Question about Mitsubishi WS-65611 65" Rear Projection Television
How do I get the picture back on my TV?
I was trying to connect the TV to my computer to look at some pictures. When it said Input select, I tried looking for one that would show the pictures. I couldn't find any. Now my TV has sound but no picture.
If you are running Windows XP. then go on the desktop. right click it. click properties. click settings. then it should show two monitors. click monitor 2. and click the checkbox that says "extend my windows desktop onto this monitor" and you should be all set.
Posted on Dec 26, 2008
Have no picture just keeps say no signal
Check the input jacks in the rear. Each should have a unique label. Pick one input that has cables connected to it. Note the input name. Follow the cables back to the device connected - DVD, BluRay, Cable / Satellite box, etc. Turn on the TV, and select the same input you noted above. Turn on the device connected to it (DVD, BluRay, Cable / Satellite box, etc.). If this fails, try again with a different device or connect the cable / satellite box to the antenna input and select ANT.
May 21, 2014 | Televison & Video
Macwynn TV 32" picture goes
I'm sorry that the TV is not displaying pictures on the screen. Please follow the troubleshooting steps and check the operation:
  1. Please make sure that the connections are secure and proper.
  2. Please select proper input by using the INPUT or TV/VIDEO Button on the Remote of the TV.
  3. Try connecting a different video source like DVD player or VCR and check the operation. If it works with another device, the issue might be with the input device currently.
  4. Also try connecting the device to a different port in the Computer if no other devices are available.
  5. If the issue persists, try with a different cable.
  6. Perform a power resetting and check the operation. To perform the power resetting, unplug the TV from wall outlet for more than 2 minutes and then reconnect it.
If the issue persists, after all above troubleshooting steps, service may be required. You can click hear to setup a service for the TV.
Also it would be good if you can come back with the model # of the TV to check whether the issue can be resolved with a firmware update.
Thanks for understanding. Please let me know if you require any clarifications / additional help.
Aug 01, 2011 | Televison & Video
Picture on all channels is dark
seems like its the inverter thats either not working or the tubes are faulty
Mar 26, 2010 | LG 42LG50 42 in. LCD HDTV
Connection using Component video No Video
1-Locate the audio/video input jacks AND the component input jacks on the TV.
Inputs are typically located on the back of the TV, but occasionally are on the sides, top, or bottom. They may also be located behind a hidden panel or door in the television.
Look for inputs marked Audio and Video IN.
Do NOT connect the system to anything marked OUT.
2-Connect the rectangular plug of the Component Video Cable into the Digital AV Out port on the back of the Wii console.
3-Connect the Component Video Cable to the television as follows. (Note that the Red and White audio cables are bound together with a black band labeled "audio.")
4-If you do not have a TV/Video button, then the input could be labeled something different. Some common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, AV, or a channel such as 00 or 99.
http://bit.ly/2ykOBno
Oct 13, 2017 | Aspire Digital AD-1000 DVD Player
When I switch from watching movie to watch TV on my Harmony 700 I get a picture on the TV that looks like the menu for the AV receiver and can't get back to a TV picture although I do have sound. I...
Hi, I would like you to try changing the input selection method for your TV. I suspect that some of the commands are incorrect.
1. In the software, click 'Settings' next to the icon for your TV.
2. Click 'Adjust Inputs'.
Make sure you select the method that best describes how the original remote changes inputs. Dont pay attention to the brand names. Also, make sure that the input list is EXACTLY the same in the software as on the TV itself.
Once you have done all of the input setup, update the remote and try it out again.
Let me know if that helps :)
Feb 01, 2010 | Logitech Harmony 700 LCD Remote Control
No picture from computer to pc
Please check the following things:
(i) You're using an appropriate cable to connect the TV to the Computer.
(ii) The cable is connected to the out port on the Computer and the corresponding in-port on the TV.
(iii) You've selected the correct input on the TV.
(iv) Dual display is enabled on the Computer.
(v) The resolution of the video signal being transmitted from the Computer to the TV should map the display resolution support by the TV. In this case, you may try lowering down the resolution of the TV in the Display Settings window of the Computer after selecting the second display.
Aug 31, 2009 | Toshiba Computers & Internet
Poor picture quality & audio reception
If the input to a HD tv is not in HD format the tv won't display an image very well. Be sure your input to the tv is compatible with the tv's technology for optimum performance quality Also re-check the input source (such as converter box, dvd player, etc..) and be sure you have the correct input/output ports connected properly. Try to reset all yout tv settings back to manufacturers defult specs. When an input signal is sent to the tv most modern tv's have software built in to select the proper format to display the input image. There may have been a mismatch communication error when your tv software tried to "handshake" with your converter box input signals from its firmware. So try a reset solution and re-connect the tv without the converter and see if that helps. If not e-mail me and I'll determine if the tv needs technical servicing.
Jan 03, 2009 | Proscan 26LA30Q 26 in. LCD Television
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
Television has sound but no picture
Check the cables first that connect to your video device, are they in tightly?  Test the cables on another TV to make sure they haven't gone bad, which is common.  Also check the input selection on the TV to make sure it matches with the video input the cable is connected to.
Dec 06, 2008 | Philips 50PFP5332D 50 in. Plasma...
Toshiba Model 42HM66 DLP Projection TV
I strongly doubt it's the lamp assy since you can actually see the blue screen. If the lamp failed, you would not see anything on the screen. This blue screen indicates to me that either the tuner is no longer decoding the signal, in improper input has been selected (ie: input 1 is selected while actual signal is on composite 1), or something of that nature. If you are getting audio then the input is selected properly but the video decoder has failed.
If your cable signal is going through a VCR or DVD, disconnect it from there and go directly to the TV (ie: bypass the VCR/DVD). If your picture comes back, there's some kind of problem with your VCR/DVD player.
If you have multiple inputs, try connecting an input signal to another input (ie: video 1, or aux from a dvd player) and see if you get a picture there. If you do get a picture, the whatever input you're currently using has malfunctioned.
Mar 08, 2008 | Televison & Video
Mitsubishi WS-65611 65" Rear Projection Television Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
