Fagor washing machine error code F04 what does it mean?
SOURCE:
  • 139 Answers
SOURCE: washing machine
That fault code is to do with the drain pump either its jammed or not working remove the front plate at the bottom of the machine undue the filter and check to see if it is either a blockage or something jammed in the pump..
hope this helps cheers
Posted on Jan 21, 2008
nick75666
SOURCE: washing machine error code f04
ok these machines are great and they make it very simple F04 means cant drain which usually means money or bits and bobs stuck in pump impeller. On the front of the machine remove the bottom right hand plastic cover by hand this is where the access to the filter and pump can be found, you will see a black cap about 3" which can be unscrewed you may need pliers or something to grip it and turn it, have plenty of old towels ready as the water in the machine will begin to come out when you unscrew it(anti clockwise), just unscrew it a little until the water trickles out and mop it up with the old towels until the water stops then continue to unscrew anti clockwise until you are sure the thread is no longer gripping you cant over unscrew so if in doubt just keep unscrewing....then it needs to be pulled out toward you, you will probably need grippers or pliers for this just wiggle it out and remove it, look inside you will see the drain pump impeller, put a finger in and feel for whatever is obstructing it and remove, now use a finger to feel for the inlet that comes into the chamber from the left, use a finger to feel inside this pipe and remove other bits and bobs in the pipeline that were ready to find there way to the pump, once you have removed whatever is in there clean with a rag the thread and scale and make it nice and clean. In your sink wash the screw cap and little white filter piece that is attached to the cap and careful so as not to cross thread it push and then screw it back in making sure the filter solid plastic part is facing toward the inlet pipe you cleaned earlier as its that solid part that prevents (should prevent but didn't or you wouldn't be doing this) large objects finding there way in to the impeller chamber, screw the cap in and restart the cycle and your done, easy repair anyone can do it..... Don't forget to send me your luv if this works for you!!... Nick (at) 2xx.co.uk
Posted on Apr 27, 2009
57 varieties
  • 1653 Answers
SOURCE: what does error f04 mean on a bosch washing
It means that the water is not draining fromthe machine inthe time allowed by the controller.
1. Switch off the machine and disconnect the mains power.
2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray.
3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
4. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
5. Reconnect the power and switch the machine on.
If the problem persists then do the following.
6. Switch off the machine and disconnect the mains power.
7. Check the electrical connections at the pump and make sure it is operational.
8. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
9. Makes sure the pump appears clear and that the impeller looks in good condition.
10. Reconnect the hoses and then reconnect power and switch the machine on.
11. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
  • 4 Answers
SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Posted on Jul 08, 2008
  • 6 Answers
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Posted on Sep 09, 2009
My brother NX-600 keeps displaying the code F04, if I switch machine off then on again it will allow me to sew, but then stops showing the F04 message agai.
You need to find out what that particular error code means and address that particular issue. It could be something very simple but frustrating, just the same..
Search for:
Make Model error code F04
Oct 19, 2017 | Brother Sewing Machines
What does error P03 mean?
Hi,I cant be a hundred percent shore,but I think that it means ( fuel voluem regulater control curcuit low )I hope I am not steering you in the wrong direction,I have a code gide and this is it if im reading it write,all the best.
Sep 14, 2015 | Fagor Washing Machines
Need to know what f04 error code is
Bosch Excel? F04 means the pump hasn't been able to pump out (or at least that it thinks it hasn't been able to pump out). There are multiple possibilities from a clogged hose, to a burnt out motor, to a bad relay or just a bad connection. None the less, I found a blog post that details how to deal with it if you're handy...
http://jgwinster.blogspot.com/2011/07/bosch-washing-machine-fault-code-f04.html
Hope that helps!
Apr 13, 2015 | Washing Machines
Fault code f04
Hello Friend, this is Z. Thank you for allowing me to assist you!
If you are getting an error code F04 on your Electrolux washer, it usually means that timer on your washer is not advancing. Typically this is due to a faulty timer or speed control board. The speed control board is what advances the timer through the spin and wash cycles. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. I hope this helps explains the error code you are receiving.
Jul 28, 2014 | Electrolux Washing Machines
Showing F01 error code on readout? what does that mean?
Hi.
It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
With Hotpoint F01 means defective triac or defective motor.
Aug 18, 2011 | Washing Machines
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
F02 error code on Fagor FU6146IT
attempted to look up your washing machine on www.repairclinic.com they don't list Fagor, but you can go to that site and do some research. That website lists error codes for countless appliances as well as troubleshooting guides for the codes. Good luck
Jan 07, 2010 | Washing Machines
Error F08 on a fagor washing machine FU-6146
F08 on my FAGOR means a new motor is required we've had 3 failed motors in the past 2 years , total rubbish machine , would never buy FAGOR again . Mr M Freeman.
Jul 14, 2009 | Washing Machines
Washing Machines Logo
2,674 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
