Question about HTC Touch Cell Phone (Unlocked) - Soft Black
Htc touch phone
My htc touch phone got wet. i dried it out and now screen comes on and has sound but touch pad will not work.
  • 2 more comments
  • Anonymous Oct 11, 2008
    I dropped mine in orange juice..don't ask how lol. The phone comes on but screen won't work half the time!! Don't know how to fix it tho.
  • roshan00732 Oct 15, 2008
    my phone unlock
  • Anonymous Oct 25, 2008
    not getting any sound at all incoming calls.
  • Anonymous Nov 30, 2008
    Dropped in water sometimes turns on when it does the screen doesnt work
Iwant to formet the htc
Posted on Oct 15, 2008
How to fix htc inspire 4g scren got wet
Best option is to take the back cover out and use a hair dryer at medium setting to dry out the moisture inside.
You could also take the pcb out to expose the screen module behind and use the dryer on it. Would not suggest if you are not comfortable with working on miniature electronics. Need good tools.
see this Youtube video.
How to replace HTC Inspire 4G Touch and LCD Screen Assembly by...
Aug 21, 2014 | HTC Inspire 4G Smartphone
G1 got little wet but it dried out and screen shows all but now triangle and cant get touchscreen to work....what do i do?
If it got wet it might still be wet from the inside and that is why your touch screen wont work, You would need to open it and clean it from inside. Or it could have a bad digitizer and that is a second reason why the touch screen wouldnt work. You can try doing a hard reset if you says it just shows a triangle on the screen.
Turn the G1 off. If it’s frozen on, take the battery out and put it back in the unit.Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle
Now to wipe the device clean:
Press Alt+L. Press Alt+W for a factory reset.
Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
Jun 15, 2010 | HTC G1
Touch screen has stopped working and phone sometimes locks up :(
That happened to me and my htc touch hd the other day. I tuned it off, pulled the battery out and let it dry out completely. The touch screen didn't work until a few hours later. However when water happens to an electronic device it usually will need to be replaced. Just cross your fingers and hope for the best.
Mar 28, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
The touch pad of HTC Touch responds intermittently.
hi, its a error in the phone, I had this happen to mine. You will most likely have to sent it away for repair. Just reflash the stock ROM and make sure that you have reflashed the stock SPL if you where using hard SPL and you will be ok this site will help you flash: http://lievenvw.wordpress.com/2008/09/18/howto-flash-your-htc-diamond-or-htc-touch-pro-with-a-custom-rom/ thank you
vijay
(vote for me)
Sep 23, 2009 | HTC Touch P3450 Smartphone
My LG Renoir was mistakenly wet by tonic water droplet, and as a result, the touch screen is not responding perfectly. What can i do, i blew dry it with hair dryer, but it still wont work well. When i...
i have had this problem also but not with it getting wet. i have bought a new digitizer (touch pad which you can get of amazon by looking for a lgkc910 digitizer) i am yet to have it replaced but if it doesnt come down to that i think it have had damage to the motherbord or needs software updates
Aug 04, 2009 | LG KC910 Renoir Cell Phone
My LG secret got damp,but it was working until tonight,now the screen wont come on,plus before it was turning off ramdomly,putting my calls on hold whilst I was talking and when I plu earphones in,it wouls...
hey,
I've had the exact same problems as you, i've found that when the touch pad becomes wet the phone would start to do some weird stuff like make the down pad go up.
I advice you to not turn it on at all and try what you can to dry it up, turning the phone on while it's still wet will fry the components inside. Also don't put a dryer too close to the phone or else you want a multicoloured screen.
if none of this works you have n option but to phone your retailer.
Jun 17, 2009 | Lands Phones
Screen locked on my htc mp6900. I don't know how to unlock it because the touch screen is not working. How do I get the touch screen to work?
You probably need to replace the digitizer pad. That's the outer screen. The actual touch screen. I did mine today, works great!! Easy to replace on your own,also. I got it for 11 dollars on dealxtreme.com good luck!!
Apr 20, 2009 | HTC Touch Cellular Phone
Htc touch screen not working.
Hi, I had the same problem. Whenever, I touched my screen the wrong things would respond, then finally one day my phone locked & when I tried to unlock it the screen wouldn't respond at all.Took my phone to 3 sprint stores and all the techs couldn't help. One even accused water damage or overheating because they saw spots under my screen. But I never wet my phone so I thought it might be overheating since I do live in a warm climate. They all tried to get me to buy a new phone, which seemed like a scam. I didn't want to hard reset & lose all my data so I looked closer at the screen & noticed the spots didn't look like water spots & peeled the screen back. I noticed that the glue from around the screen actually leaked onto the screen, so I dampened one end of a q-tip & wiped the glue off the dryed it with the other end. I turn the phone back on and the screen worked fine. Try cleaning thr screen before doing a hard reset or paying for a replacement phone. It'll save you time & headache.
Hope this helps =)
Jan 09, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Problem in touch screen
My HTC touch has lost the sensing of touch screen - looks like the touch pad is locked. Can we unlock the touch pad..
Nov 02, 2008 | HTC Touch P3450 Smartphone
HTC Touch Cell Phone (Unlocked) - Soft Black Logo
156 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
