Question about X2Gen MG19MY 19" LCD Monitor
Please please help me
I have the same monitor as yours, and exactly the same problem... half screen black, cant adjust it... did you find a solution?
thanks...
Sorry hon...can't be of any help...my monitor finally died...it was only 4 months old. What a drag!
I ended up having to purchase a new monitor. But this time I bought a dell...no problems now!
Posted on Oct 13, 2008
Screen gone half black...tried with different CPU...same problem persist... Please advise what to do...
The effect is called fold-over, where the bottom of the screen is folded over the top half.
If you can get into the menu set up you can try and change scan settings and adjust them so that :-
1. The screen is moved down so that the bottom of the fold-over is at the bottom of the screen and the top of the windows screen is at the top (it is missing on the photo).
2. Adjust the vertical scan rate to resolve the fold-over problem.
Otherwise it needs fixing by a TV engineer that can fix monitors as the adjustments are inside.
Mar 19, 2015 | Computers & Internet
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
How to change the 'Contrast' and 'Brightness' on the monitor screen
Bootup your computer and display your Windows Desktop. Make sure yourmonitor stays on for at least half an hour before you begin, so that itis properly warmed up.
Seta pure black image on the monitor so you can adjust the brightness. Toget a pure black image, do the following: Choose Start, then ControlPanel, then Display. This will open the Display Properties dialog box.Click the down arrow next to the representation of the desktop color inthe Color field. Choose black from the color palette, then click OK.
Maximizethe Brightness control on your monitor, then slowly reduce it until theblack of the image perfectly matches the black at the edge of thephysical screen. This puts the brightness at the proper setting.
Open a screen with a plain white background soyou can adjust the contrast. One of the best ways to do this is to open aword-processing document without any text in it. Gradually reduce the contrastsetting of your monitor until the white area of the screen begins to lookslightly gray or off-white. Then gradually increase the contrast until thewhite area on your monitor is pure white. This will give you the proper whitebalance. Now you've got your monitor ready for peak performance.
Hope this may help you solve your problem.
Nov 12, 2010 | Computers & Internet
Right half of screen is Black with a White vertical stripe
Yeah, I have this exact same problem, except my mom slammed my laptop shut in frustration around half an hour ago, so that's why it's like this. The right half of my screen is black with two colorful stripes (mostly white), but the left half is visible. I've researched a bit and found out that this is because the LCD in your monitor has burnt out, and since you don't have a monitor to attach, the only thing you can do is to go to where you bought the laptop and either get it fixed for free or return it for a brand new one (if your warranty still stands). If not, you might as well get a new laptop. I think my warranty has expired, so I'll get a new laptop, hopefully.
Hope this helps!
~Sam.
Jun 08, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Screen turned black
your monitor got a hardware problem:
1) the LVDS controler board out of work, only change or repair it could be fixed.
2) if you can see some show like smaller signal detect windows in the centre of screen a very short time (bright flashing one time), this is inverter board damaged or worn lamps, thay all need repair or replace
hope give you some idea. please take a rating let me know how much helped you thanks!
May 20, 2009 | Dell E176FP 17" LCD Monitor
I cant see but half tge game on the screen. the other half is beyond the right side of the monitor. please help
In order to solve this problem you will need to adjust the games resolution in order to match your screen or vice versa. In order to do so in the game it should be under your video options menu. In order to adjust windows to match the game simply right click anywhere on the desktop click on personalize or properties, then click on appearance. From there you can adjust your screen size to match. simply slide the bar left or right depending on whether you want the screen to be smaller or larger and then click apply.
Jul 10, 2008 | Take 2 Interactive Jetfighter 4 for...
Envision EN 780e Monitor Vertical Problem
u just give reset... the menus must be half visible atleast...
or just see the same type in option in other monitor and just write down how much time u must press navigation and iother buttons to go to reset option & to give reset...
once if u have done wit resetting ur screen will come normal to size then u can adjust height and width....
Feb 03, 2008 | MPC Computers Envision EN 780e (White) 17...
Colour adjustment
hi try lighten up the whole screen - its the "sun" icon and raise the contrast - its the half black hlaf white circle icon if it dont work , give us more details hope i helped
Feb 23, 2006 | CTX Professional PureFlat PR960FL 19...
X2Gen MG19MY 19" LCD Monitor Logo
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
