Question about HP LaserJet 1320 Printer
Hp laserjet 1320 has no power at all.
I have an hp laserjet 1320 that has no power at all and keeps blowing fuses.Could this be the ECU? I've put in 2 fuses and it blows them right away.Is there a way to know for sure without swapping the part? Thanks for the help.
  • robcrazee Oct 14, 2008
    Thank you for your input. We checked to insure the fuses are the same. They are. We went ahead and ordered the power board. Will see what happens!
Try connecting the printer to a circuit board (one with a circuit breaker) to ensure overvoltage is minimised. Next check that the printer has the appropriate power setting (220v/110v Depending on your area.) Ps- not all fuses are the same , if you have the original 1 look on the adaptor and it will say 220/110V at ?A thats the proper fuse to get ,if you replaced a different fuse (lower rating) it will go out instantly.if the fuse still goes out you will need to ask Hp for a replacement adaptor for your printer.(if none is available you need to either take it to hp (costly) or buy another printer .
Hope it helps
Posted on Oct 14, 2008
Hp 1320 printer not showing any signal light (what is the problem)
have you check the power source? if there is no light on the machine you have to bring out the power supply to test the fuses.
Apr 22, 2013 | HP LaserJet 1320 Printer
My hp laserjet 1320 printing is printing too slow
If you're running a Mac, when you try to install the LaserJet 1320, it may suggest that you use the driver set for "HP LaserJet 1320 Foomatic/pxlmono." Do not use those settings. I had to reinstall my 1320 recently and since it said that was the recommended choice, I selected it. If I printed just text, it worked fine, but even a tiny 50KB image would take 5 minutes to print. When I reinstalled it again, I selected the option "HP LaserJet 1320 series," and everything works just fine now.
Apr 12, 2012 | HP LaserJet 1320 Printer
My hp 1320 laserjet printer is not powering, i open the printer and check the wiring and i see everything normal. try to check if they are properly fitted and did not see anything improper.
Hello:
Check the main fuse if the unit blown especially if the unit is totally dead meaning no light on the main panel comes on. You may of had a power surge that blew the fuse. If you find the fuse good and the unit still does'nt power up then you have a power supply problem or something external of the PS is loading it down.
Sep 22, 2011 | HP LaserJet 1320 Printer
LaserJet 5550dtn Printer: blows mains fuse and power supply board fuse and b...
The fuse blows all time on High Voltage Poewr Supply, on HP Color Laserjet 5550dn,
May 16, 2010 | HP LaserJet 5550dtn Printer
Hp laserjet 1320 is not powering
there is SMPS power supply problem so u repair your SMPS power sypply
Apr 12, 2010 | HP LaserJet 1320 Printer
Hp Laserjet 1320 toner rubs off page
when the toner rubs off means it wasnt fused which means you need to replace the fuser
Feb 27, 2009 | HP LaserJet 1320 Printer
HP Laserjet 1320 Printer
Hello
Please note: Instructions only applicable to the network printer which supports telnet protocol.
HP Mono and Color LaserJet Network Printers - Sleep Mode Problem
Issue
Network printers may not print when a job is sent to the printer while in sleep mode.
Solution
Please follow the steps below-
1. Connect the printer to telnet- Using command prompt.
2. Type telnet > IP address press then enter.
3. Type menu and press enter.
Following screen will appear-
4. Choose option 2 TCP/IP menu and press enter,
5. Choose option 5 TCP/IP other settings and press enter.
6. Type y in front of cursor and carry on pressing enter until you reach “SLP keep alive”. By default this value may be 0.
7. Change this value to 1.
8. Exit and save settings.
- Nikhil
Mar 04, 2008 | HP LaserJet 1320 Printer
Problem in power supply
you changed the cord or the power supply?
Oct 23, 2007 | HP LaserJet 1320 Printer
Paper jams
check the feed roll
Oct 05, 2007 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
506 people viewed this question
Seeker5211
Seeker5211
