Question about LG Televison & Video
Lost remote control for lg v782w dvd/vcr combo
Dont want to have to spend lots of money on new remote, does anyone have a spare one?
snakehead
  • 1074 Answers
SOURCE: Use Zenith XBV443 DVD Player / VCR Combo without remote control
if you need a remote control for your unit go to www.partstore.com and purchase a originald remote for your unit.good luck.
Posted on Apr 08, 2007
SOURCE: Philips Universal Remote with Emerson VCR/DVD Combo
http://www.urc.philips.com/
US2-PM335
There you will find all needed information
Posted on Jul 05, 2008
SOURCE: LG V782W Combo DVD/Video Player - DVD won't eject
Hi
I am trying to set up my LG V782W but have lost my user manual.
Can you help. I need to know how to tune channels and program to record.
thanks
steve
Posted on Jul 20, 2008
  • 520 Answers
SOURCE: Sansui VRDVD4000
Universal remotes rarely fully work with these type of units. Call Orion customer service 800 289 0980 to price an original remote.
Posted on Oct 22, 2008
SOURCE: Need code for Emerson TV,DVD,VCR Combo
called comcast
Posted on May 28, 2009
95 nissan maxima both remotes are not working,tried reprogramming still no luck. Don't want spend the money for new ones if it is something else.dont know how to check if the remotes are both bad
Some autoparts stores have testers at the counter that can determine if the remotes are working. Otherwise it will take someone with an rf detector or an oscilloscope.
Jul 31, 2016 | 1995 Nissan Maxima
Lost key need new key cut
They should be able to issue you with a new key and just code it to the car.
Try another dealership
Nov 13, 2017 | Kia Cars & Trucks
Hi, i have started renting a house just a week ago. Its having an lg split air conditioner in the house.suddenly one day, when i came back from work and tried to turn on the A.C it didn't start. We...
Hi, does the Ac beep when you press the buttons.? Are the batteries in the correct way around. is there power at the AC. All good points to check. If all answers are yes then the chance is that the remote or the AC receiver board is faulty. Col R. digitalcontrols.com.au
Mar 04, 2011 | LG Heating & Cooling
I need to find a replacement part model UC7067RC; 7067FM-04A(6+6)
before you buy a new one try this
turn off the power!!
remove the fan controller and open it
you will see a big resistor (gray) resolder it - either on side is loose
or it is completly off
resistor location is r7
Thanks
nipper00
May 02, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
My GPZ 750 turbo starts misfiring after 15 mins running and losing power any ideas?? I`ve had it from new. 30,000 km
To be fair it could be lots of things on a turbo bike, but as problem when hot sounds like a wear problem piston rings go quite a lot on turbos. also after 30,000 kms will need good service. finally check for air leaks around the carb and turbo . new plugs are strongly advised before you spend serious money. the turbo may also be worn but dont touch till last.
Feb 09, 2010 | kawasaki Z750 Motorcycles
Car continues to misfire. Replaced spark plugs, wires, coils, module, fuel pressure regulator, and injectors. What else is left to do, without spending more money!!!!!!!
Guessing is the way to spend the most amount of money. After spending a lot of money guessing, most people dont want to spend money fixing the real problem, which in all cases, cost less than what they have spent. A shop will need to take it from here, First is to narrow down which cylinder is misfiring then go from there, Check fuel trims, compression, Vac leak, signal from the injector to the ecm. The injector is hot and the ecm grounds it. You dont say which engine you have, but the 2.4L have had a lot of coil housings go bad.
Nov 23, 2009 | 2001 Pontiac Grand Am SE
I have already mentioned the promlem with the p0300 code along with terrible exhaust smell. The hesitation happens regardless of engine temp, is this due to the cat being clogged or does this type of...
Spend the money to have it properly diagnosed by a reputable shop. Then have it repaired correctly.
Its cheaper to do this than to guess at a problem and spend a lot of money needlessly.
Sep 06, 2009 | 2001 Chevrolet Blazer
Code to program a Magnavox television.
the easy solution is to buy a new universal remote cost about 8 to 10 dollars but if you dont want to spend money just point the remote you have to the tv. and start clicking
till the tv. is off thas the solution
Aug 15, 2009 | Westinghouse SK-32H240S Television
I have 2 perfomance teknique 700wts and i dont know what kind of amplifier use
Hello perezmagdiel,
That 700 watts is maximum peak power, not RMS. If you're looking to not spend a lot of money for an amp, but want something that sends enough power to the Performance Teknique's, I'd recommend a 2-channel like the Boss Diablo D400.2. It's plently powerful enough and if you change out later, the amp can be bridged. And for inexpensive, it's got a lot of nice features, including a remote level control. It's 2ohm stable in stereo. Nice, for under $70.
Hope this helps.
Jul 17, 2009 | Performance Teknique ICBM-892 Car Audio...
Dont have remote
well if you still have the manuel for the dvd player the remote codes could be in there. if not you can always call sony tech support and see if they have the code on hand.
Aug 22, 2008 | Hisense TC24FS2H TV
Televison & Video Logo
89 people viewed this question
Computer Repairing
Computer Repairing
