Question about Nikon Speedlight SB-800 TTL Flash
Nikon D70s will not shoot
My Nikon D70s camera will not shoot when I place the Nikon speedlight on the hotshoe, seems it does not reconize the flash is there. Can you help? Thanks, George
  • 3 Answers
Make sure the hotshoe is clean, this will give the hotshoe a better connection. Make sure you lock the speedlight into place.
Posted on Jun 05, 2009
Nikon d700 hotshoe missfire with flash nikon sb900
Probably a loose hotshoe. This is a common problem with the D700 hotshoe and SB900 combo. The weight of the SB900 eventually loosens the hotshoe, meaning the internal screws holding the hotshoe in place loosens.
Nov 13, 2012 | Nikon D700 Digital Camera
Loose in hot shoe
Have you tried to tighten the little screws on the hotshoe?
if not you can purchase an off the camera flash mount
Multi-Flash Bracket Unit SK-E900
May 20, 2011 | Nikon Speedlight SB-800 TTL Flash
Sunpack Compatibilty
ifyour nikon has a hotshoe it should work quite well. I use sunpak flash on both canon and olympus without any problems. Just connect to hotshoe and shoot.
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Sunpak 383 Super Flash
I am using a Speedlight sb-800 on a Nikon D200. I cannot get the Zoom M function to change to Zoom. Any ideas?
Take flash out from hotshoe.
Can you set flash zoom manually?
When using Nikon Nikkor zoom & zooming, does flash zoom or hear motor sounds from head?
atdlee@netzero.com
Jan 16, 2010 | Nikon Speedlight SB-800 TTL Flash
The built in speedlight on my D 70S is not synching. Seems like the flash goes off before the shutter opens.My pictues all comes out dark no matter what I try. Can you help me?
I fixed this same problem with my D70s today, after twelve months of getting dark pictures despite the flash firing. It started syncing properly after I performed the following, though I'm not sure why as I was just mucking around.
- Set Program to P. - Push button to activate built-in flash. - Push, and keep depressed same button, which will put you in Flash Exposure Compensation mode. - My Flash Exposure Compensation was on +0.3 so I set it to 0.0 by turning the front wheel. Seemed to fix it.
Sep 23, 2009 | Nikon D70s Digital Camera
Built in speedlight on nikon d70 has stopped working. The light pops up, but no flash
If flash pops up and doesn't fire, little white pin/lever inside flash has lodged up inside flash casing and needs to be eased from where it is stuck. Careful when opening the flash up to dislodge the white plastic pin/lever, there are tiny wires you REALLY don't want to damage....
See how, with pics here:
http://www.stephanmantler.com/blog/d70s-camera-repair/
Sep 12, 2009 | Nikon D70s Digital Camera
I have a Samsung Pro815 and a Metz CT1 Flash
I believe the Metz does not have a hotshoe, does it?
You should be able to buy a hotshoe adapter with a pc socket and direct the Metz PC cord to the hotshoe adapter. These are very common peices and can be purchased in most any camera store.
Feb 02, 2009 | Nikon Speedlight SB-800 TTL Flash
Use of Nikon SB22s as slave flash.
in the manual setting the SB-22s is just a standard flash and should work with a standard hotshoe.
Dec 18, 2008 | Nikon Speedlight SB-22S TTL Flash
Water got into my sb600
I doubt it. Water damage usually is fatal, or very expensive.
Aug 07, 2008 | Nikon Speedlight SB-600 TTL Flash
SB-600 Flash not working
Make sure both camera and flash are set to TTL automatic mode. One time this happened to me and I had forgotten to lock the flash to the hotshoe connector.
May 10, 2008 | Nikon Speedlight SB-600 TTL Flash
Nikon Speedlight SB-800 TTL Flash Logo
167 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
