Question about Motorola Mobility E51 MD7161-3 Quad Cordless Phone
MD 7161-3 Motorola phone
Our handsets keep saying "ext in use" we don't have any other phones
We also get the message "paralell set"
  • Anonymous Feb 05, 2009
    Me too my phone says ext in use and all the other 2 phones are off i cant call out or recieve calls , no dial tone either
  • Anonymous Mar 05, 2009
    I have the same problem, the screen says PARALLEL SET, it also says EXIT IN USE, and I can't call or receive calls. PLEASE HELP!!!
Hi
I have a Motorola D212 handset that is locked - I cant find the instruction book
can anyone help me unlock it please?
Posted on Nov 01, 2008
Press menu then #
Posted on Jun 07, 2011
I don"t know my handset
go to settings and find out the factory restore option or reset all option put the security code (default should be 0000 or 1234 or 12345 or 00000 or similar combination).
keep voting me it will help others.
Jul 29, 2011 | Motorola Mobility L6 Cellular Phone
My voicemail has been set up, but it will not answer calls.. it rings and then rolls back into the main message for the office
Set your Call Forward Busy/No Answer to go to voice mail ext. as follows: Lift the handset, dial 4 then 3 followed by the voice mail ext. (the number you dial to retrieve voicemail messages). Hang up.
Jul 26, 2011 | NEC Electra Elite 32D-1 Corded Phone
I cant get my motorola w510 to send a text message
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message settings and verify that the message
center number (which is currently in use) is the same number which
is on another phone with the same network (the other Sim should be
of the same network in your area). If it's different, make the changes
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
Jun 20, 2011 | Motorola Mobility W510 Mobile Phone
MOTOROLA KRZR KM1
to fix this problem you will need to contact your network service provider and get them to resend your gprs settings to your handset, this will than allow you to use the requested features on your mobile phone, because it sounds to me as though, either the gprs settings have not been set up or they have been deleted, hope this helps.
Mar 26, 2009 | Motorola Mobility KRZR K1m Cellular Phone
Cant send message cause says capacity full
Call your carrier and have them resend the data settings to your handset
Jan 05, 2009 | Motorola Mobility W375 Cellular Phone
Mitel 5224 keeps flashing message but is no message
This sounds like you have a call back message active on your phone, The callback is a through back to the days before we had Voice-mail, if you wanted a person to call you back you could activate their message light by pressing your message key while the called phone was ringing. To remove the light you would lift your handset and press the message key then select which party you wished to "callback", once the call was answered at the other end the light would be extinguished. Give this a try, I bet you will be surprised at the results.
Jul 16, 2008 | Mitel 5220 IP Phone
Md 481 cardless phone
Phone is most likely broken.
Look on Ebay for a replacement phone system or a good used handset.
Jun 24, 2008 | Motorola Mobility MD481 Cordless Phone
Message Light won't stop
If you have vmail and no msgs and the only light that is flashing is the light at the top right of the display, what that is flashing for is someone set a msg to your phone from another phone on your system. Try this :
without picking up the handset , dial 43 .
the display should show the ext # that set the msg and an option to reply or clear . press the btn under the display where it says clear and the msg will clear and the light will go out.
Mar 18, 2008 | Samsung Falcon 18 Corded Phone
Phone has error and stopped working
I had the same problem.....remove the batteries from all the phones...ensure the entire base is totally "dead"......and first put batteries to the base and switch ON the base....and then do the same for the extra handsets......hope tht works for you.....it worked for me!!
Oct 12, 2007 | Motorola Mobility E51 MD7161-2 Twin...
Motorola MD7161-2 owners manual
I found your manual for you. Hope this helps. http://broadband.motorola.com/consumers/products/MD7161/downloads/MD7161_User_Guide.pdf
Jun 24, 2007 | Motorola Mobility E51 MD7161-2 Twin...
Motorola Mobility E51 MD7161-3 Quad Cordless Phone Logo
537 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Eric Sutherland
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
