Question about SMC Barricade g SMCWBR14T-G Wireless Router (SMCWBR14TG)
SMC Barricade g SMCWBR14-N Wireless Router... router Configure with Westell 327W
This an SMCWBR14-N Wirless Router.
I am unable to configure the router with a AT&T DSL Westell 327W router/modem. The 327W works properly when hard wired to the computers but the wireless sucks.
I have bridged the Westell and conneted the LAN from 327 to WAN connection into the SMC. I have configured it and I see all the netowork (IP, Gateway address) and my computer mac address in the Status window of the SMC. However, when I click the browser either I can't acces any web pages or an AT&T Password window pops up. Tried resetting the password but the AT&T tool fails. I have spoken to SMC & AT&T tech Sppt and both say it's a problem with the other equipment. One of the senior AT&T analyst said that it is a 327W Wireless router. She said that I have to order their regular modem for $75.00 for the router to work and she said she cannot promise it will work. The SMC is set PPOE.
Thanks, Steve
    Novelist:
  • 143 Answers
It seems that the router capability of both devices are conflicting with each other so below are the steps that you can try to setup the two devices to work with each other.
i assume that you are using pppoe connection from at&t and you are using a connection manager. if so, with the current setup that you have right, you need to disable the connection manager on your computer (network connection, disable at&t connection) and set the connection of your web browser to "never dial a connection". check now if you will be able to connect to the internet instead of being prompted for a password. if your problem is still the same, try the steps below.
configure the westell 327w the way it was before (when it works properly when hard wired to the computers but the wireless sucks) but disable the wireless capability. change now the ip address of the smc router from it's default (192.168.2.1) to an ip address which is on the same segment as the ip address of the westell 327w (ex. 192.168.1.2 if your westell 327w is using the ip address 192.168.1.1). disable the dhcp of the smc router (note:make sure that you have configured all the settings that you want to configure with the smc (i.e. wireless settings, port forwarding, etc). then connect the westell to one of the LAN ports of the smc (note: with this setup, the wan port of the smc should not be used) and power cycle everything and check if this setup will work.
hope this'll help you and just ask me if you have other concern.
ciao!
Posted on Oct 08, 2008
I use Wireless router Model: SMCWBR14-G2. My Office is use Staitc IP for Staff and DHCP for Customer. But DHCP is well work, static is not. I Re Configure this router. It is Ok!. But Gtalk can not use by...
We have used gtalk with static ip number. Sounds more like the port it uses isn't open. It could be that they block the port at your office. When using static ip numbers the gateway must be the number of the router in order for it to get out to the internet.
Mar 18, 2011 | SMC Barricade g SMCWBR14-G2 Wireless...
I want to know how to configure my smc router to the network ?
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Aug 19, 2010 | SMC Barricade g SMCWBR14-G (662698582192)...
Smc setup cannot be accessed but have network
login to your router and go to wifi and check for the mac address of your laptop, if its require to change anything do it according to it.
To know the mac address of your laptop go to command prompt and type --> getmac
Mar 11, 2010 | SMC Barricade g SMCWBR14-G (662698582192)...
Computer wont recognize cable hookup
You will have to start the configuration from the wired network rather than the wireless network. Connect the computer directly to the router. I am assuming you might be trying to configure the router from the wireless network. Then use the installation CD to configure the router
Nov 29, 2009 | Computers & Internet
Cant put a lcok on my smc router
Manual for WBR14-G2 router [6.2 MB] in pdf format:
http://www.smc.com/files/AG/MN_SMCWBR14-G2.pdf
Keeping others from connecting to your router:
1. Have an "wired only" router login access or for this router "change and disable your SSID". This way you avoid that others can login to
to the router changing your settings: See page 48 of the manual.
1.1 Wireless Network Name (SSID): change the default name SMC
to "any private name" ( and remember for later login )
1.2 Broadcast Wireless Network Name: change from default ENABLE
to DISABLE .
2. Make a secure wireless encryption key for your connection:
see page 87.
2.1 For most secure key select WPA / WPA2 only and SAVE SETTINGS .
2.2 See page 91 for entering and saving your secure key: the password
that must be entered to get access to the router.
Sep 18, 2009 | SMC (SMCWBR14-G2) Router
SMC Barricade g SMCWBRT14T-G router
You need to open the port that Utorrent is using check this link for the step by step way on how to do that on the utorrent and on the router http://portforward.com/english/routers/port_forwarding/SMC/WBR14T-G/Utorrent.htm
Hope that helps..............
Aug 08, 2008 | SMC Barricade g SMCWBR14T-G Wireless...
Won't connect
http://www.smc-asia.com/download.php?Fullkey=50&Class=4
this url for mamul of your configuration so download the mamul and configure it
Jun 19, 2008 | SMC Barricade g SMCWBR14-G (662698582192)...
HOW TO CONFIGURE THE ROUTER
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly
connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
May 08, 2008 | SMC Barricade g SMCWBR14-G (662698582192)...
Firmware updates
According to SMC, there are no firmware updates for that product.
Jan 17, 2008 | SMC Barricade g SMCWBR14-G (662698582192)...
SMC Barricade g SMCWBR14T-G Wireless Router (SMCWBR14TG) Logo
713 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
zappal
Level 1 Expert
Clive Gray
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
