Question about HP LaserJet 2430dtn Printer
My HP LaserJet 2430dtn Paper jam
I'm having a problem with my HP 2430 jamming on every print job whether it be one sent from my computer or just doing a config print right from the control panel. The jams occur from both tray 1 and tray 2. When it jams, the leading edge of the page is always stopped just before reaching the transfer roller assembly. I've checked the paper path for obstructions but found nothing. I also checked all the paper p/u rollers for dirt, signs of wear, or damage but they all look fine. I'm kind of leaning towards the registration roller assembly being the problem. It seems that when the paper is going in from the MP tray, it gets picked up fine. But once it enters the printer and right about when the registration rollers are supposed to take over, there's almost a "struggle" for the page to continue and then the paper jam message pops up. So if anyone out there has any ideas or has any experience with this problem, your help and input would be appreciated.
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Try this, make a print from the by-pass tray, does it go OK or jam??
If it jams then there is a problem with the paper feed from the tray.
If it jams then
1-check the drum and see if there is an image on it( you can put a mark on the edge to see if it's rotating, thus eliminating the drum unit)
2-same for the reg roller
3-check for labels ar foreign objects
Posted on Oct 10, 2008
My HP 2430 continues to jam on Tray 2 only. Tray 3 and Tray 1 (manual feed) are fine. I have replaced rollers and it continues to jam paper.
Common problem on this printer is for either the drive shaft for tray 2 to come lose or to break. Pull out the tray and try to rotate the roller. If it turns freely then the shaft is broken. The replacement procedure is too complex to describe here. If the roller does not turn freely then likely the pick solenoid has failed.
Oct 12, 2016 | HP LaserJet 2430dtn Printer
My hp `2430dtn is printing lighter down the right side of the paper
Fist step check with new cartridge, clean transfer roller, clean Laser scanner assembly, check fuser..
Sep 07, 2011 | HP LaserJet 2430 Printer
It gives paper jam
Because the solution fix is very long i to post here 2 links.
1-Troubleshooting a 13.20 Paper Jam - LINK.
2-Clearing Jams - LINK.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 01, 2010 | HP LaserJet 2430dtn Printer
What is a solution when hp laserjet printer1000 series has the problem of paper jam ?
Open the cover, pull out the cartridge and take a look inside for paper cuts or something.
Sep 28, 2009 | HP LaserJet 1000 Printer
HP 2430 jams from optional tray 3 only.
Hi Rich,
I've had this problem too. I believe it's the post that holds the drive gears wears or becomes loose causing timing problems.. Unfortunately there's no spare parts available for the optional tray. You would have to purchase a whole optional tray.
Mar 11, 2009 | HP LaserJet 2430dtn Printer
My HP Laserjet 2430dn makes a grinding noise after power on.
Feb 26, 2009 | HP Office Equipment & Supplies
hmmm...sounds like maybe you'll need new drivers? is your new computer vista by chance?
Jun 16, 2008 | HP LaserJet 2430dtn Printer
HP LaserJet 2430dtn printer
what kind of problem??
jams or it won't duplex, what?
Jun 13, 2008 | HP LaserJet 2430 Printer
Have you checked the settings on the printer's menu. It should be under paper handling.
The printer is noisy when printing
all printers are noisy  ,and repetitive it could be the toner
Oct 25, 2007 | HP LaserJet 2430dtn Printer
HP LaserJet 2430dtn Printer Logo
801 people viewed this question
Ben Johnson
