, then languages, you should be able to scroll up or down to find English.
Jan 19, 2010 | Garmin nuvi 205W GPS Receiver
My 255w garmin quit talking. No ryhme nor reason. anyone help me out?
Have you tried resetting the voice,Tools-Settings-Language-choose a Voice with (TTS) by it.Or try Resetting the NUVI,Resset Button under the Serial Number at the Bottom of unit,Press and hold for several seconds.
Oct 24, 2009 | Garmin nuvi 255W GPS Receiver
My garmin 750 quit talking??
Please see this link on how to restore the TTS voice directions:
- Jim
Sep 13, 2009 | Garmin GPS
Garmin wont talk
Thank you for contacting Garmin International. If you are not receiving verbal instructions from your unit there are a few things we can try to correct it. One would be to make sure there is a voice selected. You can check by pressing Tools, Settings, and Languages. If the box associated with the voice language is empty, press it and select a voice with a proper name after it and hit OK. Then you'll be fine. If it says "No Voice Found" please download and run Webupdater and you will be able to download the voices again. I hope this helps and here are some instructions for downloading that program.
These instructions follow what I experienced getting the update file. Based on computer settings you may have a slightly different experience.
From Ed. I got mine to work by completely depleteing the battery. It talked again during the process.
Jan 15, 2009 | Garmin nuvi 200W GPS Receiver
My garmin nuvi 205 quit talking. volume is at 100% and not on mute. beep sounds work but when in route i have no next turn or direction sounds. screen map does work.
I have a 750. I went to settings, language and restored the defaults. The Voice was blank when I went to that screen. I am not sure if the 205 has the language setup or not, but this should solve other Garmin problems. And as a bonus, if you want to solve the problems with the US, Fire Congress check out
Nov 07, 2008 | GPS
Garmin c550 phone book problem
Try deleting the pair from both the phone and the Garmin.
Then, retry the pairing sequence.
Hope this helps.
Sep 06, 2008 | Garmin StreetPilot c550 GPS Receiver
Voice quit working
I assume you have made sure the volume knob on the right side of the unit is adjusted all the way up. Have you also made sure the volume icon has the volume up? Does the unit make any sounds at all?
May 18, 2008 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
144 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
