Question about Creative Labs ZEN V Plus MP3 Player
How to change the battery
How do you change the battery in the Creative Zen V plus MP3. I would like a tip before I pry the casing off. Thanks.
  • goal2achieve Nov 15, 2008
    after fully charging the zen V plus, the battery depletes even when the product is powered off.....in about 30 minutes
Do a YouTube search on:
Creative Zen V / V Plus Help Reset Won't Work / Disassembly and follow the instructions till it gets to the bit where he disconnects the battery.
Quite where you get a new batterey from is another matter ...
Posted on Oct 12, 2008
Have you tried going to the www.creative.com/support site? It's a very informative site for my ZEN V, even though I still can't figure out how the LCD display went black and has never recovered. I hope this helps.
Posted on Oct 08, 2008
How to open it
Watch this YouTube video that shows the way to open up a Creative Zen V Plus and replace the battery.
All it takes is a guitar pick, a couple of screwdrivers, glue and some chutzpah.
How to replace battery MP3 Player Creative Zen Plus total reset
Jan 18, 2014 | Creative Labs ZEN V Plus MP3 Player
Tip
How To Install A Battery In A Creative Labs Zen Touch Mp3 Player
1) Using a small Philps screwdriver, remove the two screws from the top of the back case cover (near the head phone jack) and unscrew the two remaining screws at the bottom of the back case cover.
2) Carefully wedge a guitar pick, or a small Flat Head screwdriver from the side of the unit, in between the two housings in the middle, unclipping the case clips, using your fingers, carefully pry open the back case cover.
3) Disconnect the power cable by gently pulling on the cable, if needed use the Flat Head screwdriver or needle nose pliers to carefully pull the connector out.
4) Using your finger or the tip of the screwdriver, carefully remove the battery from the glue inside the case cover.
5) Plug in the new battery by pushing the connector into the socket; use the tip of the screw driver if needed. Make sure the battery fits within the guide brackets and does not get in the way of the screw holes. Snap the cover back with the rest of the device, and reinstall the four screws. Charge the new battery for a minimum of 3 hours before the first use.
on Jul 18, 2010 | Creative Labs Zen Touch MP3 Player
Creative zen uploading data on windows vista
Support for the Zen V plus is on this site
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=15306&prodName=ZEN+V+Plus
Get downwards on this page and go to Manual selection.
Next choose your language and the Operating System, in this case: Vista and SUBMIT.
The name of the application software for Vista is called:
ZNV_PCApp32_LA_6_41_10.exe
Aug 03, 2009 | Creative Labs ZEN V Plus MP3 Player
My creative zen v pluse dosent turn on at all dosent charg and...
http://support.creative.com/Products/Products.aspx?catid=213&catName=MP3+Players GO HERE. download a service manual or here I've had mine for 10 months, and the battery is dead. I did pry the Zen apart. There's 3 plastic pieces that hold it together. Just wedge a common screwdriver on the lower front piece first. Then remove the upper piece around the viewing screen;
http://i33.tinypic.com/2rnhhfm.jpg
The little monitor is held into position using double face tape. Gently pry it away from the circuit board. DO NOT REMOVE THE RIBBON CABLE. Let it hang by the cable. Then remove the two screws holding the board to back piece. The battery is mounted on the back side with double face tape pry it off and use a soldering iron to remove it from the circuit board.
http://i36.tinypic.com/8vqg61.jpg
http://i37.tinypic.com/20kspis.jpg. RICHARDM69
Dec 07, 2008 | Creative Labs ZEN V Plus MP3 Player
Line in recording procedure
i cant really offer a definitive solution. I just starting playing with my zen and finally figured out how to use the line in recording feature. I also realized that i needed an adapter to plug in the zen to my stereo; luckily my husband has two. I have read how to delete the recordings. I havent tried to use it as of yet; but if i have any trouble i will contact you back. thanks again, new to zen
Nov 06, 2008 | Creative Labs ZEN V Plus MP3 Player
Wont switch on
if it is still under warranty... take it in...
if not you can wedge your nails or a small screwdriver in the bottom of the case between the colored portion and the backing and pry it off...
Apr 01, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen nano plus
Change the battery, or send it to somewhere to get it fixed.
Mar 30, 2008 | Creative Labs Zen Nano Plus MP3 Player
One yr old, i let batt die, now does not seem to want to chg. after a bit the scn goes blank.
http://www.gomadic.com/creative-zen-v-rapid-wall-ac-charger.html
Following a tip on another forum, I picked up a Creative wall charger for the Zen Micro. Works just fine with my Zen V Plus and it was only $9.99 ($17 with tax and shipping) off the Creative web site. I like that it has a 5-foot cord. (That little USB cable that comes with the player is a pain.)
Nov 19, 2007 | Creative Labs ZEN V Plus MP3 Player
Won't turn on
Well, if you are new to the creative zen Nano plus, you may not have figured out how to turn it on. hold the play/pause button until the mp3 lcd screen lights up and that should work. if this is not the case i am sorry i cant help, but i also have a creative zen Nano Plus so i could find out for both of our benefits. i hope i helped!
Oct 31, 2007 | Creative Labs Zen Nano Plus MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
1,276 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
