Question about Technics SL-1200MK5 Turntable
Tone arm pushing towards the cent or the record
The tone arm on my mk5s is being pushed towads the middle. i dont know i use serato and it tell sme bad table vibration. changed platter, needles everythign. it still pushing. when i release it from the lock it moves towards the center a lil like it is out of timing or something. if you know whats wrong please email me and let me know something. Thanks
Tomafire@gmail.com
  • 515 Answers
Your tonearm is either damaged, or your anti-skate is not set properly. It should be set to ZERO. Take a look at this video for some assistance...- OPTiC.
Digital Analog Therapy
www.djprolab.com
www.1200s.com
Posted on Nov 04, 2008
My turntable a Crosley CR49 is about 14 years old. It plays just fine, but have to manually reset, clicking the tone arm after every record I play, either 45s or 33 1/3. How Can I fix this?
You will need to get to the underside of the turntable. There you should find that the arm when it gets to the centre of the record it will push on a switch. This switch might be out of position or just get stuck by grease or dirt. Correcting it should solve the problem.
Dec 08, 2015 | Crosley Audio Players & Recorders
Adjust tone arm
Usually there is a hole towards the back of where the tonearm is mounted that adjusts the set down area. Be aware that some have two holes one for set down and one for pick up of tonearm. These can be adjusted with a flat blade screwdriver. Check and see with a good flashlight. Adjust slowly and check to make sure you are turning it in the correct direction.
Apr 04, 2014 | RCA Audio Players & Recorders
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
Mar 03, 2013 | Technics SL-BD22 Turntable
Wurlitzer one more time. no sound and record will not eject
There is a switch just under the tone arm. When the tone arm moves towards the centre it slowly pushes two copper strips together. When they meet it starts the motor to eject the record. If you can't Cancel the record with the cancel button then that is a different problem, otherwise you can adjust the trip switch by inserting a 7mm spanner down the hole to the right of the tone arm post.
Apr 30, 2012 | Wurlitzer Jukebox 1015 One More Time...
Tone arm will not move over on self-start unless
Hi, they are not an auto start model turntable. To start lift tone arm off rest and move into position at start of record. It will automatically lift and return to rest as well as shut off at end of record. cheers john ,, Styluscity.com
Feb 21, 2010 | Thorens TD-190 Turntable
Tonearm not emitting signal into Serato
there is a switch that cuts off the signal when the tone arm docks.check the wiring is not broken inside and that the switch is ok.typically,red green white black red and white are plus and left ground is green and right ground is black.the collar that screws on to the head unit has 4 pins.make sure the contacts are clean.measure the wires one at a time from the tone arm to the rca plugs on the back.the green and black go to the outside collars,and the red and white go to the center pin of the rca plugs
May 26, 2009 | Technics SL-1200 Turntable
Playing songs backwards wit serato scrach live
I got it partially fixed. The black wire from the tone arm was broken so that been solder back on place nd the rca also the song is playing foward on channel 1 only, thats a start! New problem accuring now! Can't use that table to scarch now caus every time i do so the song goes foward only??? No back and forth in the sound??? I'll get a new tone arm and it should get everything better!
Dec 09, 2008 | Panasonic Technics SL-1200MK2 Turntable
I balanced my tonearms correctly. i think .. but the stylus jumps off the record and when i back spin (cue) the needle skates drasticly. can you walk me through the balancing proceedure and tell me how to...
Balancing the tone arm is a two step process. Set the needle weight adjustment to zero(0) and make sure that the tone arm is balanced. It should rest horizontally without touching anything. Next, set the needle weight (usually 1.5 grams). Both adjustments should be on the rear of the tone arm. That should cause the tone arm to drop toward the record and have the correct pressure for the needle. Also, check the anti-skate adjustment. If that is off, the behavior you describe will occur as well.
Dan
Jul 21, 2008 | Technics Audio Players & Recorders
Early tone arm pickup
On some record players there is an adjusting screw at the back of the tone arm that adjusts the tone arm drop in location but I don't think it will adjust the pick up point. That is controled by a steel rod under the record player deck that moves over and pushes a little trip lever near the center of the platter so that a gear is engauged and the end of record cycle is started. I'm not sure but you may be able to find an adjustment under the deck that is near the rotation point of the tone arm that will adjust that rod so that it will pickup later. Hope this helps some.
Dec 26, 2007 | Teac GF-350 CD Shelf System
Aiwa LX770 Turntable won't start
It's a bit after Jim's post, however I had what appears to have been the same problem with my LX770 after it had been stored in the loft for quite a few years. I found the problem to be caused by the tone arm mechanisms stalling - The band that was associated with lifting the arm had turned to a black gunge and was not allowing the motor to rotate, also the motor associated with moving the arm backwards and forwards was struggling to turn. I cleaned the tone lifting pulleys and replaced with a small elastic band (for a temporary fix). This was a little fiddly as you have to take off a spring and a couple of gears to get the new band in place. I cleaned the runners and cleaned off the grease on the worm gears associated with the arm tracking (as I suspected it may be more viscus than originally installed), lightly oiled the tone arm tracking gears. It still seamed to take an amount of helping the tracking arm gears until they were able to move freely. With the tone arm mechanisms working properly the whole unit now seams to be working.
Top tips if you attempt this: WARNING - If the unit is plugged in, the transformer and high voltage wires are live regardless of whether the on button is on or off on the front of the record deck. PLEASE do not take any of my comments as recommendation you should ever do anything with the unit plugged in! Remove the little stylus carrier before you start taking the player to pieces - saves damaging it! Remove the record mat and aluminium platter before turning the unit upside down. Manually push the tone arm to about 0.5cm from its furthest travel - so you can remove the tone arm mechanism plate. May be a little stiff as the wires have to slide of the pulleys for the tone arm to be pushed. To access the tone arm mechanisms, remove the main bottom plate (and greasy spring), then undo the screws which hold on the rear undertray. With the decks buttons toward you, you should then be able to lift the rear tray slightly and tilt the tray towards you to expose the tone arm mechanisms. You shouldn't need to remove the circuit board with the control buttons on the front of the unit.
After getting it going, I found that I needed a Phono preamp to get the signal strength necessary to use the deck for transferring vinyl to my PC.
Good luck
Oct 20, 2007 | Audio Players & Recorders
Technics SL-1200MK5 Turntable Logo
122 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
