Question about Garmin Forerunner 301
Forerunner 301 lcd replacement
My 301 was dropped and the LCD cracked. The unit still works but the display is not readable and has a black spot near the crack. Can the LCD be replaced? If so, at what cost? Would it be cheaper to just buy a new 301?
eMitH
  • 22 Answers
SOURCE: garmin forerunner 301
hi
the garmin gps often use a soft rubber in their contruction
either wait til the unit is out of the heat or use a bit more pressure to push the button doen firmly
the map60 range has the same issue with the power on/off buttons
there is no replacement parts as its built into the case
D
Posted on Nov 21, 2007
  • 43 Answers
SOURCE: Garmin nuvi 350 - broken screen
If the LCD is actually leaking (big stain on the screen) then it cannot be repaired, only replaced.
Replacing an LCD is a relatively simple job on any GPS, it is normally just a case of opening the casing, disconnecting the ribbon cable on the old screen and putting the new one in its place. As long as you are careful and put everything back where you found it then you should have no problems.
You can check all the parts suppliers in your area or online for a new screen, but for the lowest cost solution I would suggest searching ebay for a faulty nuvi 350 with an intact screen. If you can find one you will probably get it for less than the cost of a new part, plus whatever bits you have left you can always resell. There are always people wanting to buy spares for satnavs.
Posted on Dec 07, 2007
SOURCE: Change battery on Garmin Forerunner 301
Hi - look at this solution for a forerunner 201, which has the same case design. I was just looking myself! R_nz Rank: Apprentice Rating: 96%, 8 votes I've made some progress here, I discovered that there is a small notch beneath the flat black pastic insert that holds the rubber button cover in. By gently prising this out, I can at least expose the pcb with the buttons on. I still can't figure out how to open the case though ****! Comments: Jan 29, 2008 - Well, I got there in the end! As above, I managed to prise the plastic insert cover off the rubber button cover, the peeeled this off as well. Underneath is a mylar printed circuit with the silver domeos of the buttons moulded in. This is siliconed down, but you can peel it up with a fingernail. The top left end (above the on button) is aatached inside the case, so start at the other end. Jan 29, 2008 - .ctd.. Once you have lifted the mylar strip, you can get at the case seam underneath and prise it gently open with a flat blade. The case is glued together with a light silicon or something. My problem was unresponsive buttons and by detaching and then re-attaching the small connector by the big silver block where the mylar attaches to the main board and then re-attaching it, it seemed to fix it! :-) Oct 22, 2008 - As an end-note; I glued my 201 back together with a light Silicone sealer. It seems to be at least rain proof anyway. Forerunner 201 battery replacement (Expert level): Opening the 201 was not easy and could not be done 100% clean, but thanks to R_nz (above) I got it open. My problem was dead (almost) battery, after 6 years of superb operation. I found the battery to be glued (double sided tape) to the back cover. To remove, push it up slowely and pull out. Beware of the short wires. 1. It is a flat battery, wrapped in shrinkable tube. Made by MDTechnology, P/N 043048 3.7V, 500mAh see http://www.mydbattery.com/EN/products.asp?ID=12 2. On the cover, the battery is soldered to the underside of a small PCB, hard to get to (by expert!). If you find a battery, suggest to cut the wires and solder wire-to-wire. Hope that helps
Posted on Jul 08, 2009
  • 4 Answers
SOURCE: Cracked LCD screen for Garmin Nuvi 255w
Hello
Try here www.satnavrepairservice.com
Posted on Aug 04, 2010
  • 1082 Answers
SOURCE: How much does it cost to replace the LCD display
Unless it's under warrenty, it's cheaper to buy a new one.
Posted on Nov 19, 2010
Growing Black Spots on Insignia LCD Flat Screen
Black dots/spots on an LCD panel display indicates either a dead pixel or a stuck pixel. Alternately, if you press lightly on the black spots and they go bigger/darker, then in some instances, it could be that the frame holding the display has been slightly warped when too strong a pressure was applied when it was being cleaned. Should this be the case then corrective measure would be to disassemble and flatten whatever area was dented. Some have reported success with the use of a suction cup. Perhaps this, this or this might be interest you.
If the unit is still under warranty, please try discussing your concern with your dealer. Though a few small spots are an acceptable norm. Alternately and if the warranty has lapsed, there are companies online that offer LCD replacement kits or will replace/fix your LCD and it would cost you less than the cost of a new screen or TV.
Other than the above, am afraid that your options are rather limited.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | Insignia IS 20" TV040919 TV
Black spot appeared on the screen on bottom left side how to clear it
A large black spot usually means the LCD screen is damaged. It may have fine cracks around the black spot. In this case the LCD screen needs to be replaced.
A replacement screen maybe available for your laptop from this WEB site.
LCD screens and Inverters www.lcdparts.net
Feb 12, 2013 | Lenovo Computers & Internet
Broken lcd, how can we go about it.
Call HP to determine if the unit is still in-warranty, and they will be replacing it. Otherwise, you may have to upgrade it through their Out-of-Warrranty programs.
Feb 13, 2011 | HP Compaq Presario V2555US Notebook
There is a black spot on the digital screen. It does not show up in pictures but it is on the digital screen. Any fixes?
Unfortunately this is a permanent damage on the screen display - it needs to be replaced. The LCD glass has a cracked - the black spot is the crack. It should not effect your pictures when you take them.
Nov 12, 2010 | FUJIFILM FinePix Z70 Z71 Digital Camera
My bold has a white screen with a couple black lines going vertically and a black circle/blob in the top right. The phone was never dropped and has no crack in the screen. Please try and help restore to...
You don't have to drop your phone to crack / break the screen. This problem is almost certainly caused by a crack screen. This can be easily repaired by taking your phone to the local repair shop and getting the LCD replaced.
Depending on where you live and who you know you can get this done for $50 - $100 in North America.
Oct 12, 2010 | RIM BlackBerry Bold 9700 Smartphone
The screen on my Forerunner 201 is suddenly blank. Is charged. Wasn't dropped.
I left the unit on to run the battery down completely, then put it on charger and the screen was readable again.
Sep 02, 2009 | Garmin Forerunner 201 GPS Receiver
Only black spots on screen I dropped it
It seems that the LCD screen is cracked. You can find replacement screens for CANON cameras here:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ViewObjectID=649065
Dec 14, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Screen black
If screen is black on both the playback and camera modes then LCD unit is probably cracked more likely it needs replacement.
Dec 02, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Garmin forerunner 301
hi
D
Nov 21, 2007 | Garmin Forerunner 301
Garmin Forerunner 301 Logo
57 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
