How do I get the front cover off a Gateway tower? It is a GP7 800.
  • 781 Answers
You need to provide a serial number of your computer and model. gp7800 does not say much to lookup that information for you.
in general most towers are secured with plastic tabs that are secured to the chasis of your system. what i suggest is for you to open on of the side panels and check at the back of the front panel if there are tabs securing your front panel. you don't want to force the plastic panel or those tabs as you may brake them if you apply to much force, simply move the tab to unsecure it and check all the tabs had been moved to an unlock position before jiggling with the part in order to remove it... you may also want to look if your system has a top pannel to be removed as removing this top pannel may also release other panels and may also provide acess to latches or tabs on the top part of the front panel that may allow you to unsecure these portion.
I've been trying to obtain general information on your system or any other gateway tower for you to have an idea but given how generic and also how propriatery this instructions may be is unlikely a service manual may be accessible.
with more info on your system you may want to inquire with gateway if there's a service manual with schematics by checking with them online. at this location.
http://support.gateway.com/support/ask_gateway.asp
Posted on Oct 08, 2008
Lost power button got turn off
try this; carefully detach (pull off) the front panel of the base tower unit.. and behind the plastic front that you just took off there's a little button that you can push to power off and on. The power button just goes through the plastic cover and pushes the button.
Jan 04, 2016 | Gateway Computers & Internet
Need to replace double layer dvd +-rw burner in my Gateway 838 GM. Will the curved front be a problem ?
You will have no problem at all replacing the DVD/RW, you may however have to pop the front off the tower, you do this by pulling on the front bottom of the unit and the cover should pop off, the DVD itself will unscrew from the case.
Good luck
Jun 30, 2009 | Gateway Computers & Internet
I need to replace the power button on a Gateway E4000 mid size to
I think you will find this site useful in assisting you with removing the cover. I think you can scan directly to pg 107 for the "mid-tower" http://nzr.mvnu.edu/facilities/items/gatewaye4000manual.pdf
Mar 26, 2009 | Computers & Internet
How do i remove the cover of a Gateway MFATXPNT NMZ 500SE
I found this:
"Facing front of computer you need to remove the left side cover. cover release is on top of the computer in center of side panel. Press in on button and p[ull top of side cover away."
Don't know if it's useful. If not let me know and I'll keep looking.
Mar 16, 2009 | Gateway Computers & Internet
Gateway Model 0019401806 Tower - Power button fell into case
there are tabs inside the case that you depress to pull the front cover off. once pulled off you should be able to replace the switch.
hope this helped
please rate well.
Mar 06, 2009 | Sony PCV-RS620G PC Desktop
HOW DO I GET THE COVER OFF THE TOWER TO A GATEWAY PC
Try this link for your user documentation:
http://support.gateway.com/s/PC/310_Series/2900300/2900300ul.shtml
That should help.
Jan 30, 2009 | Gateway 310S (2900621) PC Desktop
OPEN CASE
one screw in back on top then slid case back, about 2 inches then lift from rear
Aug 02, 2008 | Gateway E-2000 Deluxe PC Desktop
Need mini tower cover
Ebay has them for pretty cheap
Dec 07, 2007 | Gateway 505GR PC Desktop
Removing cover on gateway 300
This a tower right? I don't have a gateway but I have a dell and a compaq tower they come apart pretty much the same way. The left side panel slides out by pulling from the back. Some may have a screw or two you have to loosen or take out. Then you can either slide it by pulling from the back or there could be a latch that you slide to unlock it. Wow I can't believe it 60 bucks. Just keep messing with it you'll figure it out!
Oct 09, 2007 | Gateway 300 C PC Desktop
Computers & Internet Logo
155 people viewed this question
David Payne
David Payne
