Question about Asko W6461 Front Load Washer
Asko washer 20605
I keep getting f3 code on my washer. How do I reset the codes?
3 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: F6 CODE
F6 on an asko washer means a fault was detected with the motor. What this means 99% of the time is the brushes in the motor are worn. As long as the armature isn't damaged, (visual inspection while turning motor shaft should identify damage) you'll be fine replacing the brushes.
part # 764414, 2 required, about $40US each (better than $400US plus for a motor).
hope that helps
good luck
Posted on Sep 29, 2009
blueextc3221
  • 15935 Answers
SOURCE: Asko 20605 washer stopped mid-cycle, now no power?!
The ECU should be tested. Look for the service manual inside the chassis for troubleshooting procedures.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
SOURCE: My Asko 6461 washing machine - F3 code
F3 problem, I had the issue on model W6461, however, judging by the amount of F3 issues posted this could work on other ASKO models If the coin trap in the drain is clear of debris, try this. Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet in the wall or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear back through the coin trap.
7) Pour some water into the open end and blow this back through the drain as well.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water (all over the floor, don't forget the towels!)
Just ran the machine now and fault cleared.
Good luck
Jurgo
Posted on Sep 13, 2010
Model 20605 Probably very old. First time using it in new home. How do I open the inside door? Is there a latch someplace? Is there a place I can get a manual?
Welcome to FixYa.
The Asko 20605 washer is an older model indeed, but not as old as you might think, the serial number would indicate it's actual manufactured date but it is in the neighborhood of late 90's early millennium.
Those particular electronic control models have a button on the front which unlocks the door if the power is "on".
For a more detailed explanation I've tried to copy & paste a clip from my service info.
The door can also become "stuck" closed if in-active for a period of time with the door in the closed position as it will stick to the rubber seal around the basket opening. You may need to pull slightly on the door as you push the lock switch to unlock it.
Let me know if this clears up the matter for you and I'll try and assist you in whatever manner I can going forward...if need be.
Thank you for choosing FixYa for your inquiry. Good luck.
Regards,
Macmarkus :)
Jan 26, 2011 | Asko W6641 Front Load Washer
F3 Error Message
F3 is a pump problem check the pump trap and clean it this should clear it up...
Aug 25, 2007 | Asko W6441 Front Load Washer
Mar 04, 2010 | Asko Washing Machines
I stopped my Asko 20605 washer midcycle and it went dead. Can't turn it back on. Power turns on in the drier, but not the washer. If it's a fuse problem, where is the fuse? How do I get to it and what do I...
Do you still have washer? Where are you located? Give me a call i also have washer and i am looking for parts or might be able to give you parts.
410.926.7006
Dec 03, 2009 | Asko Washing Machines
Model 20605; problem, F-3 fault in pumping out
Usually cleaning out the pump will correct the problem.
Oct 06, 2009 | Asko Washing Machines
Not only is my asko washing machine leaking, the code "F3" flashes continuously, and my clothes are locked inside. What does "F3" mean? and how do I get the door to unlock?
F3 is a blocked drain...open coin trap remove blockage... also in the trap door is a red release string.. remove screw and pull it will release the door...
Hope it helps if NOT let me know more about your problem... and I will help
Jun 30, 2009 | Asko W6441 Front Load Washer
F6 CODE
hope that helps
good luck
May 30, 2008 | Asko W6021 Front Load Washer
20605 Washer - portal door hinge is loose - so door vibrates and bangs loudly in the spin cycle... literally tearing itself apart. Where can I get the replacement hinge parts, including the clips, and how...
its a big job the door comes as a kit,you have to losen the front panel that the door sits on thers two bolts on the back of the front panel you get access from inside take off the back panel use 60 cm extension then remove door seal and ring the screws for the door are behind the hinge you will have to move the front panel forward and stick screw driver handel between so you can get access,but the kit does have instuctions.it will take about 1 hour or so.hopethis helps. model 20605 is an asko
Mar 26, 2008 | Washing Machines
F3 Error Message
The F3 error code relates to a pump problem Check pump trap and clean. Good luck!
Asko W6461 Front Load Washer Logo
116 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
