Power supplies I have an ATX100-5 (bestec) I need to switch it remotely, to power research devices for my sons robotics hobby. The five volt pass though voltage must return to the supply to turn it on. what pin on the 20 pin plug will return the volts? The green wire on the 20 pin plug is the five volt pin the purple wire also carries 4.25 volts
    Scholar:
  • 116 Answers
The purple wire.
Posted on Oct 08, 2008
  • mastermind10 Oct 08, 2008
    be very care ful while doing this type of experiments.
    some times causes risk.
    Sergeant:
    Champion:
  • 435 Answers
I assume you want to turn on your son's device with this ATX PSU.
here is the 20 pin configuration.
which gives you an idea of which pins could be used.
http://img510.imageshack.us/img510/6133/20pin24pinconnectoroe2.jpg
  • Karthik P Oct 08, 2008
    Also make sure to switch "on" the PSU (ATX100-5) by connecting the PIN 14 (Green) to any of the Ground PINs (black)
    You can use Ground and any of the 5V PINs (red) for the researcg device.
  • 13,433 Answers
Heres the atx pinout
http://pinouts.ru/Power/atxpower_pinout.shtml
heres something for you to read higly recommend you read it
(Power Up an ATX PSU without a Motherboard)
http://www.gideontech.com/content/articles/196/1
  • 1 more comment
  • Ekse Oct 08, 2008
    Seems to be GREEN and BLACK
    please read the webpage I sent earlyer.
    Thanks,
    Ekse
  • Ekse Oct 08, 2008
    let me know if you need anything else
  • Ekse Oct 08, 2008
Hi, I want to use the DC power supply disconnected from the motherboard. When all connectors to the powersupply are disconnected the fan in the power supply is not rotating and no 12 volt DC is...
As long as you're not talking about hooking it up to anything else, as in a hobby project, then the best thing to do is go out and get yourself a power supply tester. Office Depot still sells Antec ones in my city for under $20, and I recently bought one or two over eBay, direct from China, for under $4--shipping incl--each!
You just plug the tester up to the PS, plug the PS into the wall outlet, turn it on, and ...there you go!
Just one word of warning--be careful with Bestec power supplies--nothing personal against the company itself, but they should all be replaced before they damage your computer. I never worked on any eMachine with one of these power supplies, which had a hardware-related problem, where there wasn't damage to the motherboard due to their Bestec power supplies. They are not properly 'fused' to protect your computer against spikes, surges, etc.
Mar 22, 2011 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
I bought a wowwee mr personality robot for my son for Christmas. It talks and responds with words, but it will not move. The remote also will not turn it on-only off even when the button is in the on...
should be under warranty
with receipt of purchase return to place of purchase
confusing instructions indeed
try using robot with the power source plugged into it robot wont shut down like it does on battery
reset button on robot base
point the remote controller towards the robot’s IR receiver so that he receives the signal properly.
You can turn off Mr. Personality from a distance using the remote controller; Table 2 describes how.
NOTE:
If you want to turn him on after having turned him off using the remote controller’s power button,
you need to restart him using the power button on the
robot (press it OFF and then ON again).
one online site offers a repair service
Manual WowWee Mr Personality Toy Robot
Mr. Personality - The Old Robots www.theoldrobots.com/images7b/Mr._Personality_Manual.pdf
Apr 28, 2017 | Wowwee Toys
How do I check my bestec atx-250-12e power supply with volt meter
It's hard to do with a volt meter. What you would be better off doing is either ordering a cheap power supply tester online, and test yourself with that, or take out the power supply and take it to your local pc repair shop and ask them to check it for you. There are 12V outputs, 5V outputs and 3.5V outputs, and any of them could be bad, so that is why I say using a voltmeter is harder than using an actual power supply tester.
Let me know if this solves your problem.
May 01, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
EMachine T6420 will only turn on to start the fans and then immediately turns back off - has Bestec ATX-300-12E power supply - do you think that's the problem
These computers have had problems with the mother board. I had one the same problem, and I did research on the INternet. Best advice.... find a replacement board which will fit this box. Then you will have to re-install the operating system with the cdrom. You may be able to repair the system.
