Question about Eagle Seafinder 500c Df Dual Frequency Fishfinder With 5" Color Display Includes Transom Mount Transducer With Speed & Temp
Transducer need a z6100 fish finder transducer manual to install.
ward_knutson
  • 64 Answers
SOURCE: no manual
Here is a link for your fish finder: http://www.eaglenav.com/upload/Eagle/Documents/Manuals/fisheasy2_0143-641_091902.pdf
Posted on Nov 25, 2008
  • 195 Answers
SOURCE: I require a Manual for a Apelco 365 fish Finder
Check out this site, on here they have a download for the manual you require,
www.retrevo.com/s/Raymarine-465-review-manual/id/556ci073/t/1-2/ - 52k - or go direct to www.raymarine.com
Regards
Alan Hood
ami-man
UK
Posted on Mar 12, 2009
  • 8 Answers
SOURCE: I need a manual for Eagle Cuda 250 s/map fish
http://www.eaglenav.com/en/Products/Fishfinders/CUDA-250-SMap/
Posted on May 05, 2009
  • 106 Answers
SOURCE: i bought a fish finder from harbor freight and it
http://www.harborfreight.com/manuals/94000-94999/94511.pdf
Your welcome!
Posted on Jun 04, 2009
tbirdfan1
  • 3051 Answers
SOURCE: fish finder manual
hello there:
here is a link that will help you get the manual u need ok?
best regards micha
Eagle 250 DS - FishEasy GPS safe.gif Learn more about the Eagle FishEasy 250 DS before you decide to buy. Download User Guide and Manual ... fish finder EAGLE FISHEASY 250DS. www.bestfishfinder. ...
www.retrevo.com/s/Eagle-250-DS-GPS-review-manual/id/23493bh848/t/1-2 - 69k - Cached el
Posted on Aug 27, 2009
Manual for Eagle by Lowrange Z-6000 Depth Fish Finder
Hi
The closest manual to your unit that I could find is the Z6100. Hopefully it'll supply some information that is of use to you.
-Steve
http://www.eaglenav.ca/upload/Eagle/Documents/Manuals/Z-6100.pdf
Sep 05, 2014 | Boating
I need to connect a Garmin 160 transducer to a garmin 120 fish finder
If I may inquire, how many pins on the transducer and on the fishfinder.
Hope to hear from you and pls post back the requested information.
Good luck and kind regards. Thank you for using FixYa.
Sep 17, 2008 | Garmin GPSMAP 188 Fish Finder/GPS Receiver
Transducer leaking wax and fish finder say,s low voltage with two new battery,s
you have a bad transducer.. its a direct short if its leaking anything getting way to hot
Oct 03, 2013 | Humminbird Matrix 97 Combo Fish Finder And...
Lowrance Elite 4X fish finder that reads between 1.5' and 2.5'
Hey Anon
The transducer installation is more important than anything.. next to correct wiring! You must make sure the mounting is good,,, if its outside the hull, make sure its sitting 1/16th below the hull with no obstructions.. if its inside the hull, the medium you used to fix the puck to the hull must be porosity free and the puck sitting as level with the WATER as possible..
Now, take the manual to the lake with you and DO NOTHING but read the manual and apply what you read to the unit,,, read -repeat - read-repeat.. forget about fishing... now read-repeat and learn... IF nothing seems to be reading correctly.. its probably the transducer installation.. YOU DID use a/the transducer specifically for this unit!!
Jun 24, 2017 | Lowrance Elite-4x Fishfinder
My depth finder keeps loseing the bottom and just flickers the last reading
Hi, if this happens when stationery check the angle of the transducer, if it only happens when moving check the height of the transducer also. Regards Phil
Jul 02, 2012 | Lowrance Lcx 38c Hd Fish Finder Gps (200...
I have a furuno FCV295 and when I was doing the initial installation set up of the transducer (airmar r299) I accidently chose the wrong settings. How do I re-do the transducer settings? The factory reset...
If you reset it and while in the Initial Settings" Menu, you press menu, it should take you to the transducer setup screen. These menus allow for "Transducer Type" to be changed to your exact transducer. See the "Installation Manual", which is different than the "Operators Manual". Section 3 page 9 and 10. You may have to enter your units of measure (Knots vs MPH, etc), and then it will allow you to choose the transducer type. Hope this helps. John Barry, 847-746-0100, technicalmarine.com.
Jun 19, 2011 | Furuno FCV 295 104" Fish Finder
When we are deep water (500 ft or deeper) the fish finder will display 3.5-10 ft. and won't show the fish or shows tons of fish. Are we able to set the depth that we would like to see eg: if we are...
Im not familiar with your particular unit but you should be using a low frequency transducer for water over 500'; something like a 50 kHz transducer or a dual frequency transducer like a 50/200kHz for detail with the high freq. but increased depth range on the lower frequency. As far as setting it to 250 ft, you should be able to use the range feature and adjust the maximum to 250'. typically the factory default is automatic so it will caonstantly adjust the range based on the maximum current depth.
May 22, 2011 | Standard Horizon Standard Ff520 Fish...
Need a manual
try going to eagles web site and download a manual to your printer. good luck.
May 29, 2010 | Eagle Fish Elite 480 Skimmer Transducer...
Installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Apr 26, 2008 | Lowrance LMS-332C GPS Receiver
Eagle Seafinder 500c Df Dual Frequency Fishfinder With 5" Color Display Includes Transom Mount Transducer With Speed & Temp Logo
37 people viewed this question
Top Eagle Boating Experts
Steve
Steve
ray gallant
Al Toledo
Are you an Eagle Boating Expert? Answer questions, earn points and help others
