Question about Canon PIXMA MP460 All-In-One InkJet Printer
Paper jam in Canon MP460 printer
Paper jam error but no paper in it.
  • 3 more comments
  • Anonymous Nov 25, 2008
    I have the same damn problem...no paper in it but it says clear then paper jam and press ok
  • bbchris1 Nov 26, 2008
    I have the same thing and I cannot turn it off - there is no paper jammed in it. ALso wont even scan now.... useless
  • Anonymous Nov 26, 2008
    yes i have the same problem can someone please give a solution..
  • Anonymous Dec 13, 2008
    Same problem as me, I had a paper jam, cleared it and it won't work. I keep getting the paper jam message.
  • Anonymous Apr 09, 2009
    i have the same problem i do not no no how to feed paper threw and it nevver work
This can be fixed at home. It's a design flaw that locates a little paddle right on the edge of an infared light beam when the paddle is resting where it should be when no paper is in the printer. If they had extended this black plastic paddle ever so slightly toward the front of the printer, it would surely interrupt the beam as it is supposed to do. Raise the platten section as if you were going to change the ink cartridges. Locate the white plastic plate with 8 little white rollers along its front edge. About 1.5" from the right edge of this plate is slot about .25" wide, just under a metal bar going across the printer. Down in this slot is a little black plastic finger that gets lifted up when a piece of paper goes through. This little finger is the lower end of the paddle above. Poke gently on this little finger with a little stick or dowel rod. Make sure there's no paper under it. Put the lid down and try it. If still giving the paper jam error, you'll have to take the whole blooming cover off to get to the paddle. I put a piece of black electrician's tape over the paddle to extend it forward to be sure to interrupt the beam. The key to opening the cover is to start with the gray plastic pieces on each side. They move down toward the floor about 1/8" to come off. Be gentle. Try never to tip the printer on its side ink will run and make a mess. I highly recommend a pair of rubber gloves once inside -my fingers got green ink on them and it doesn't come off. Good luck.
Posted on Aug 21, 2010
  • Dennis Jansen Aug 22, 2010
    Hello Greg,
    Thanks for your answer and help. Can you give me more information how to open the printer? I dont really know where to start and what to take off in which steps. And I dont want to force anthing. Thanks in advance
I was having the same problem. Talk about frustrating. Sometimes up to 45 min of dicking around to get it to print one page. Here is what I did. And I know it sounds crazy but it worked for me....
SOLUTIONL: Cancel any currently pending print jobs. Press the settings button. Arrow down below the paper type setting (currently set to "Plain paper") and change the speed from "Standard" to "Fast". This did the trick for me and now I am feeding paper and printing like a mad man.
It really doesn't make complete sense to me why this would fix the problem and why so many people are having the same problem... but my rationale is as follows.... This is happening to many people ... not merely an isolated incident... so most likely this is an engineering defect. Something in the way they designed and built this thing is less than perfect. I am guessing that somewhere within the firmware that runs this printer there is a section that says start counting the number of milliseconds from the time the paper feed is started until it is place to begin printing (probably a sensor somewhere), and if too much time has passed then there must have been a paper jam. This allotment of time may have been set to a very small window of time...(tighter tolerances usually means better quality, but not in this instance.) So by setting the speed to "Fast" we are able to get the paper in position before the window of time expires.
Posted on Jan 03, 2009
I have MP460. It can't load paper and all it does is to fail to load papers while making a loud hammering sound like it normally does. I pressed menu on the printer, go to settings then pressed clean the roller and it started to work again perfectly. It is as good as new and like is now printing like a mad man.
Hope this solves your problem to. Good luck.
RNG
Posted on Sep 13, 2010
I'm having this same problem: it's giving me an error message saying that the paper is jammed and i need to fix it and press OK. well, i fixed it, and it continued to give me this error message even when i removed all the paper, put in new, less, or more paper... it just keeps telling me the same thing. i can't even use the scanner because all it cares about is this stupid imaginary paper jam. in a fit of rage i was mashing in the 'reset' button and for a moment it appeared i had fixed it, but when i went to scan something the error message popped up again. i'm about to throw the damn thing out the window. what do i need to do?!
Posted on Apr 18, 2010
Go to Menu, Settings, and then click on Reset Settings. Doing that within 2 minutes of looking at the printer, after my mother took half an hour looking through EVERY setting, I feel like a God.
Posted on Nov 17, 2010
Jai le même probléme et je pense l' a démontée
Posted on Dec 30, 2008
pineworks
  • 4041 Answers
SOURCE: My canon ip2600 printer has a paper jam error, but there isn't.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
  • 1382 Answers
SOURCE: I have a canon mp460 pixma printer that
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Posted on Jul 08, 2010
shaggyrat
  • 1224 Answers
SOURCE: canon pixma mp460 code error 6000
Solutions for error 6000 Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1. Press ON/OFF switch to reset the multifunction device 2. Removing paper jams MP450 / MP460 3. The MP460 may require repair
heres the problems currently with mp460 and at bottom is the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
this is the solutions for the mp460
for the guest
clean out your ink absorber after unplug
reset printer you still have a little credit card sized paper in your printer that you need to remove it
Posted on May 21, 2008
jonb3838
  • 237 Answers
SOURCE: My MP460 printer wont grab paper and feed through
It sounds like the pickup rollers are worn or damaged and would need to be replaced
Posted on Feb 11, 2009
SOURCE: removed paper jam, but get
how to repair paperjam error
Posted on May 12, 2010
Paper iam
open the printer back cover and remove paper from it
May 23, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Service error 6000
for the guest
May 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP460 Paper Jam
this is only a possible solution.make sure the paper is between 17  to 24 pounds thick.i once had a jamming problem and it turned out to be the printer which canon replaced under warranty.but in the process i learned paper thickness can make a difference. i was recommended 20 pounds by a staples employee.i hope this helps you.
Apr 07, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Feb 11, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Paper jam in a mp460 printer(canon)
clean up the roller that picks the paper up.
Jan 30, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Canon pixma mp460 code error 6000
for the guest
May 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Mp460 canon all in one
Same problem .Alarm light on and paper jam advice on the screen. No paper there...
Apr 08, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
5,550 people viewed this question
old marine
old marine