More than likely the power supply is not the problem, but the board is suspect more than anything.
Sep 23, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Want to use the atx-300-12z as a hobby power supply. Need 12vdc.
You're asking for a fire or just burning out the power supply. But,at your own peril, check the yellow wires for 12v or buy a power supply test adapter from ebay. It bypasses the power switch usually done by the motherboard & will fire up the power supply like it was connected to a board. Then test the wires for 12v. Should be any yellow wire,red is 5v. Green is 3.3 or 3v.
Jul 22, 2009 | HP Bestec ATX-1956D 200w HP Part No...
I have a Bestec atx-300-12az and i need to know which power supply harness to use on a Samsung model#HD103UJ hard drive.Thanks,Tony
Technical Details
  • Samsung Spinpoint HD103UJ 1 Terabyte SATA/300 Hard Drive General Features:
  • 1 Terabyte formatted capacity 7200 RPM spindle speed SATA/300 interface 32 MB buffer
  • 8.9 ms average seek time 4.17 ms average latency 3.5-inch form factor
  • Improved recording stability over temperature with PMR
  • Advanced dynamic FOD control for best data integrity
SATA Power3 Peripheral4 Floppy5 02 +3.3V (Orange)
03 COM (Black)
04 +5V (Red)
05 COM (Black)
06 +5V (Red)
07 COM (Black)
08 PG (Gray)
09 +5VSB (Purple)
10 +12V (White)
11 +12V (White)
12 +3.3V (Orange)
13 +3.3V (Orange)
14 -12V (Blue)
15 COM (Black)
16 PS-ON (Green)
17 COM (Black)
18 COM (Black)
19 COM (Black)
20 Blank
21 +5V (Red)
22 +5V (Red)
23 +5V (Red)
24 COM (Black)', CAPTION, 'Pin Signal (Color)', WIDTH, 150, BGCOLOR, '#000000', FGCOLOR, '#FFFFFF');" onmouseout="return nd();" href="javascript:void(0);">matx24pin.gif
atx12v.gif sata.gif drive.gif floppy.gif This ATX12V power supply is a 300W, five output unit with remote on/off, and UL, CSA, and TUV approvals. RoHS compliant. Original HP part number 5188-2625 used in many Media Center, Pavilion, and Presario computers. Also serves as upgrade for HP/Compaq part numbers 5189-3964, 5188-0131, 5187-5116, 5187-6114, 5188-0129, and 410507-001. Airflow drawn out of case into surroundings by 80mm internal fan. Built-in power status LED above AC inlent. 2 x 12 (24 pin) main board power connector. Includes two daisy chained Serial ATA connectors. Bestec model ATX-300-12Z CDR, also replaces ATX-300-12Z BC, ATX-300-12Z BD, and ATX-300-12Z CC. i trust this helps
Jul 15, 2009 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
HOW CAN I TURN ON A BESTEC ATX-300-12E PSU OUTSIDE OF THE COMPUT
check on mother bord there is power on key in corner of motherbord.
Some smps has switch in back side of it.
Mar 26, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Bestec atx-250-12z rev d hp model 5187-1098 pc will not start up when pushing button on front of machine green led on back of p/s flashes with power cord plugged in. does this indicate a p/s failure?
I have already replaced mant Bestec ATX-250-12E power supplies because they have an internal failure. Consider yourself lucky if the thing doesn't power up your computer because it has a problem of imposing the +12 volt line onto the +5 Volt line then blowing out the mother board. Sometimes you aren't so lucky because once the damage is done then it is to late to just simply replace that piece of junk. I was lucky with my daughters E-Machine because if she tried pressing the start switch on the front of her computer it would sometimes come on and sometimes not. She just mentioned this to me and I immediately replaced that Bostec ATX-250-12E before it could do any damage to her computer. If anyone has an older E-Machine or an older Gateway machine then it would be a good idea to see if it uses that Bostec-ATX-250- 12E. If it does then go order another power supply, anything but a Bostec, and instead of a 250 watt order a 300 watt or better. I hope that this has helped those that might have this problem before it destroyes *********** boards. Marty
Mar 23, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Computers & Internet Logo
571 people viewed this question
David Payne
David Payne
