Question about Insignia 42" LCD Flat-Panel HDTV
NO PICTURE BUT I HAVE SOUND 42" INSIGNIA/PRIMA
LOOKS LIKE A COMMON PROBLEM. CAN ANYONE BE KIND ENOUGH TO LET ME KNOW WHICH BOARD I SHOULD BE LOOKING FOR TO REPLACE OR REPAIR. I CAN REPLACE CAPS IF THATS THE PROBLEM. I KNOW INSIGNIA AND PRIMAS ARE THE SAME BECAUSE I PULLED A FEW FROM A DUMPSTER WITH BROKEN SCREENS AND TOOK THEM APART. JUST MY LUCK ..I CLEANED HOUSE AWHILE BACK AND TOSSED ALL MY SPARE PARTS.
  • 4 more comments
  • craigedwards Oct 08, 2008
    MY MODEL IS PRIMA PS-42D8C MANUFACTURED 2004.
  • dodo4bird Nov 05, 2008
    Does anyone know a part number to replace this? Or a website?
  • firehog Nov 23, 2008
    42 lcd with no picture but have sound.
    replaced the lcd control board but did not fix the problem. Can anyone tell me what i should replace next. a part number woul be great. it is an insignia 42" lcd.
  • tasty11 May 08, 2009
    my insignia model nslcd42 when i turn it on the picture shows for a second, and then it goes out and it is just a black screen, i can hear everything but cant see anything
    when i turn my tv on its an insignia 42" the picture shows for only a secondand then the screen goes black i am having the same problem could someone help me with this
  • 1970gizmo Apr 24, 2010
    I have the same problem. Where did you get the board?\
I just repaired the TV.. It's the main power board that's causing the problem.The biggest board in the TV. I took a metre to the old board and it's failing on the VS circuit. I was only getting 14volts when i should of been getting 78 volts or something like that. If you look on aluminum backing of the screen .. top right corner there's a sticker which tells you what the voltages should be for the VS and a few others. It's the 10 pin socket top left corner on the main power board. VS is the first 2 pins. That's the part of the cuit that caused the screen not to light up. I had audio and power but no picture. All the other readings I took were normal on the board that was failing. Only the VS reading failed with the 14 volt reading. I put in another a good used main power board and took a reading from the VS pins and it was normal. I connect the cable to the y board and the TV powered up and is displays fine. If there's someone who does work on low level cuits and finds the actual part that is failing I would like to know. I replaced my board with a known good one and traced it too which part of the cuit failed. I suspect it's just buying time and don't plan on spending another $100.00 on another board after this one. So any help would be great. Thanks for all Craig
Posted on Oct 09, 2008
Insigna ns37d20sna14
Common problem is this series is the power board fails. Unfortunately it often takes the main board as well.
Aug 31, 2016 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
42" INSIGNIA/PRIMA We lost the picture and then 20 min later lost the audio. Changed the main power board, got the power light back but still no audio or video. Any ideas?
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 26, 2014 | Insignia 42 Class 1080p LCD HDTV
Electronic tech needs help this tv only half of picture is showing what could be the problem i wants to fix it myself
Hello Danyell,
According to the model number you provided you have a 42" Insignia plasma TV. The problem you reported with having just a blank black screen on the lower half is due to a bad lower buffer board or also called a lower scan board. The part number is LJ92-01739C and if you Google this part number you can find these online and also find some sites that may show a short video on how to replace it. Price of this board looks to be about $35. Also of note is you will find that this part number is a Samsung part number which means your Insignia TV has a Samsung plasma panel in it so the associated circuit boards will also be Samsung parts.
May 02, 2014 | Insignia 42" Flat-Panel Plasma HDTV
No picture with sound
Check the fuses on the Y- sustain and Z-sustain modules. which ever is blown, that board is your problem. Y is on the left and Z is on the right. ( looking at it from the back )
Nov 22, 2010 | Insignia 42" Flat-Panel Plasma HDTV
We have a 42'' Prima that has no picture, screen is black but we have sound
One of the drive board went bad, unfortunately, Prima is not in business any longer.
Nov 07, 2009 | Televison & Video
Tv picture looks grainy like it was shot on video
well most lcd and plasma tv's above 36" will look grainy on standard definition because they are made for high definition so if you do not receive a high definition signal to your tv then that would most likely be the problem
Sep 12, 2009 | Insignia 42" LCD Flat-Panel HDTV
Cracked plasma screen
honestly probably not worth it
May 31, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Sony Tv PFM-42 V1 doesn't show any picture or tv menu
This is a common problem with plasma tvs You did not mention whether you could generate any sound like through your dvd player or something like that. Whether you have audio or not makes a difference on which board may be causing you the problem. Just because it does not have a picture for tv viewing does not mean it won't produce some type of sound through your av1 input. Try it and I'll try to be more specific.
Jan 06, 2009 | Sony PFM-42V1 42 in. HD-Ready Plasma...
No picture
btw for anyone experiencing these problems with the infamous "is-lcdtv32" byd:sign is the same manufacuterer as insignia, its the same company with a different sticker. i know this isnt a solution, but parts for all discontinued insignia';s can be purchased thru byd:sigh(by design). hope this helps .
Oct 06, 2007 | byD sign d:4232 42 in. HD-Ready Plasma...
Prima plasma tv model ps 42t8
there is a kit for prima 42 t8 from lg electronics i just fixed my prima last week cost under 200 canadian dolars kit is avalable from england on ebay plasma parts uk kit no lg philips pdp v7 tv repair kit email me at mpasarich1@sympatico.ca to see if you have it fixed
Sep 19, 2007 | Televison & Video
Insignia 42" LCD Flat-Panel HDTV Logo
953 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
