Ican find the wireless router from ny laptop but i cant connect to it
  • 39 Answers
What kind of router is it and do you know that the router uses a ip address for the settings?
try 192.168.0.0 or 192.168.0.1 these are the default ip address most use.
Posted on Oct 08, 2008
For clarification, what OS are you using? If you are using Windows 2000 or later, it should ask you for a WEP key and the SSID. Both of these numbers are available on the bottom of your router if it was provide by your ISP (such as with Verizon, Comcast or Time Warner).
Latitude X1 PC Notebook: I just used ny Dell Latitude X1 to add a new lapto...
If the other laptop can't see the network, then it sounds like you somehow turned off SSID broadcasting while you were in the router's settings. Log back into your router and look for the SSID broadcast enable setting. Make sure it is set to on, then save the changes and reset the router if you have to. The laptop should be able to see it now. (There is also a setting in the Windows wireless network properties that you can check to connect to a network even if it is not broadcasting, as long as you have connected to it previously.)
Hope that helps!
May 17, 2010 | Dell Latitude X1 Notebook
Cant connect ,no light on wireless connection. was
you need to setup the wireless connection if you havent already and your router needs to be a "wireless" router in order to create that type of internet connection. Have you laptop then scan for one which would be the one you just made and input the correct information to connect. If that doesn't work I'd suggest getting a new wireless router
May 06, 2010 | Belkin F5D8236-4 Router
Our wireless net work comes up but we cant connect to it why?we have a wireless g wgr614v9 router and we cant log on to it with the passphrase
The Netgear router needs the wireless settings configured i.e SSID, WPA encryption etc and the wireless card in the laptop/computer needs to be configured with the router's wireless settings for the laptop/computer to connect with the Netgear wireless router. Pleas click on this link and follow my instructions to secure your wireless network, configure the wireless router's settings and configure the wireless card in the laptop/computer :-
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 21, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
I cannot get Internet access with a secured wireless connection
tell me more.. who is your provider and what router/modem doyou use?
you can try to contact me directly.. mage0213@aol.com if I can't help here.. I may need more information before Ican offer a solution
May 05, 2009 | Kenwood KDC-MP235 CD Player
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Cant connect to wireless router
Make sure the wireless adapter is enabled on the elonex laptop and its properly installed.
Connect wirelessly on the elonex one laptop using the same SSID and security key that you used on your main laptop.
Aug 07, 2008 | Belkin (F5D7230-4) Router (587009)
Wireless ready laptop not getting connected to internet through belkin router
You may want to check if the wireless switch is "ON"
on the laptop most wireless ready laptops has either a
button or toggle switch to enable the wireless radio..
if it's already enabled and you still cant connect to
the wireless network,try changing the wireless channel
from the router.
Jun 19, 2008 | Belkin (F5D7231-4) Wireless Router
I have internet service with you. I want to know how do I get service for ny laptop
You can purchase a wireless home router and share your current internet connection between both computers. Most routers will cost less than $100, and will provide both wireless and wired connections on one device, so there would be no need to convert one of your computers.
All you have to do is connect your modem into the router's internet port, then plug your main computer into one of the other available ports. Setup your laptop to access via wireless, following the instructions in the user manual of the router, and you will be all set.
If you have anymore questions, please ask.
May 04, 2008 | Computers & Internet
MY LAPTOP IN NY LIVING LOST ITS CONNECTION TO THE ROUTER..BUT I SAW A DIFERENT ROUTER NAME...WHAT DO I DO NEXT?
It sounds like your running wireless. Go to where you saw different router name. It probably should be an icon on your taskbar. If this is the case, right click on the icon and clink on show available wireless networks. Yours should be listed. The laptop may have connected to someone elses or a wireless nic card you have in another pc or someone's close bt. Just click on your network and say connect. This should fix your problem. Any other questions just add a comment and I'll be glad to come back and help.
Mar 21, 2008 | Computers & Internet
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
